Old 03-14-2017, 07:34 PM   #1
ItsJune
My Ride: 330i Sedan
Identifying Injectors
Purchased a Used AA SC Kit, these injectors were provided and I'm not sure if there correct..
Can anyone help me identif the Lbs or what Injectors these are?
Sent from my LGLS775 using E46Fanatics mobile app
ItsJune is offline   Reply With Quote
Old 03-14-2017, 08:49 PM   #2
XanderCrews
My Ride: 2000 328ci
I'm gonna guess either 30lb/hr if for 330/28 or 24lb/hr if for 325/23.
XanderCrews is offline   Reply With Quote
Old 03-14-2017, 09:11 PM   #3
ItsJune
My Ride: 330i Sedan
After some google searches, looks like they are infact 24lb ..
What would be your thoughts on tuning on 24lb vs 42lb, c30 blower intercooled, stock regulator?
I'm trying to see 350 at least is that ideal
Old 03-14-2017, 09:20 PM   #4
XanderCrews
My Ride: 2000 328ci
I know the Asa tm-12 could hit that with the zhp according to there advertising but that's with the 8psi pulley but given a good tune and what other mods you have it's possible. Heres some good advice I got from rob43 do a compression test on your engine first.
Old 03-15-2017, 01:01 AM   #5
daniel_f.
My Ride: 330iC
Does the aa kit come with a different intake? Take a look at an image of the Siemens deka injectors and compare it to your new Bosch injectors. Tough fit i'd say...
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 03-15-2017, 01:07 AM   #6
ItsJune
My Ride: 330i Sedan
Aa kit doesnt come with a different intake but with a look at my stock 330 injector
I'm not sure so i ordered a some Siemens deka ones.. But most part is I'm regretting buying this sc without a tune
If i cant datalog the car and get it tuned remotely I'm lost.
Would it be better to buy a tune through Active Autowerke and go from there ?
Old 03-15-2017, 07:10 AM   #7
XanderCrews
My Ride: 2000 328ci
I would say yes but custom for your car would be better. Pick up a wide band and montiter your a/f that would be probably the most important gauge to have and if you can get some logger someone may be able to do something with your data for you. I look at engines like CPUs there is only so much they will give in an overclock but everyone is different. So an over the counter tune may work but a custom would be better.
Old 03-15-2017, 07:22 AM   #8
daniel_f.
My Ride: 330iC
Originally Posted by itsjune View Post
aa kit doesnt come with a different intake but with a look at my stock 330 injector
i'm not sure so i ordered a some siemens deka ones.. But most part is i'm regretting buying this sc without a tune
if i cant datalog the car and get it tuned remotely i'm lost.
Would it be better to buy a tune through active autowerke and go from there ?
Sent from my lgls775 using e46fanatics mobile app
ms45? Ms43?
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 03-15-2017, 03:54 PM   #9
ItsJune
My Ride: 330i Sedan
ms45? Ms43?
Ms43 Daniel and also using your EWS File
Old 03-16-2017, 12:24 AM   #10
daniel_f.
My Ride: 330iC
So you can log through TunerPro and the ADX file from mgh-34 Get a proper wideband and it should be able to log afr and all the important maps. I also tend to think GeorgeG will be able to create you a very nice tune for it
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 03-16-2017, 02:00 PM   #11
Pole position
My Ride: E46 330ci
Shut up and drive
Pole position is offline   Reply With Quote
