Old 04-07-2017, 02:12 PM   #1
02gtstang
My Ride: 2005 zhp coupe
E85 or meth????
I have a ess ts2 on my car and am looking at upping the boost to 11psi along with cams and to maximize power I would like to run either meth or possibly e85. Wondering if there are any e85 330s out there or if it's possible in these cars
2001 325i sport 5spd topaz blue R.I.P.
2005 330ci zhp 6spd black on black
02gtstang is offline   Reply With Quote
Old 04-07-2017, 02:32 PM   #2
XanderCrews
My Ride: 2000 328ci
I believe you would have to change your fuel pump for e85. It seems quite simple. I chose meth because e85 isn't available around me and trying to make my own just doesn't justify the $335 for a 55 gallon drum to mix with gas. I still haven't decided how I will install my meth I was thinking putting the pump on the washer fluid or actually routing it through the trunk. It's on hold until I reinforce my subframe though.
XanderCrews is offline   Reply With Quote
Old 04-07-2017, 02:45 PM   #3
dwtaylorpdx
My Ride: 2005 330xi
A tune should cover that boost ,,
FWIW,, I'm not a fan of either Alcohol in these older cars, just too much stuff is not fully compatible.. O-rings, sales, injectors etc.. any car before 06 typically unless sold as a flex fuel will need a new pump, replace all rubber fuel hoses, and injectors and injector o-rings to get some resistance to rotting them..
Dave Taylor
Pacific North West
dwtaylorpdx is offline   Reply With Quote
Old 04-07-2017, 07:34 PM   #4
Alpine-E39
My Ride: E39 ESS TS1
Inject 50/50 water/meth thru the twin screw. That's what I'm doing. It only comes on when I get into boost. Otherwise you are just wasting expensive fuel when crusing...
Alpine-E39 is offline   Reply With Quote
Old 04-07-2017, 09:04 PM   #5
02gtstang
That's what I was thinking of the meth. Ess has recommended against meth through the twin screw from what I've found. There is a 335 around here with a flex fuel tune to where he presses his pedal a couple times to switch between tunes from 93 to e85 and didn't know if the same was available for the e46 cars.
Old 04-07-2017, 10:53 PM   #6
Alpine-E39
ESS is completely useless aside from supplying the hardware. There is no reason not to. On a turbo it's different because the water droplets act like sandblasting to the leading edge of the blades, however our rotors are not spinning fast enough for this to be a problem. The mixture flash vaporizes due to the heat of compression/case/rotors, no seals are exposed to it. It helps to seal the clearances as well. You may not see higher boost because the air is more dense, but you will feel the POWER!
Fairly certain that 335 does not have the stock ecu.
Edit: laminova cores may cause water to recondense. I'm still ts1 (w/85mm) and plan to stay that way.
Old 04-08-2017, 07:51 PM   #7
rkneeshaw
My Ride: 330i ZHP
Someone emailed lysholm and they confirmed there is zero issues running meth through the twin screw. The only possible concern could be the aluminum laminova cores, and the concern is only valid if you think the methenol could condense and pool on the cores.
ESS says you have to use a stock OEM intake and even the BMW performance intake "isn't recommended".... so don't bother asking them what can or can't be done.
My latest crazy idea is to use the OEM sport button next to the heated seats button to turn the methenol system on and off. I'm trying to figure out if I can use an arduino to sniff the CAN bus of the vehicle and detect if "Sport" is enabled or not, and in turn, trigger power to the methanol system. Further, Terra has been experimenting with modifying the MS45.1 to detect "sport" mode and use a "sport" mode tune. If those things could be brought together, it provides a super slick way to activate and deactivate the meth system (in case fluid is low or your just commuting).
For the meth setup, I like the idea of using the windshield washer reservior because you get a built-in "low fluid light" in the dash, and it looks stock. Just put a sticker on it that says "50/50 water methenol mix only" or something. And it still works as windshield washer fluid, btw.
I haven't thought to persue E85 because of the work involved in overhauling the fuel system. Plus I know 93 octane is avialable everywhere, there's only one station in my area that has E85, would make long road trips a little logistically challenged too.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 04-09-2017, 03:02 PM   #8
Davew
My Ride: 2004 330ci Msport
The ESS supplied injectors will be too small also for e85, you will need to upgrade these as well as fuel pump, fuel filter, and fpr.
I was originally going to try water meth with a nozzle for each intake runner, but opted for setting up for e85 instead. Costs were about the same for hardware, but not having to fill a tank and reliability of less parts made me personally decide e85 was the better option for myself.
If you are planning to spray before the screws, I would suggest you consider removing the laminova cores, and let the water meth do the cooling. The laminova cores are quite restrictive and you should see about a full psi difference in having them/ not having them installed. With the water/meth "sealing" the tolerance between the screws, it would be interesting to see how much boost you gain on the same sized pulley
Davew is offline   Reply With Quote
Old 04-29-2017, 09:14 AM   #9
jdjg
My Ride: e39, m52tub30
E85 or meth????
Hi Dave, I use meth/water with my TS2++ SC and dont see any boost gain, only torque gain and little lost in hp
here with crappy gas and NO meth/water (79mm pulley)
here with crappy gas and 50/50 water meth (79mm pulley)
all the same day
jdjg is offline   Reply With Quote
