Old 03-02-2017, 10:33 PM   #81
autospeed_01
My Ride: 2000 328Ci
Try pm'ing vince as well. Maybe you can go outside the group buy (unless you already did pm him). But I'm excited to see the work you've done with the bottom plates welded in!
My Build Thread
From Salvage to Custom Widebody
DTM Style Angel Eyes (flat bottom)
autospeed_01 is offline   Reply With Quote
Old 03-03-2017, 11:34 AM   #82
cwarel
My Ride: 330ci coupe
20170222_100717 20170225_092751 20170228_135023 20170228_135031 20170228_135039 20170228_135055 20170228_143533 20170301_201106 20170301_201114 20170301_201123 20170301_201129 20170301_201139 20170301_201147 20170302_103445 20170302_103456 20170302_103501 20170302_103505 20170302_103525 20170302_111854 20170302_111900 20170302_120012 IMG_20170228_155407 IMG_20170301_200731
cwarel is offline   Reply With Quote
Old 04-05-2017, 08:40 AM   #83
cwarel
Got all the parts / went to the shop today and they are busy till next week (((( So i guess I gotta wait more
Old 04-12-2017, 06:33 PM   #84
cwarel
So it finally started. In 9 hrs I did all of the hardest work
1) Remove oil pan , drill it , clean it , put it back also took oil pick up and noticed that it had some rtv in it from valve cover so I cleaned it and blew all the stuff out.
2) Installed exhaust manifold
3) Installed Turbo On the manifold
4) Had to relocate wastegate actuator because it wouldnt fit , so I had to cut bracket and weld it , shorten wastegate actuator
5) Installed intercooler had to custom fab the brackets for the intercooler
6) Installed oil pump nut with a wire through it because I was always afraid that my nut would come off because I literary "drive spiritually" everyday if you know what I mean.
What has to be done to complete this build
1) Gotta go to someone who can weld aluminum so they could weld oil drain line because Ive got different angles and Im planning to angle one of the 45 a little more so it would fit perfectly
2) Make a down pipe with an angle that turbo sits it is very easy downpipe to make
3) Finish Oil supply which requires removal of the thermostat so i could screw in the double banjo bolt , unless I find strength within myself and go to the other end of the vanos oil supply line
4)Put Suspension back
5) Run all vacuum hoses for boost control , BOV, and wastegate
6) Route piping to turbo side of the intercooler which isnt that bad
7) Make sure I didnt forget anything
8) Start the car ( pull off the intake so engine gets no boost until I tune it )
9) Find that guy with a 2016 Hyundai Genesis 3.8 R-Spec and dust him EASILY .I raced him last night and I could keep up with him no problem, so next time he's getting violated
Turbo kit parts etc 20170412_090555_1
20170412_105316_1
20170412_121644_1 20170412_123831_1 20170412_123840_1 20170412_140436_1 20170412_184354_1 20170412_143730_1 20170412_153732_1 20170412_154628_1 20170412_154636_1 20170412_162811_1 20170412_162821_1 20170412_162833_1 20170412_165937_1 20170412_175103_1 20170412_184324_1 20170412_184339_1 20170412_184404_1
Old 04-13-2017, 12:15 PM   #85
daemonicus
My Ride: batmobile
everything sounds good except for the the oil pump nut wire. all your hard work is going to go right out the door when that nut backs off and breaks your wire. if you spend lots of time driving spiritually or spend a lot of time in the upper rpm range, you're driving a ticking time bomb.
the wire trick was used by guys as a temproary bandaid but unfortunately it has proven itself time and time again that it will eventually fail. the problem is that it will usually break in the upper rpms due to harmonics and if you lose oil pressure at 6k, you're going to be buying a new motor and wishing you had bought an upgraded oil pump the first time around.
daemonicus is offline   Reply With Quote
Old 04-13-2017, 07:39 PM   #86
cwarel
I knew that and I was also thinking if I should of welded it , but then I remembered that Ive got 2 engines in the backyard that got less than 40 k miles on them. Also In the summer Im planning to build one of those engines to handle boost better and then only then I will think of buying that Oil pump that supposed to fix all the problems because its aint cheap you know.Meanwhile Im pretty sure it will last me few months before it fails ( drove my car spiritually everyday , always racing people always in 6k rpm and the oem nut was good there. Also when I took it apart the chain that runs the pump felt a little lose , so maybe thats where the harmonic vibrations come in and take that nut out for us , I thought maybe weld chain tensioner somewhere there so it keep tension on the chain so less vibrations.
Old 04-13-2017, 07:50 PM   #87
cwarel
Another day , didnt put in that much work today because I had to run around for parts oil , etc
What got done today
1) Made downpipe myself and I had never welded before in my life so lmk how that looks))
2)Finished Oil supply line , Did it legit ))) I was too lazy to take thermostat off so I went to the Oil housing and ran hose there , little did I know my oil pressure sensor was cracking and the plastic on it deteriorated in my hands , so I took one off the engines I got in the back yard
3) Finished Oil drain , went to the machine shop to let them weld that aluminum and they cked up one of the 45 10-AN fitting , so I made them custom make it the whole thing untill it fits on my car ( also the guy that was doing it smelled like alcohol a lot)
4) Motor Mount had to be heavily modified because cold side of the turbo was in the way about half an inch so had to grind off the motor mount.
