Old 03-16-2017, 12:07 AM   #1
dbr
04 e46 330xi automatic m54 supercharger?
Looking for a good supercharger for my car. A kit. And any tips or recommendations would be appreciated.
Sent from my SM-G930V using E46Fanatics mobile app
dbr is offline   Reply With Quote
Old 03-16-2017, 11:44 PM   #2
M Rated
My Ride: 540i/325i/330i/323iT
ESS supercharger kit for maximum power. G-Power or any other producers will also be a good idea for the upgrade. Such supercharger kits will make it possible for the engine to perform up to 350 HP and even more with stock M54B30 engine internals. Stock pistons and connecting rods are able to handle up to 400 HP.
M Rated is offline   Reply With Quote
Old 03-18-2017, 06:53 AM   #3
markusmarkus
My Ride: 2001 330Ci
I think the weak points of the upgrade will be the tranny and the chassis mounting points for the rear subframe.
Old 03-18-2017, 10:26 AM   #4
dbr
So I should reinforce the subframe and get a different transmission?
Sent from my SM-G930V using Tapatalk
Old 03-19-2017, 11:23 PM   #5
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
He means, Auto to manual if you want more than 7-8 psi boost and yes, re-enforce your subframe.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 03-19-2017, 11:28 PM   #6
dbr
Why not keep it automatic? And just get a better automatic transmission transmission
