Old 05-17-2017, 09:29 AM   #1
UnBearable_Lo
My Ride: 330ci
Bad fuel system, but running rich?
Misfire with low fuel level
Pre cat and post cat 02 running rich
While I have read other threads regarding the misfire code, nobody seems to agree as to wether it's the fuel pump or the filter, but on all of those threads I have seen that they are also running lean where as I am the opposite, running rich. Why is mine different from the others?
I have also noticed a misfire whenever cold starting, a lower idle RPM (used to sit at 750-800, now bounces between 600-700) and sometimes when I attempt to downshift I can hear a slight misfire , I'm not sure if this is also caused by the fuel system, or if it could be something else.
UnBearable_Lo is offline   Reply With Quote
Old 05-17-2017, 10:19 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
I doubt the engine is running Rich.
What is leading you to the idea the engine is running Rich??
Provide codes and descriptions of the codes and what tool or software you used to gather the codes. My expectation is you have a code that states something like "O2 Sensor Bank 1, Sensor 1 Deviation Too Rich" If so, this is NOT a RICH code, it is a Lean code.
Your description sounds like the engine is running Lean.
Most of what you need to solve your problem is outlined here: Solve your misfires, lean codes, rough idle - http://forum.e46fanatics.com/showthread.php?t=897616
Old 05-17-2017, 12:34 PM   #3
UnBearable_Lo
My Ride: 330ci
I used a Launch Creader V+ at a friends shop, and if I'm not mistaken the codes were:
P0313 Misfire with low fuel level (one active, one pending)
P1091 Pre-cat fuel trim too rich bank 1
P1093 Pre-cat fuel trim too rich bank 2
Plus 2 post cat codes for headers
Will double check codes with BMWLogger later tonight.
Also your thread was very helpful last year chasing down a vacuum leak, and rough idle issue.
Old 05-17-2017, 01:03 PM   #4
jfoj
Fuel Trim Too Rich means the DME has added as much fuel as it can and still not correct the LEAN condition. This is not a Rich condition.
Most likely a CCV hose air leak would be the first guess.
Freeze Frame and Fuel Trim data is needed.
If you have a smart phone or table, get an OBDII App and interface so you can read the codes along with Live/Realtime or Freeze Frame data then you will know exactly what is going on with the engine fuel management system.
The OBDFusion App and proper VeePeak interface from Amazon are less than $30 for both for iProducts, less than $20 for both for Android
OBDFusion for Android is is $3.99.
https://www.amazon.com/Veepeak-Bluet...peak+bluetooth
OBDFusion, for the iProducts it is $9.99.
For iProducts you NEED a Wifi adapter or LE Bluetooth adapter which are more expensive and VeePeak does not offer these yet. If you choose LE Bluetooth interface, it MUST be one that is listed as supported on the OBDFusion web site. I think the Carista interface is the most reliable.
iProducts requires Wifi - https://www.amazon.com/dp/B00WPW6BAE...ywords=veepeak
Old 05-17-2017, 03:27 PM   #5
UnBearable_Lo
My Ride: 330ci
So if I'm understanding correctly, if it were reversed and the fuel trim was reading too lean, it would mean the engine is running in a rich condition and the DME can't compensate? Interesting.
I will read the trim levels when I get home, but I'm about 50% sure that the STFT/LTFT has one reading -9x.xx% while the other sticks around -07.xx%. Don't really remember which is which...
Im slightly confused at the links you posted for the scanner. You mentioned VeePeak doesn't offer the WiFI yet, but the link for Amazon says WiFI? Do I still need the wifi adapter?
Old 05-17-2017, 03:40 PM   #6
jfoj
Do not try to understand what is going on, there are often problems with language translation, point of reference and semantics. Is the glass half empty or half full type of problem.
Best to gather the Fuel Trim data and cross check this with the codes and see what is going on.
Positive (+) Fuel Trims mean the DME/ECU is adding fuel in an attempt to balance out the fuel mixture.
Negative (-) Fuel Trims mean the DME/ECU is removing fuel in an attempt to balance out the fuel mixture.
Sorry about the confusion, VeePeak does not offer a LE Bluetooth adapter yet and even if they did, it would have to specifically be programmed to work with OBDFusion. I guess the statement was not written as clearly as I could have been.
