Sponsored by The Tire Rack
Old 12-03-2006, 10:18 PM   #1
sna77
sna77's Avatar
My Ride: BMW
Anyone running OEM 19" CSL wheels on an e46 sedan
I posted something like this the other day and got a bunch of responses along the lines of "there are lots of threads with CSL reps."
Just to be clear... I'm only interested in seeting OEM 19" CSL Wheels on an e46 sedan
I've seen plenty of 18" CSL reps and I'm not crazy about them. The 19s curve inwards, and I like that look.
I believe 4 fronts will fit on an e46 sedan w/o rubbing or need for fender rolling:
http://www.bmwwheels.com/bmwwheels_d...163&Series=E46
Anyhow, if anyone has any pics of OEM ones only, please post them.
Gratzi
sna77 is offline   Reply With Quote
Old 12-03-2006, 11:20 PM   #2
325rider
My Ride: gone, not forgotten
Send a message via AIM to 325rider
the 19's wont rub unless you drop. BUT, Oem 19's (front) WIll fit all around on your sedan. FREE
Schrick 264/248 | Ebay Headers | AA dyno tune | SSR GT2 18x9 | 3.46 | Full OEM Mtech 2
My Fitness YouTube Channel!!! Thanks for all the support I am GRATEFUL
http://www.youtube.com/channel/UCozwn8gNwXQVuG0se8cTpUQ
325rider is offline   Reply With Quote
Old 12-04-2006, 05:10 AM   #3
kameleon
My Ride: various
Send a message via MSN to kameleon
is there any way the rears will fit also?maybe with stretched tyres. i priced these genuine today for my 00' 328 sedan also. interesting that they're alot cheaper then the done to death std m3 rims.
kameleon is offline   Reply With Quote
Old 12-04-2006, 07:27 AM   #4
kpeng
Banned User
My Ride: E46 330 and E30 325
The offset is simply too aggressive for the rear, and even with stretched tires, it'd pop out so far that if you dropped it, you would no longer have a fender. The only way to do this is to do a custom widebody in the rear.
-Ken
kpeng is offline   Reply With Quote
Old 12-04-2006, 08:05 AM   #5
sna77
sna77's Avatar
My Ride: BMW
anyone know of any members that have done this?
Old 12-04-2006, 08:16 AM   #6
E92M
E92M's Avatar
My Ride: '08 ZCP M3 | '03 R6
I have 19" CSL 8.5" by 9.5" staggered. Running 265 in the rear and 235 up front.
Mmmhmmm,
-Chris
E92M is offline   Reply With Quote
Old 12-04-2006, 08:20 AM   #7
kpeng
Banned User
Mmmhmmm,
-Chris
He's talking about OEM CSL wheels. Not replicas.
Old 12-04-2006, 09:08 AM   #8
jiggynites
My Ride: 97EK 00 E46 03 745i
yeah there is no way in the world to fit them unless you do a wide rear fender. just take this for example
My car is dropped and I have rolled fenders. I tried to fit the oem M3 18x9 rim with 255/40/18 tire and the tire was right on the fender I had to lift the car up instantly. so I tried putting on a 235/40/18 on the rim and while it actually went in just barely touching the fender lips I know once I hit any little bump my rear fenders are gonna be destroyed so I took them off.
Now you want to tried this with the csl 19x9.5 def not a good idea.
you can fit 4 fronts 19x8.5 but the fronts dont curve inward like you want only the rears curve inward.
jiggynites is offline   Reply With Quote
Old 12-04-2006, 10:21 AM   #9
sna77
sna77's Avatar
My Ride: BMW
Just noticed my link up top was broken:
The fronts are 19 x 8, so I imagine fitting four of them fit no problem.
I didn't realize that the fronts do not curve inwards, which is why I'm requesting a pic of them. =)
Old 12-05-2006, 03:53 AM   #10
kameleon
My Ride: various
i think that 19x8 is a typo. on the epc it says theyre 8.5 not 8.
Old 12-05-2006, 07:17 AM   #11
sna77
sna77's Avatar
My Ride: BMW
No it doesn't?
http://www.realoem.com/bmw/showparts...=36&fg=15&hl=1
Old 12-05-2006, 09:59 AM   #12
albert1028
My Ride: 2002 330Xi
Originally Posted by sna77 View Post
Width of wheel is less of a concern, the front of the OEM 19's should fit, but the rear will not because off the offset, unless you want a wheel sticking way past hte fender well, if you notice that the offset of the M3 rear wheel is usually in the +20's.
Tirerack has a good article on offset if you want to read more:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
albert1028 is offline   Reply With Quote
Old 12-05-2006, 10:28 AM   #13
sna77
sna77's Avatar
My Ride: BMW
I understand offset. As Ive mentioned 3 times already, I'm thinking of using 4 front wheels, and going 19x8 all around. I simple want to see if ANYONE is running OEM CSLs on an e46 sedan now, and for a visual of how it looks
Old 12-06-2006, 02:24 AM   #14
kameleon
My Ride: various
thats strange. on the epc at my work (bmw ag owned dealer in australia) it states 8.5, ill double check this tomorow though.
if the offsets etc are the same as normal m3 19's i will try and fit these to the sedan and take some pics.
Old 12-06-2006, 07:09 AM   #15
sna77
sna77's Avatar
My Ride: BMW
Great, thanks!
Old 12-06-2006, 08:41 AM   #16
easyman
My Ride: MKV GTI 4 Door
im curious to see this setup. How are you going to get four fronts though?These wheels arent all that common. If you pull it off its going to look awesome.
2007 GTI 4 Door (MKV)- Current
2010 Acura TSX (cu2) - Retired
1987 BMW 325i (e30) Vert - Burned Down
2002 330i (e46) - Retired
ZPP - ZCW - ZSP - Nav - Bi-Xenon/85122+ - Mtech - 18" CSL - FSD's - 4300k Fogs-
Sig courtesy of fskarboe
easyman is offline   Reply With Quote
Old 12-06-2006, 09:11 AM   #17
sna77
sna77's Avatar
My Ride: BMW
They are $400 / each new. I'll just buy them new, and sell my OEM ZHP wheels
Old 12-06-2006, 11:02 AM   #18
easyman
i vote for chs... almost the same price and ... they are BBS!
Old 12-06-2006, 11:50 AM   #19
sna77
sna77's Avatar
My Ride: BMW
Well, they are both BBS.
I like the CSLs much better than the CHS'...
BBS CH:
OEM CSL:
Old 12-06-2006, 03:35 PM   #20
325rider
BBS CH>CSLs
