Old 05-06-2017, 08:23 AM   #1
Fox Fader
My Ride: '05 325i
Most Likely Thermostat
51 degree morning running down the hiway (6 miles), stopped at my cousins for 10 minutes, temp gauge went up a bit, back on the hiway and temp gauge drops a bit. Points to thermostat. Only mentioning since this is my first BMW. Already had flush on the list, may as well add stat, 2 hoses and w/pump.
'05 325i handshaker CW Package 130k
M Shift Knob - 545i Short Throw w/ Suede Boot
Tint: 20%r, 35%f - PowerStops - HomeLink® - Clear Fender Signals
10 Ford GT 401a 5sp 17k miles
17 High-Ball Matte Nuclear Sunset Orange
11 KLR 650
07 Tuono Factory
03 F150 STX Lightning replica
11 Kia Sorento SX (wife's)
Slammin Tunes
Fox Fader is offline   Reply With Quote
Old 05-06-2017, 08:54 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Nothing unusual: Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491
Suggest if you do not have the OBDFusion App, you invest in the interface NOW. You will need it. You need to have visibility and without the interface it only delays things.
If you have a smart phone or table, get an OBDII App and interface so you can read the codes along with Live/Realtime or Freeze Frame data then you will know exactly what is going on with the engine fuel management system.
The OBDFusion App and proper VeePeak interface from Amazon are less than $30 for both for iProducts, less than $20 for both for Android
OBDFusion for Android is is $3.99.
https://www.amazon.com/Veepeak-Bluet...peak+bluetooth
OBDFusion, for the iProducts it is $9.99.
For iProducts you NEED a Wifi adapter or LE Bluetooth adapter which are more expensive and VeePeak does not offer these yet. If you choose LE Bluetooth interface, it MUST be one that is listed as supported on the OBDFusion web site. I think the Carista interface is the most reliable.
iProducts requires Wifi - https://www.amazon.com/dp/B00WPW6BAE...ywords=veepeak
Old 05-06-2017, 10:16 AM   #3
Fox Fader
My Ride: '05 325i
Yeah, I got a system that'll read live data on this car as well. Just got to pull it out with the old laptop. Got the ELM wifi adapter and stuff, guess I'll get the OBD fusion, Hell I may already have it. Checked with another guy's B, his gauge is at mid range on that run. With the car cooling down as I ran here again, I just decided to go on and get the stuff since it's prolly OE anyhow.
11 KLR 650
07 Tuono Factory
Slammin Tunes
Old 05-06-2017, 02:28 PM   #4
Fox Fader
My Ride: '05 325i
Live gauge showed that when my needle's in that area, coolant was around 135 degrees F. Heat being barley warm this a.m. helped tell the story.
11 KLR 650
07 Tuono Factory
Slammin Tunes
Old 05-06-2017, 02:38 PM   #5
jfoj
That's hell on the oil, fuel economy and engine wear. Check the rear bumper, license plate and trunk face for soot build up, not sure if the E46 will do this, but I know other cars will have black tail pipe tips and the back of the car will have a black film on it.
Old 05-06-2017, 02:44 PM   #6
Fox Fader
My Ride: '05 325i
This is the first time this has started to happen. This hasn't happened on any other chilly morning. Caught it right in time.
11 KLR 650
07 Tuono Factory
Slammin Tunes
Old 05-06-2017, 04:51 PM   #7
jfoj
Probably been having this problem for a while. Usually the P0128 code will pop, but this sometimes takes a while. If the ambient temp is at or above 70F usually the engine will get up to operating temp even with the soft thermostat. It will just take longer. The temperature gauge is buffered in these cars over like a 70F range and the needle will stay at the 12 o'clock position. So you will often miss the fact the engine is running cold.
Old 05-06-2017, 09:50 PM   #8
Fox Fader
My Ride: '05 325i
Like I said, it has just started. Ive been keeping an eye, a close eye on almost everything on rhis car since I got it. It was going to normal temp reading every morning I drove it. Pretty simple.
