Sponsored by The Tire Rack
Old 03-25-2017, 06:24 PM   #1
peleke4
My Ride: 2003 bmw 330ci
Shop inflated tires 44 front, 37 rear. What tire pressure do you recommend?
Hello Everyone,
I have a 2003 BMW 330CI with Barum tires 225/40 R18 all around. It says max inflation pressure 51 psi. I usually do 35 all around. But yesterday I had my tires rotated at the shop. And they inflated the front tires to about 44 and the rear tires to about 37. What tire pressure do you recommend that's best for my car? Thanks a lot
peleke4 is offline   Reply With Quote
Old 03-25-2017, 06:46 PM   #2
Alex323Ci
My Ride: M3 & 323Ci (sold)
people like different pressures for different reasons.
I usually run 35 psi all around for my set-up and driving style.
Old 03-25-2017, 07:53 PM   #3
tcphoto
My Ride: E92 335 MT Coupe
I would start with the pressure stamped on the plate in the door and go from there. I liked running 34psi all around.
tcphoto is offline   Reply With Quote
Old 03-25-2017, 08:03 PM   #4
Onizukachan
My Ride: `04 M56 Touring
I always run the rear 4 psi higher
If I were to give my Touring a first name, I'd probably name it "Alan".
Mostly because I like puns.
DIY: E46 Touring TV Tuner Install/Mounting
DIY: Wiring City Lights, Rear Fogs, and Rear Camera in a Touring
Onizukachan is offline   Reply With Quote
Old 03-25-2017, 09:29 PM   #5
raptorman5174
My Ride: 330i ZHP
I run 38 all the way around
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 03-25-2017, 09:53 PM   #6
tks
My Ride: slower than yours
25 psi all around.
When I go 100mph, the air expands and makes it 32psi because science.
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 03-25-2017, 11:53 PM   #7
orb
orb's Avatar
My Ride: 325Ci
36 all around
orb is offline   Reply With Quote
Old 03-26-2017, 12:39 AM   #8
nealfromnz
My Ride: 2002 e46
Originally Posted by peleke4 View Post
Hello Everyone,
Sounds like they don't know what they are doing. Did they give any context to why the fronts were so high ?
nealfromnz is offline   Reply With Quote
Old 03-26-2017, 12:58 AM   #9
generalvp
My Ride: 05 330ci
32 front 36 rears
generalvp is offline   Reply With Quote
Old 03-26-2017, 02:15 AM   #10
GaryFS
My Ride: 2004 330ci Conv
Have a 330CI vert with staggered wheels and while at dealership for airbag recall tires were inflated to 32/38
Sent from my iPad using E46Fanatics
GaryFS is offline   Reply With Quote
Old 03-26-2017, 04:40 AM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Originally Posted by orb View Post
36 all around
Same
Old 03-26-2017, 07:24 AM   #12
markusmarkus
My Ride: 2001 330Ci
Does the car have a staggered tire set up. I own a 2001 330Ci with the staggered tires and I run 34psi up front and 36 out back. Seems to be a good combination of comfort and performance. But you should try various pressures to find your sweet spot.
Old 03-26-2017, 09:23 AM   #13
Knight
My Ride: '05 330Ci | '01 325i
I usually run 40 PSI all around.
Knight is offline   Reply With Quote
Old 03-26-2017, 10:24 AM   #14
mtnbimmer
My Ride: 325xi
This^
mtnbimmer is online now   Reply With Quote
Old 03-26-2017, 10:35 AM   #15
Citruz
My Ride: BMW E46 330i
Front = 36 PSI
Rear = 38 PSI
Citruz is offline   Reply With Quote
Old 03-26-2017, 12:01 PM   #16
BKMrSteel
My Ride: 99 328i
Anything from 32-38 normally, and depending what I'm doing and tires. I've ran 42-44 for fuel economy, it helps. Most often 36psi all around, because I like even numbers lol
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 04-11-2017, 02:55 AM   #17
Sicily1918
There I was, Sicily, 1918..
Sicily1918's Avatar
My Ride: '03 325Ci + '05 ZHP
Hello Everyone,
I run 34 all around (same exact size tires on my wife's 325) -- gives the firmest ride without the risk of going above max PSI.
I run 34/40 on the ZHP (as opposed to the 32/38 recommended by the door sticker).
Sicily1918 is offline   Reply With Quote
