Old 05-16-2017, 03:00 PM   #1
ozscorpio77
My Ride: E46
Weird Recess on New Saleri water pump
Hello All. I am new to this forum. I bought an E46 a few months ago, I am about to do the much recommended cooling system overhaul. Car has 110000kms on it. only a minor leak on the radiator. I plan to replace everything. I bought the Saleri water pump, i cross referenced with the RealOEM website. Once it arrived it seems to have the center axle somewhat recessed, is this a normal condition? should I install it with no worries or should I return it?
Return is a big hassle were I live hence why I ask here, maybe Mango or someone else here has had a similar experience. I used the search button, there are tons of info but nothing about this. Below is a picture of such pump.
Cheers!
ozscorpio77 is offline   Reply With Quote
Old 05-16-2017, 03:21 PM   #2
cvx5832
My Ride: 325Ci, 325Cic, C300
Cheers!
https://www.ecstuning.com/b-saleri-p...517527910~sal/
Edit : Pictures are from multiple pumps judging by the part that attaches to the pulley. Looks like you get it one way or the other. You'll be able to confirm when you compare the depth of old vs new.
cvx5832 is online now   Reply With Quote
Old 05-16-2017, 03:37 PM   #3
My Ride: Lexus
As long as its tight i wouldnt worry about it
seems the other photos online match yours
Old 05-16-2017, 03:45 PM   #4
Alex323Ci
My Ride: M3 & 323Ci (sold)
looking at a photo from ECS Tuning looks like the same
Old 05-16-2017, 04:50 PM   #5
ozscorpio77
My Ride: E46
Awesome, thanks to all for the clarification. I had only checked the pictures in forums and not ECS tuning. Seems to be fine. .
I was also checking the DIY for accessory belts, I shall post some pictures of my car seems to have the rare 2 idler pulley configuration (instead of the usual 3).
Old 05-16-2017, 08:55 PM   #6
jmo69
My Ride: 03 325xi 98 328is
M54 motors have one idler pulley. Two tensioners, but only one idler on the water pump, crank, power steering pump and alternator belt.
https://www.google.com/search?q=m54+...lsS9u3mTlMaGM:
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 05-16-2017, 11:25 PM   #7
azbp2
My Ride: 2007 VW GLI 6MT
Good luck with the cooling system overhaul. I just did mine today and feel a whole lot better about summer time driving in Texas
azbp2 is offline   Reply With Quote
Old 05-19-2017, 08:50 PM   #8
ozscorpio77
My Ride: E46
Thank God I did this, everything has gone smooth. Until a few moments when I removed the waterpump and found a plastic impeller shattered in half. It Doesn't sound like composite like the saleri one. The car was giving me no problems at all no symptoms. So I was even thinking on not changing it. Thankfully I will also replace the radiator too so any large pieces of the impellerr should be there.
Also what I meant to say is that my car has the typical 2 mechanical tensioners but no idler. I will post pictures for the records.
ID:	655421   Click image for larger version
Old 05-19-2017, 09:23 PM   #9
Pro325ie46
My Ride: 2004 BMW E46 325xi
Saleri pump is legit. 26,000 miles and no problems. Dont worry.
Pro325ie46 is online now   Reply With Quote