11 KLR 650
07 Tuono Factory
Slammin Tunes
Old 05-06-2017, 10:07 PM   #9
jfoj
Not sure you understand, the temperature gauge in these cars is BUFFERED. This means the gauge stays at the 12 o'clock position over a very wide temperature range, the gauge does not tell the truth. The engine could be running as low as 76C/170F and the needle will be at the 12 o'clock position and as I mentioned unless the ambient temps are much lower than 70F then you will never really know how cool the engine is actually running.
Old 05-07-2017, 12:20 AM   #10
SizzlerMA
My Ride: 2017 M240i XDrive
This sounds like what happened when my thermostat went. Goodbye $500 ...
2017 M240i XDrive
Mineral Grey Exterior
Black Leather Interior with Hexagon Aluminum Trim
8 AT
Premium Stereo
Park Distance Control
Nav
Apple Car Play
Carbon Fiber Rear Spoiler
SizzlerMA is offline   Reply With Quote
Old 05-08-2017, 08:04 AM   #11
Fox Fader
My Ride: '05 325i
Dude, I've been doing this for over 30 years, LOL I'm just new to BMW.
11 KLR 650
07 Tuono Factory
Slammin Tunes
Old 05-08-2017, 08:57 AM   #12
jfoj
That's why I wanted to make sure you understood how the coolant temperature gauge is buffered, it masks all sorts of low coolanttemp problems.
Old 05-08-2017, 09:09 AM   #13
Fox Fader
My Ride: '05 325i
We're Eye 2 Eye
I get you.
I was "there" when they dropped 'real time' gauges. My dad and others figured ways to make them real-time again. I did the same on an E-150 van I had. At this point, with obdII, laptops, android devices and apps I don't even sweat changing or adding gauges any more... Unless I get back on the track.
11 KLR 650
07 Tuono Factory
Slammin Tunes
Old 05-19-2017, 09:25 AM   #14
Fox Fader
My Ride: '05 325i
And it was passing thermostat. Car now gets to normal temp quickly and stays there like it's suppose to.
11 KLR 650
07 Tuono Factory
Slammin Tunes
Old 05-19-2017, 02:34 PM   #15
jmo69
My Ride: 03 325xi 98 328is
Expensive for a $50 part.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 05-20-2017, 12:01 AM   #16
Tinuva
My Ride: 318i
Sorry to hijack thread, but I think I have a similar problem on my 2001 330i M54B30, only started this week I think, so today I connected up OBDFusion and did a log.
In the log I can see, after 5 minutes, the temperature reaches 71 degrees celcius (160F).
It then hovers around 71-76c (160-169F).
When the car then stand still in parking lot, it then stays at 75c (167F).
Outside temperature was 13c (55F).
Am I correct or wrong, optimal temperature should be average ~95c (203F), but normal for the gauge (in the middle) is anything from 75C-113C (167-235F) ?
So this looks like the engine is running cold, think I will just get the thermostat replaced and look what else needs replacing.
Tinuva is offline   Reply With Quote
Old 05-20-2017, 06:35 AM   #17
Jason325xi
My Ride: 2004 325xi 5speed
Yup, sound like a soft thermostat. Seems like you know what's going on and how to handle it
Adjustable koni yellow front struts, Rob43 9-way adjustable rear shocks, Special Rob43 lowering springs, supreme power drop hats, billet aluminum rear shock mounts, poly RTAB, G.A.S. Disa kit, G.A.S. 1.2bar expansion tank cap
I run 6010 overhead in a t-shirt!
Jason325xi is offline   Reply With Quote
Old 05-20-2017, 06:51 AM   #18
Fox Fader
My Ride: '05 325i
How long did you let it sit still after the 5 minutes?
11 KLR 650
07 Tuono Factory
Slammin Tunes
Old 05-20-2017, 09:23 AM   #19
Tinuva
My Ride: 318i
I didn't record any data after turning off the car. Just leave the car like I would normally when not driving it. Should I record data after turning off the car?
Sent from my MI 5 using Tapatalk
Old 05-20-2017, 09:25 AM   #20
Tinuva
My Ride: 318i
Thanks. Just hope i didn't drive it too long like this, should have bought obdfusion earlier.
