Old 05-16-2017, 10:06 PM   #1
loko209
My Ride: 2000 bmw 328i
2000 bmw 328i tcm help
i need help finding the correct replacement for my tcm which are the numbers that have to match so its a direct fit without having to reset it.
loko209 is offline   Reply With Quote
Old 05-17-2017, 12:03 AM   #2
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
By TCM, do you mean transmission control module? In BMW speak it's called an EGS. The part number is printed on the label on the module; get the same part number.
Here's an example. It's part number is 7506056.
http://www.ebay.com/itm/152515862065
///Mmmmmm...
Old 05-17-2017, 10:06 PM   #3
loko209
mine says 7504685 is theyr a newer version or is that just the part number sorry if i sound like a rookie.
Old 05-17-2017, 10:23 PM   #4
BaliDawg
As I said already, buy one with the same part number: 7504685.
The firmware inside it can be updated with WinKFP.
///Mmmmmm...
Old 05-17-2017, 10:43 PM   #5
loko209
thank u so much what program do i need 4 that
Old 05-17-2017, 11:03 PM   #6
BaliDawg
If you're in SoCal, I'll update it for you. The program is WinKFP, as I said already.
///Mmmmmm...
Old 05-18-2017, 12:18 AM   #7
loko209
sounds good sir im having trouble finding 1 is it recomended to update the 1 i got on rite now my car is in limp mode i believe thats the reason i cant communicate with the egs as also the ebox fuse keeps blowing for the egs so im running with the blown fuse
Old 05-18-2017, 07:53 AM   #8
markusmarkus
My Ride: 2001 330Ci
I'd find out why the EGS fuse keeps blowing first. There may be a short in the power wire or the connector. Installing a "new" EGS may not solve the problem.
Old 05-18-2017, 08:25 AM   #9
cvx5832
My Ride: 325Ci, 325Cic, C300
The heater circuit for the 02 sensors is on the same fuse as the EGS. To test, disconnect them one by one, replace the fuse and switch to ON (not START). When the fuse blows again you have your culprit. Replace the offending sensor or just replace them all.
fuse block
cvx5832 is offline   Reply With Quote
Old 05-18-2017, 02:46 PM   #10
loko209
[QUOTE=cvx5832;17245367]The heater circuit for the 02 sensors is on the same fuse as the EGS. To test, disconnect them one by one, replace the fuse and switch to ON (not START). When the fuse blows again you have your culprit. Replace the offending sensor or just replace them all.
fuse block
image[/Q
i replaced all 4 with cheap ebay 1s but all 4 pop out bad still but fuse blows anyways
Old 05-18-2017, 08:08 PM   #11
cvx5832
Any work on the VCG lately? Has happened to a few here where the wire got pinched and the wire eventually shorts out.
Old 05-18-2017, 08:59 PM   #12
loko209
what is the vcg
Old 05-18-2017, 11:56 PM   #13
BaliDawg
what is the vcg
Valve cover gasket.
///Mmmmmm...
Old 05-19-2017, 06:13 PM   #14
loko209
Valve cover gasket.
i replaced it about 4 months ago
