Old 03-25-2017, 12:37 PM   #21
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Originally Posted by lingon300k View Post
Definitely needs to be stickied. Very good info, and will hopefully give an immediate answer to a very common question.
Done.
///Mmmmmm...
Old 03-25-2017, 12:38 PM   #22
BaliDawg
Originally Posted by Knight View Post
Havoline Dexron VI is no longer available. They are updating to a more universal ATF that meets GM spec, among others.
Thanks for the info. List updated.
///Mmmmmm...
Old 03-26-2017, 02:29 PM   #23
Kpriest
My Ride: 2005 325i
I noticed you put Redline D4 under the ZF but D6 under the GM.
Redline D4 lists that it is Texaco ETL8072 compatible. Doing just a drain and fill with a new filter, I want to match the old fluid as closely as I can since I won't get a few remaining quarts out.
Is there any reason why D6 would be better than D4 in the GM trans?
Kpriest is offline   Reply With Quote
Old 03-26-2017, 04:29 PM   #24
BaliDawg
I couldn't tell you which ATF is better than another for a given AT, and this thread specifically avoids that. We're simply listing the ones claimed to be compatible with LT71141 and Dexron VI.
D4 lists as compatible with LT71141.
https://www.redlineoil.com/product.aspx?pid=51&pcid=9
D6 lists as compatible with Dexron VI.
https://www.redlineoil.com/product.aspx?pid=115&pcid=9
///Mmmmmm...
Old 04-02-2017, 12:56 PM   #25
captkhaos
My Ride: '02 330Ci
Why not just use Pentosin?
captkhaos is offline   Reply With Quote
Old 04-02-2017, 02:51 PM   #26
BaliDawg
Pentosin ATF 1 is on the ZF list. It's not Dexron VI rated, so not on the GM list.
http://www.pentosin.net/specsheets/pentosin_atf1.pdf
///Mmmmmm...
Old 04-07-2017, 10:48 AM   #27
EthirD
My Ride: '02 325iT, '07 X5
I've now done two drain/fills in the last 400 miles using the Febi LT71141 ATF (Fluid was super nasty, so I let the first fill mix and then repeated). I'll try and report back on how it works, but I like that it (a) claims only LT71141 and Dex3 compatibility, so it's not some crazy generic fluid that meets a lot of standards, and (b) you can get it for around $8 a liter from RM Euro, which I believe is the cheapest for a non-universal style fluid.
On an unrelated note, I don't know that I'd recommend using it as I'm not a huge fan of "universal" style oils that claim tons of compatibility, but if you're in a pinch, the Walmart Supertech Multi-Vehicle Low Viscosity ATF claims LT71141 compatibility and claims to be "full synthetic," though we know how loose the rules are on the usage of that term in the USA. As mentioned, it also claims about a zillion other compatibilities, and in ATF I am a believer in less truly being more. Here's a link: https://www.walmart.com/ip/Super-Tec...1-gal/52626199
wagon devotee
BMW CCA Member #480924
EthirD is offline   Reply With Quote
Old 04-07-2017, 12:59 PM   #28
BaliDawg
Added the Super-Tech LV to the ZF list. Thanks!
I've also been using the Febi for a while with no issues.
///Mmmmmm...
Old 04-11-2017, 09:50 AM   #29
daves325in2012
My Ride: 2004 330cic
For the record, it's not the best fluid for the GM 390R, but it works great in place of Maxlife..
Bought it @ AutoZone clearance for $2 a quart and had a fluid exchange yesterday
Feels as good if not better than Maxlife I had put in there before, 60,000 ago
From what I can tell, it's a souped up version of Dex III meant to last longer, possessing slightly different additive packages and better base oil than the standard spec
I will say while not officially the latest and greatest Dex 6 spec, but it works great.
I would modify the change interval this go around and require a 30k severe service interval vs the 60,000 the Maxlife, especially since a drain and refill was done without filter and pan.. but from what I've been reading its better than plain jane Dex 3 in there..
