Old 05-10-2017, 11:57 AM   #1
Doc_V
My Ride: 2000 323ci Cabriolet
Car parked, engine off - Should there be *any* play in the steeriing wheel?
With the engine off, key *still* in the ignition so the steering wheel does not lock, and parking brake on; how much [if any] steering wheel play is normal?
Doc_V is offline   Reply With Quote
Old 05-10-2017, 12:24 PM   #2
My Ride: Lexus
When engine off and not locked, It should move but feel firm and tight, but should not be any play or clicky business.
http://www.e46mango.com/2016/10/the-...n-refresh.html
Old 05-10-2017, 02:08 PM   #3
05SMG
My Ride: 2005 330ci ZSP
+1 ^^ Checked mine yesterday.
Technically 05SSG
05SMG is offline   Reply With Quote
Old 05-10-2017, 02:59 PM   #4
jdstrickland
My Ride: '94 325iC & '00 323i
I guess "play" is subjective. The steering rack can allow the steering wheel to have some play of a few degrees. The tires should move when the wheel it turned, but the movement can be difficult to discern so you think you are moving the wheel further than you really need to.
Old 05-10-2017, 03:00 PM   #5
jdstrickland
This.
Old 05-10-2017, 06:31 PM   #6
YoitsTmac
My Ride: 328Ci
Yes. There should be some. The guibo is flexible and that should give a bit without any assist before you begin moving the actual tires. But the wheel should flick back to where it started. My front suspension was completely redone 5k miles ago
YoitsTmac is offline   Reply With Quote
Old 05-17-2017, 08:47 PM   #7
Doc_V
Follow up - after replacing the control arm bushing's and sway bar links, there's much less play in the steering wheel. What play there is left, I believe may be due to the uneven wear of the tires from the worn out control arm bushings.
Old 05-17-2017, 09:06 PM   #8
redfeathers
My Ride: 2001 bmw 330 ci
I have a good comparison, 2001 330ci vs my 2016 mustang GT. I turn the steering wheel of my GT 1/4" and I feel the tires squeaking on the drive way......NO PLAY at all. The 330ci quiet loose but the rubber bushing have at least 75000 miles on them so their you are. Replace everything and it should be tight again.
2001 bmw 330 ci 250k miles white AUTO A5S 325Z steptronic
redfeathers is offline   Reply With Quote
Old 05-18-2017, 09:11 AM   #9
HOODY007
My Ride: '04 330ci
Have you replaced the steering coupler? It's relatively inexpensive, and for me, removed virtually all the play in the rack...
HOODY007 is offline   Reply With Quote
Old 05-18-2017, 08:28 PM   #10
tks
My Ride: slower than yours
balance a quarter on top of the steering wheel; as you rotate the steering wheel, george washington (make sure it's heads up towards you) will roll over roughly 90 degrees. if george falls off your steering wheel due to excessive wheel play then take a look at the steering coupler.
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 05-19-2017, 09:41 AM   #11
Archbid
My Ride: 2003 330cic
There should be no play in the mechanism. Period. Any movement of the wheel should simply be the tires' slipping or flexing.
I have a new flex disc.
Archbid is offline   Reply With Quote
Old 05-19-2017, 09:58 PM   #12
divil
My Ride: 2002 ///M3
Power steering racks must have some play in order to work.
The steering column is connected to the pinion via a springy torsion bar. When you turn the wheel, the bar twists. This twisting action allows one half of the control valve to turn relative to the other...and this relative movement opens up the passages for pressurised fluid to flow, thereby providing the power assist.
If you turn the wheel a little with the engine off, it will feel springy - let go and it springs back to where it was. You are feeling the torsion bar.
divil is offline   Reply With Quote
Old 05-20-2017, 10:07 AM   #13
Doc_V
Wow... doesn't get much more comprehensive than that.
^^This right here... And yah, it springs back, so I that's a good thing.
