Old 01-21-2017, 12:17 PM   #1
dist01
My Ride: BMW 330I E46
330i m54 turbo
Hello Guys,
Now i have standart without turbo and tuned with tunerpro (only increased advance ignition) and i want install turbo, I have at home ori garrett gt3076r. I have 3d printed spa (copy) exhaust manifold from heat resistend stainles steel. I want use OEM engine.
whitch injector buy? I read OEM fuel pump is good to 400hp. I have weld lincence Tig aluminium and steel.
And need help with software for turbo
dist01 is offline   Reply With Quote
Old 01-21-2017, 02:01 PM   #2
JakerMacDorey
My Ride: 93 325is
Let's see pics of the 3D printed turbo manifold!!
JakerMacDorey is offline   Reply With Quote
Old 01-21-2017, 02:06 PM   #3
dist01
330i m54 turbo
I will take picture I have in my work
Old 01-24-2017, 07:20 AM   #4
dist01
Now i have only 3d printed 4 cylinder diesel engine N47 GT1752 ballbearing. My manifold is on machining
Old 01-24-2017, 03:39 PM   #5
GuidoK
My Ride: Z4 3.0i ESS TS2+
Thats a 3d printed stainless manifold? Looks good! I see you deleted EGR on this manifold?
I cant wait to see the m54 manifold.
Is this a 3d printing model with a laser on a stainless powder bed where there's a small layer of powder added every pass?
E85 Z4 3.0i | ESS TS2+ | Quaife ATB LSD | Custom Brembo BBK front/rear | Schrick cams | Schmiedmann headers/cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers | Sachs performance clutch
GuidoK is offline   Reply With Quote
Old 01-24-2017, 03:49 PM   #6
dist01
Eos germany printer, laser printing
Old 01-24-2017, 11:52 PM   #7
Pole position
My Ride: E46 330ci
Wow, very cool
Shut up and drive
Pole position is offline   Reply With Quote
Old 01-26-2017, 10:23 AM   #8
Kyrazh
My Ride: e39
very intresting...
Kyrazh is offline   Reply With Quote
Old 01-26-2017, 12:17 PM   #9
dist01
Old 01-28-2017, 10:25 AM   #10
dist01
yes powder metod
Old 02-02-2017, 10:01 AM   #11
dist01
Coming soon
Old 02-02-2017, 10:07 AM   #12
cwarel
My Ride: 330ci coupe
So i guess this is for bottom mount ?
cwarel is offline   Reply With Quote
Old 02-02-2017, 10:15 AM   #13
dist01
Yes bottom mount
Old 02-02-2017, 12:44 PM   #14
GuidoK
You can print that in one go?
How long is that? 60cm or so?
The inside is probably a lot smoother than the usual cast turbo manifolds you see.
Is this your own printer or can you use it at work in the evening hours?
Old 02-02-2017, 12:59 PM   #15
sda2
My Ride: BMW E46 330i Touring
Wouldn't it be better to separate the flanches to reduce stress on the mounting plate?
sda2 is offline   Reply With Quote
Old 02-03-2017, 12:03 PM   #16
Kyrazh
My Ride: e39
dist01
when are you going to install this stuff?
i can't even breathe before i see how it works under the hood
Old 04-24-2017, 12:09 AM   #17
dist01
We have some problem with printing i still waiting
