Sponsored by The Tire Rack
Old 03-25-2017, 10:34 PM   #1
d0n
My Ride: e46 330ci
18inch 8.5 and 9.5 width
so im planning on buying new rims for my 2001 bmw 330ci and, these are 18 inch rims staggered width dimensions are 9.5 in the rear and 8.5 in the front. will these fit the car?
d0n is offline   Reply With Quote
Old 03-25-2017, 10:59 PM   #2
Alex323Ci
My Ride: M3 & 323Ci (sold)
need to know OFFSET
Old 03-26-2017, 02:23 AM   #3
AbdullaJaafari
My Ride: E46 330ci
The most important part of that equation is the offset, and then the size of the tires you will be using
also, are you lowered?
-2002 BMW E46 330Ci
AbdullaJaafari is offline   Reply With Quote
Old 03-26-2017, 02:25 AM   #4
d0n
My Ride: e46 330ci
no im not lowered
Sent from my SM-G935W8 using E46Fanatics mobile app
Old 03-26-2017, 03:04 AM   #5
WhatsAnE46
My Ride: not a crotch rocket
sooo whats the offset....?
WhatsAnE46 is offline   Reply With Quote
Old 03-26-2017, 03:31 AM   #6
AbdullaJaafari
My Ride: E46 330ci
Now you need to know the offset of the wheels.
I'm facing the same issue, and still not sure what's the right offset to go for without ending up rubbing. Also you might need to cut the inner side of the fender
-2002 BMW E46 330Ci
Old 03-26-2017, 08:17 AM   #7
The Snake
My Ride: 3 Pedal 330
FWIW I have those exact wheel sizes with +40 offset in the front and +45 in the rear. I'm lowered on H&R race springs and have 245/35 all around. No rubbing at all, but definitely cutting it close
"If you aren't driving a stick shift BMW, you're just steering"
The Snake is offline   Reply With Quote
Old 03-26-2017, 09:10 AM   #8
AbdullaJaafari
My Ride: E46 330ci
Attachment 652283
The wheels in the picture are
18"x9.5 +45
18"x8.5 +40
-2002 BMW E46 330Ci
Old 03-26-2017, 09:17 AM   #9
d0n
My Ride: e46 330ci
whats the lowest offset you can go, and tire width. so it can fit properly without me having to do any modifications?
Old 03-26-2017, 09:37 AM   #10
BKMrSteel
My Ride: 99 328i
Somewhere close to et30 with a 8" wheel.
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 03-26-2017, 10:39 AM   #11
d0n
My Ride: e46 330ci
so the rims are 18" width is 8.5 front 9.5 rear. et42 front et39 rear will this fit?
Old 03-26-2017, 11:28 AM   #12
The Snake
18"x9.5 +45
18"x8.5 +40
That is correct.
Old 03-26-2017, 11:29 AM   #13
The Snake
It also depends on what tires you want to run. Plug my numbers and the numbers you want into a tire/wheel size comparison tool and post your results.
Old 03-26-2017, 02:11 PM   #14
asianisafish
My Ride: 330ci
willtheyfit.com is your friend
also once again, offsets are important, and the size tire you want.
with an 8.5j front, you can do a 255/35/18 with a et30
with a 9.5j rear you can also pull off a 255/35/18 around an et35
for some aggressive fits
asianisafish is offline   Reply With Quote
Old 03-28-2017, 08:24 PM   #15
ben325I
My Ride: 02 325i / 00 323i
will this require fender rolling?
ben325I is offline   Reply With Quote
Old 03-30-2017, 11:30 AM   #16
asianisafish
My Ride: 330ci
Depends how low you wanna go, around - 2.5 camber in the rear would be needed and whatever the most you can get in the front
Old 04-04-2017, 02:30 PM   #17
Radnor
My Ride: 325Ci
op, go to "will they fit".
Radnor is offline   Reply With Quote
Old 04-05-2017, 04:21 AM   #18
abyzzim
My Ride: '03 318i Sedan
Stock ride height, with 18x8.5j ET+37 wheels in front... I reckon I can use a 10 mm spacer, and it will still be fine.
20170402_131843******** async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8">*********>
Touge
abyzzim is offline   Reply With Quote