Sent from my XT1254 using E46Fanatics mobile app
Mysticblau 330cic
Pretty Facelift on..PSS9\\Alpine 9855\\More
daves325in2012 is offline   Reply With Quote
Old 04-11-2017, 09:54 AM   #30
EthirD
You got Pentosin ATF for $2 a liter? When? Was it on display or behind the counter? I will totally make an autozone run and clean them out if they've got some.
wagon devotee
Old 04-11-2017, 10:07 AM   #31
daves325in2012
Hint: They have a yearly inventory blow out
This was about a month ago I purchased it
Front of store..On a clearance rack with Pentosin LV ATF too, which I skipped.
Look for an island next time, around the time everyone on the internet posts about Autozone clearance sales
Would imagine you'll be very happy like I was..
My total was like something silly like $14 for all the bottles
It's
Mysticblau 330cic
Old 04-18-2017, 11:32 AM   #32
bmwdude330
My Ride: E46 330i ZHP
This is a great thread, and you don't have to overthink it. Thank you!
bmwdude330 is offline   Reply With Quote
Old 04-19-2017, 04:33 PM   #33
protocol1
My Ride: 2001 330i
For the ZF 5HP19 trans, the only fluids that are actually suitable according to the LT 71141 spec are these:
ZF Lifeguard5:
Pentosin ATF1:
Febi No. 14738:
Fuchs Titan 5005:
In order of preference.
protocol1 is offline   Reply With Quote
Old 04-19-2017, 04:47 PM   #34
EthirD
ZF Lifeguard5:
Pentosin ATF1:
Febi No. 14738:
Fuchs Titan 5005:
How is this determined? Other than what the bottle says on the back, I don't know anything about it.
wagon devotee
Old 04-19-2017, 06:44 PM   #35
BaliDawg
ZF Lifeguard5:
Pentosin ATF1:
Febi No. 14738:
Fuchs Titan 5005:
All the fluids listed under ZF claim to be LT 71141 compliant.
///Mmmmmm...
Old 04-20-2017, 03:57 AM   #36
protocol1
My Ride: 2001 330i
ZF approved ATF are according to ZF TE-ML 11B listing here:
https://www.zf.com/global/media/en_z...s/TE-ML_11.pdf
Note that ATF-1 is now listed as a Fuchs product, Pentosin was bought out by Fuchs.
I use and recommend only ATF-1 having the exact performance properties suitable for the 5HP19 and is 100% synthetic fluid. Not a blend.
ATF-1 is not dyed red, it is natural amber color. With red colored fluid, there is no way to know what fluid is in the trans except it is for sure not ATF-1.
Low cost should not be a factor in the choice of ATF. The specification is crucial. I buy 5 liter jugs for about $56 on Amazon, and is a reasonable price, about $11.20/liter.
Also, it's worth mentioning that the "lifetime" fluid fill does not officially apply for severe service applications, where fluid changes are recommended by ZF. See TE-ML 11 for details.
Old 04-20-2017, 04:28 AM   #37
protocol1
My Ride: 2001 330i
Yes, nothing wrong with your list. However, certain ATFs such as ATF-1 are more compliant than others.
Old 04-25-2017, 10:06 PM   #38
Pro325ie46
My Ride: 2004 BMW E46 325xi
Originally Posted by Mango View Post
Maybe you can vet first for changes, then add from my old thread:
Automatic:
You should change your automatic transmission fluid and filter with OE or OE-spec'd high-quality fluid every 50-75k miles.
http://forum.e46fanatics.com/showthread.php?t=923563
What transmission filter would you recommend?
Pro325ie46 is offline   Reply With Quote
Old 04-26-2017, 12:50 AM   #39
BaliDawg
Originally Posted by Pro325ie46 View Post
What filter would you recommend?
Mango lists it right in his thread!
"Oil Filters
You can use any OE-spec parts store filter in a pinch, but I recommend using Mahle or Mann OE-quality/OEM filters.
Mahle supplies filters to BMWs for their ///M cars. Mann supplies for non-M. Both are fine but I prefer Mahle--the quality seems more robust/high-end. Part number: 11427512300"
///Mmmmmm...
Old 04-26-2017, 01:15 AM   #40
Pro325ie46
"Oil Filters
Thanks. I was asking about the transmission filter though. I looked up that part number and that is an engine oil filter.
