Old 02-11-2017, 09:29 PM   #1
rkneeshaw
My Ride: 330i ZHP
Cams and the ESS TS2 and TS2+ tunes
Someone compared the TS2 and TS2+ tunes and found no changes in the fuel maps.
I think it was davew?
I was wondering if anyone knows specifically what is actually different between the tunes at all?
The only hardware changes when going to TS2+ is a slightly smaller pulley (81mm vs 83mm) and the FI cams.
I'm already running a 79mm pulley and the AFR and ignition timing is right where it needs to be.
But I want to add the FI cams, can I swap them in without updating the tune? Or will it run like crap?
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 02-11-2017, 11:46 PM   #2
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
You can just put them in.
For the best results, a retune would be on the menu.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 02-12-2017, 08:12 AM   #3
rkneeshaw
My Ride: 330i ZHP
So it will run fine, but the VANOS or something just isn't optimized for the new cam profiles, or something like that?
2003 BMW 330i ZHP
Old 02-12-2017, 09:11 AM   #4
dbarton62
My Ride: 04Z4R VF 12PSI
I asked my tuner about this exact thing.
His response was there is so much adjustability in the Vanos that even huge overlap cams can be tuned for.
It will not hurt to just stick in the cams and drive but a tune will optimize the power gains.
04Z4R 3.0 6 speed VF supercharged,Tial BPV,Ceramic coated Bimmerbrakes header, megan motor&trans mounts,42 design catch can, custom intake ducting,2.62 blower pulley,pre and post S/C WMI,CDV delete ,custom strut bar,3.64LSD, H&R anti roll bars, adjustable Hotchkis end links.Eibach Pro Kit,Koni Yellows. Carbon dipped interior.
dbarton62 is offline   Reply With Quote
Old 02-14-2017, 10:00 PM   #5
rkneeshaw
My Ride: 330i ZHP
Thanks guys!
2003 BMW 330i ZHP
Old 02-15-2017, 03:27 AM   #6
cosmos328Ci
All good.
I'll be looking forward to the dyno.
Old 03-21-2017, 08:12 PM   #7
MikeD118
My Ride: 325ci
Camshaft problems
Does anyone know of available camshafts for a m54 engine? 325ci with engine mods and out of luck on performance camshafts
MikeD118 is offline   Reply With Quote
Old 03-21-2017, 08:14 PM   #8
MikeD118
My Ride: 325ci
Does anyone have a lead on performance camshafts for a M54 engine? 2001 325ci
Old 03-21-2017, 08:22 PM   #9
MikeD118
My Ride: 325ci
Does anyone know of or have a lead on performance camshafts for a M54 engine.. 2001 325ci
Old 03-21-2017, 10:32 PM   #10
zha50
My Ride: '04 325ci 5MT
Schrick or Cat-cams.
'04 325ci M-sport 5MT
- Bone stock -
zha50 is offline   Reply With Quote
Old 03-22-2017, 12:38 AM   #11
daniel_f.
My Ride: 330iC
Dbilas too
Old 03-22-2017, 07:43 AM   #12
MikeD118
My Ride: 325ci
I've found a 264 in 248 out but with the duration being that fat apart would they work?
Old 03-27-2017, 03:47 PM   #13
Davew
My Ride: 2004 330ci Msport
There are no differences in vanos/camshaft related maps between TS2 and TS2+, but there are a lot of fuelling tweaks through the TS2+ file:
Injection time at idle speed, cold engine, vanos active
Injection time at idlespeed, cold engine, vanos active
Injection time at part load, cold engine, vanos I
Injection time at part load, cold engine, vanos II
Injection time at idlespeed, warm engine, vanos active
Injection time at part load, warm engine, vanos I
Injection time at part load, warm engine, vanos II
Basic injection time
My previous comments have been that ess, contrary to their advertising, do not tune the actual cam shaft VO etc, or "optimised vanos maps" or similar.
i would save your money and custom tune , car should adapt with TS2 tune in the meantime
Davew is offline   Reply With Quote
Old 04-01-2017, 01:06 PM   #14
rkneeshaw
My Ride: 330i ZHP
Crazy, so the ONLY thing they really change between TS2 and TS2+ is the injection time? And only for idle and part throttle. I'm surprised.
As terrible as ESS is to deal with when it comes to their tunes, and in light of this, it makes no sense to use their tune.
I was thinking there still might be value in the fact that they allegedly spend "50,000+ miles" tuning this kit for daily drivability and top performance, but I think thats horsecrap. It definately does NOT apply to the MS45 because the tune I got from them had to have several iterations of corrections for the AFR to be right (and the only thing out of the norm was my M3 fuel pump).
2003 BMW 330i ZHP
Old 04-08-2017, 11:54 AM   #15
randomdude
My Ride: ZHP, 135, X1
Agreed. I'm on my 7th update from them. My first tune was so lean, the car overheated on the first run on the dyno. The timing is still all over the place. Looking at the numbers from my last tune, all he did was retard the timing.
Good thing I have the data logger and your assistance in converting the O2 voltages to AFR (many thanks!) or it would of cost me over $700 in dyno time alone. Even after all this tuning and moving to an 83 mm pulley, I'm only at 286HP on my best run...
randomdude is offline   Reply With Quote
