Flipping a "top mount" turbo manifold - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-13-2017, 01:11 PM   #1
lo_jack
My Ride: 2001 X5 5spd M54
Do the Chinese ebay m50/m52 turbo manifolds have symmetrical flanges? In other words, can you use a "top (front of engine) mount" manifold and flip it upside down to make it a bottom-rear mount? I have asked some of the ebay sellers, but they just tell me what the listing calls it.
As far as I can tell, the flanges are symmetrical, but the angle of the turbo flange and downpipe flange (if equipped) would be the limitation. Space aside, they look like they would be flip-able.
Manual transmission and AWD...it's like the 70's, but faster.
lo_jack is offline   Reply With Quote
Old 04-13-2017, 01:38 PM   #2
WALKD U
My Ride: Just Fast!
m5x is symmetrical
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 04-16-2017, 07:03 AM   #3
sda2
My Ride: BMW E46 330i Touring
Keep in mind, that some of the top mount manifolds are angled, so that the turbo doesn't collide with the hood. This may be for chassis/turbo clearance next to the engine.
sda2 is offline   Reply With Quote
Old 04-17-2017, 10:55 AM   #4
lo_jack
Yes, I have seen that. There are also some other subtle geometric differences, like the distance between the head and the mid-line of the turbo flange. I feel like I have more space than the bottom-mount e46 builds I have seen, but not that much more.
Old 04-17-2017, 01:12 PM   #5
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
why would you need it to be bottom mount. Either way, you're not going to hide that turbo
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 04-18-2017, 09:19 AM   #6
lo_jack
There is so little room up there. It looks like E53 has the same space problem e46 has (I specifically re-read Pole_position's build), but because of the chassis differences, has more room down below--particularly once the factory cats are gone.
It would simplify many things to put it back there. Yes, it would be nice to hide it, but that's not the point, of course.
Old 04-18-2017, 10:46 AM   #7
autospeed_01
My Ride: 2000 328Ci
I think if you had a custom "up pipe" made once you've decided on turbo placement, with the manifold mounted, you could make it work. But it would be a fair bit of test fitting, ie have the manifold bolted to the engine and the turbo hanging where you want it then, then tack a bar between the two flanges.
Gurov had done this in his thread:
http://forum.e46fanatics.com/showthread.php?t=773653
He used a Tcd manifold flipped over with a couple of generic extensions (but again it wasn't an x5 so I'm not sure how it would work for your application):
My Build Thread
From Salvage to Custom Widebody
DTM Style Angel Eyes (flat bottom)
autospeed_01 is offline   Reply With Quote
Old 04-18-2017, 11:43 AM   #8
lo_jack
That is interesting. An uppipe like a WRX is something I had thought about for top mount, but I wouldn't have believed you could squeeze a functional downpipe past the motor if he hadn't posted pictures of it. The wastegate plumbing is problematic, but maybe the answer there is internal...less pipes.
