Old 03-05-2017, 08:33 PM   #1
malcolmcrane33
My Ride: 1996 328i
Need advice! 330i supercharhed exhaust
I just recently purchased a 2001 supercharged 330i and need advice on what to do with exhaust. I dont have too much to spend on it and need to fix the back pressure. I was thinking about getting some stainless steel headers without cats and deleting resonators. I dont know what else to do from there. I would like to keep it under $700
Sent from my SAMSUNG-SM-G925A using E46Fanatics mobile app
malcolmcrane33 is offline   Reply With Quote
Old 03-05-2017, 09:24 PM   #2
hodgkinsc330ci
My Ride: 2002 BMW 330Ci
"Fix the back pressure"?
If you want catless headers, be prepared for the emissions ordeals if your state has any, and go with a quality E-Bay seller or Bimmerbrakes. As for a full exhaust, you could get a Borla rep for about $600. That's the setup my friend's S/C ZHP has. Together that'll run about $900 or so. It doesn't really get much cheaper than that.
Sent from my 831C using E46Fanatics mobile app
2002 BMW 330Ci 5AT
Originally Posted by lingon300k View Post
[BMW Motors] Advertising has somehow convinced people that they're different. That they're made by magical Dachshunds who only eat special bratwursts made by virgins in an undisclosed magical spot inside of the black forest that can only be accessed via a special hydrogen powered BMW helicopter.
hodgkinsc330ci is online now   Reply With Quote
Old 03-05-2017, 09:40 PM   #3
malcolmcrane33
My Ride: 1996 328i
Originally Posted by hodgkinsc330ci View Post
"Fix the back pressure"? What, did you buy it with straight pipes?
The car is pushing 280hp at the wheels so about 330hp at the crank. The headers and exhaust is all stock and the car is giving some codes saying there is a problem with the o2 sensors after the cats and when coasting the car goes into limp mode. I would think there must also be back pressure because the stock exhaust system doesnt allow for very much airflow when the car is tuned and s/c.
Old 03-05-2017, 10:59 PM   #4
hodgkinsc330ci
I'd look at taking your car to a local tuner to get the exhaust and motor tuned for your needs. I'm no expert, but to my knowledge, S/C motors shouldn't differ too much from N/A motors as far as exhaust tuning goes. You're gonna want something that gives you plenty of flow (reducing backpressure is always good, you'll always make power) but is designed properly to take advantage of scavenging effects which will ensure you aren't losing torque.
Read up on back pressure and exhaust systems and tuning. If you're looking for a more definitive answer, I'd suggest taking your questions to the F/I forum on here. I'm sure you'll find the help you need there. Lots of knowledgeable people around here!
Edit: The codes you're getting shouldn't be caused by any sort of "back pressure" issue. Either you're running too lean or too rich, or your sensors need replaced. Read the codes and look 'em up on here, see what others have done to fix the issues you're having.
2002 BMW 330Ci 5AT
Old 03-12-2017, 08:12 PM   #5
rkneeshaw
My Ride: 330i ZHP
Borla rep? Stainless mandrel bent with borla mufflers? Link?
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 03-12-2017, 10:07 PM   #6
hodgkinsc330ci
It's right here: http://m.ebay.com/itm/162269234026
Says it's stainless steel, and my buddy said it even comes with a lifetime warranty.
2002 BMW 330Ci 5AT
Old 03-15-2017, 05:01 PM   #7
rkneeshaw
My Ride: 330i ZHP
Interesting, thanks. Looks exactly like the Borla, in almost every way. Thanks for sharing
2003 BMW 330i ZHP
Old 04-02-2017, 05:41 PM   #8
Alpine-E39
My Ride: E39 ESS TS1
OP. If I was you I would not remove the resonators if this is a DD.
Alpine-E39 is offline   Reply With Quote
Old 04-08-2017, 12:00 PM   #9
randomdude
My Ride: ZHP, 135, X1
It was my understanding that the ZHP exhaust flows pretty well, Can anyone verify this?
randomdude is offline   Reply With Quote
Old 04-08-2017, 07:54 PM   #10
rkneeshaw
My Ride: 330i ZHP
I think that is probably very true, but I don't have any data to back it up unfortunately.
2003 BMW 330i ZHP
Old 04-30-2017, 03:55 PM   #11
indee321
^ i dont think it was the entire exhaust system but i remember reading that the muffler (back box) section of the zhp apparently flowed better than stock
Sent from my SM-A300FU using Tapatalk
indee321 is offline   Reply With Quote