5) Put the suspension back ( gotta put 2 bolts in the lower control arms)
6) Royal purple 8 qts - 80 bucks , and 2 qts of diff fluid 40 bucks - 120 bucks of oil )))
Things to be done
1) Finish the intercooler piping I need few adapters to make it clear the rack and the k frame
2) Run all the vacuum hoses and mount boost controller
3)Tune the ecu
4)Ive got short shift in the trunk
And thats it , so hopefully tomorrow ill be done with the project and Ill say exactly how many hours it took me without running for parts
20170413_172322_1 20170413_180227_1 20170413_180232_1 20170413_184527_1 20170413_193651_1 20170413_194818_2 20170413_194825_1
Old 04-14-2017, 07:00 PM   #88
cwarel
Thats it the car is mechanically done , now I gotta tune the car ( drove it from the shop to my crib ( 8 blocks) feels like the fuel cuts out when it hits boost
Old 04-15-2017, 02:16 PM   #89
daniel_f.
My Ride: 330iC
Which is to be expected.
Old 04-15-2017, 04:04 PM   #90
xi46
My Ride: 2002 330xi ZPP/SP/CW
Been following this thread for a while and interested in all the MS43 tuning going on. I'm curious why the ECU would cut fuel when it sees more air than expected. Wouldn't that result in a dangerously lean mixture in the engine?
xi46 is offline   Reply With Quote
Old 04-15-2017, 04:24 PM   #91
daniel_f.
My Ride: 330iC
Cutting fuel basically means stopping explosions means no lean mixture.
Old 04-15-2017, 04:34 PM   #92
xi46
Ah that makes perfect sense now that I think about it as cutting fuel entirely. Thanks!
Old 04-16-2017, 05:01 AM   #93
Anthony78
My Ride: 330ci
Oh my god !!!!!!
Awesome work cwarel , I look forward to see final result with ms43 tune
I started my e46 330ci trackday project, leightweight, reinforcement subframe, lsd, coilovers, all polyurethane bushing, big sway bar and I would like to install a turbo kit asap in order to increase power to 350hp
Before :
In Progress :
Big thanks to you and I cross my finger for your tune
Anthony78 is offline   Reply With Quote
Old 04-16-2017, 01:35 PM   #94
cwarel
Ight so I figured why the car cut fuel like a mofo . Its me , im the idiot here and I put the maf facing the wrong way))) . After I flipped it everything was fine and car runs good untill it hits boost and then it leans out so that means I gotta add fuel , but I dont know how much timing I should pull tho because I didnt feel it knock ( the car runs good by itself up to 1 psi , after that it starting to lean out . On 1 psi ive got 12.7 afr which is good , so tomorrow or a little later Ill be road tuning at night , so if anyone in NYC wanna meet up hmu)))
Also I would not recommend installing cx racing BOV, that thing will hurt ur ears.
Old 04-18-2017, 03:41 PM   #95
cwarel
Got good news and bad news
Good news that I made a map where I can drive the car and floor it without it knocking and having enough fuel ( tuned at 7 psi)
So I did some more changes and then I decided to do a little launch and this is what happened , a while back I welded my diff and Iwas driving on it for 3 months beating hard on the car and there was nothing wrong , but when it hit boost all the bolts snapped that used to hold the diff , aluminum cover that has a mount too , got ripped out also , lucky me I was 10 blocks away from my house so i got my volvo xc90 and towed it to my house now , i gotta either fish a diff that I have in the back yard which is 2.93 or buy a new one with the same or different ratios , also might think of buying lsd right or stay on open diff till I completely finish tuning the car
Old 04-18-2017, 05:26 PM   #96
332
My Ride: 332
I have a 3.07 diff, perfect for a turbo car imho. Drop me a pm, super cheap.
332 is offline   Reply With Quote
Old 04-20-2017, 02:28 PM   #97
Anthony78
My Ride: 330ci
Hi Cwarel,
I'm really sorry for your diff I hope that you can fix it without lost money...
About your tune, You have done yourself with tuner pro and xdf files provided by Daniel ? If yes what map you have changed to have a good settings ?
Thanks in advance
Anthony
Old 04-21-2017, 11:59 AM   #98
cwarel
Good/bad news again
Got diff 3.46 for free
After further investigation I found out that my welded diff is still ok, and what went bad is subframe itself failed , pics later , also drive shaft is f***ed , imma keep on taking it apart more updates tonight!!!!!!!!!!!!>
Old 04-22-2017, 12:28 PM   #99
cwarel
More Updates
Got everything install , had to buy new driveshaft , and people at the junk yard screwed up cv join ( which i needed cuz thats what broke on mine) , So i lowballed a little for the price and I got it for a 100 , they wanted to charge me 175 -_-
Got new 3.46 diff in , subframe got reinforced with 1/4 steel plates were welded in 2 spots ( at the rear mount for the diff )
Took it for a drive ( im still on shitty tune ) 2 nd gear on traction lmao ( with traction control enabled it still broke tires lose and my car went sideways a little
Kind of lasy to upload pictures because I just finished
Tomorrow Im gonna install new speaker system in the car ,and once that is done ill finish tuning it ( because there is no room in the car because of all the speakers /subs and wires everywhere
Old 05-02-2017, 08:15 AM   #100
cwarel
Updates good and bad again
Good ones first
Tuned the car on 12 psi runs fine
Bought oil sending block and oil pressure gauge
Bad News
3.46 diff completely sucks ass
0,63 AR turbo is too small for 3 liter i can feel the car die off after 3500 rpm ( feels like a rocket from 2 k to 3.5) , gonna try to cop 0,82 maybe
Valve cover leaking again
AND MY PISTON RINGS GOTTA BE CHANGED OD OIL BURN ))
Also had the car running on 17 psi before i figured turbo is too small and its pointless
Anyone can give me an advice on turbo i should get , i want to boost come on 3500 rpm , not 2 k like my piece of crap right now) , also trynna buy more legit turbo then ebay , cuz that thing pisses oil everywhere