It probably should have been worded like this:
For iProducts you NEED a Wifi adapter or LE Bluetooth adapter which are more expensive and VeePeak does not offer a low cost LE Bluetooth Low Energy interface. If you choose LE Bluetooth interface, it MUST be one that is listed as supported on the OBDFusion web site. I think the Carista interface is the most reliable.
Old 05-17-2017, 03:51 PM   #7
UnBearable_Lo
My Ride: 330ci
Ahhh okay that makes sense, thanks jfoj.
Without a doubt I know the fuel trim levels are negative, not positive. I will update with live data in a few hours when I get a chance
Old 05-17-2017, 04:12 PM   #8
jfoj
And often if the Fuel Trims are Negative and taking away fuel, since most vehicles do not often run Rich, then this can actually cause a Lean condition if there are faulty inputs to the DME confusing things.
Most driveability problems are a result of Lean conditions.
Old 05-18-2017, 11:19 AM   #9
UnBearable_Lo
My Ride: 330ci
Those are the codes pulled from BMWLogger, theyre pretty different than what was pulled with the Launch scanner. Fuel trim codes are gone, before I cleared it I also got a fuel sender code.
Waiting for the Amazon scanner to arrive for live data, for whatever reason BMWLogger can't/won't allow me to do it.
Old 05-19-2017, 07:51 AM   #10
powerstroke
My Ride: 330i G-string
Hai,I think if his plugs are black,high fuel consumption or black smoke at exhaust tail pipe,then he cn conclude that his running rich.
Sent from my GT-S7392 using E46Fanatics mobile app
powerstroke is offline   Reply With Quote
Old 05-19-2017, 07:53 AM   #11
powerstroke
On the other hand,can anyone help me wt the function of a vent valve on an m43 engine?
Old 05-19-2017, 07:56 AM   #12
powerstroke
My engine cant hold idle when cold but wen I disconnect MAF it holds,replaced MAF but no change,cn I suspect vent valve?at some point it was even running rich..
Old 05-19-2017, 10:48 AM   #13
jfoj
BMW trouble code translation from Bentley manual.
233 = P0420 Catalyst System Efficiency Below Threshold (Bank 1)
234 = P0430 Catalyst System Efficiency Below Threshold (Bank 2)
235 = Pre Catalyst Fuel Trim System Too Rich (Bank 1)
236 = Pre Catalyst Fuel Trim System Too Rich (Bank 2)
But ALSO note, not sure if this is a type or a situation where often the codes may have multiple meanings. The 235 & 236 codes are also listed in the Bentley manual as:
235 = Pre Catalyst Fuel Trim System Too Lean (Bank 1)
236 = Pre Catalyst Fuel Trim System Too Lean (Bank 2)
This is why it is simpler and easier to use a generic OBDII for most driveability problems and then compared the code description and also Fuel Trim values to see what is really going on.
As I have mentioned, most modern vehicles do not run Rich, they may have a Rich indicator, but this is often due to bad sensor data or sensors connected incorrectly.
The P0420/P0430 codes mean the catalyst may be compromised, these can be really nuisance codes and may be able to be sorted out without catalytic converter replacement, however, on many of these higher mileage cars the catalyst are failing.
Old 05-19-2017, 12:59 PM   #14
UnBearable_Lo
My Ride: 330ci
The inefficient catalyst is because I have headers, is it safe to assume the air flow meter code is referring to the MAF, or could it be some type of leak around the intake
Old 05-19-2017, 01:08 PM   #15
jfoj
Yes, code 8 has two different definitions in the Bentley, again unclear if this is a typo or translation failure?
Mass or Volume Air Flow Circuit Low Input AND Mass or Volume Air Flow Circuit High Input
Notice this is listed as a "Circuit" problem and not a "Sensor" problem. Sometimes a "Sensor" problem can appear as a "Circuit" problem, but usually a "Circuit" problem does not appear as a "Sensor" problem.
This error happened at 5152 RPM based on the info provided. My guess is possibly a broken wiring inside the MAF connector right at the female terminal crimp. Watch live data and wiggle and pull on the wiring and see what happens to the live data values.
