Thread Tools Search this Thread Rating: Thread Rating: 30 votes, 4.87 average. Display Modes
Old 04-24-2017, 10:20 AM   #341
gurov
My Ride: 2004 325XI Turbo
Send a message via AIM to gurov Send a message via MSN to gurov
getting rid of this thing. took all the useful bits off the car.
i want to sell this part, it's an aluminum intake manifold that fits M54 engine, 660cc injectors, fuel rail, and BMW 650i throttle body that just happens to fit.
anybody interested in the intake manifold ?
there's also a mishimoto expansion tank that i've taken off that will not be mostly useless to me, so i'd let that one go for cheap as well.
i've got few other bits (ebay turbo, oil feed line, bits of the intercooler piping)
2014 X1 - m-sport - stock
2004 325xi top mount turbo - megasquirt3 for engine, 5 speed swap. build thread
1994 supra MKIV - single 72mm - bc272 cams - super spec twin plate clutch - aem v2, 1000CC ID, dual denso pump, j&s ultrasafeguard
2004 SE-R SpecV turbo - megasquirt3 j&s ultrasafeguard - SOLD
gurov is offline   Reply With Quote
Old 04-25-2017, 12:25 PM   #342
gurov
oh yeah, i have the AC line replacement too, if someone wants that, it doesn't leak, and you can make whatever length hose you need.
Old 05-11-2017, 01:53 PM   #343
avantgarde
My Ride: 2001/2005 325xi A/M
was the MS43 ECU okay with running the 650i throttle body?
avantgarde is offline   Reply With Quote
Old 05-12-2017, 02:23 PM   #344
gurov
yeah, it plugged in, and i was able to rev the engine all the way to redline.
Old 05-12-2017, 04:24 PM   #345
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Hey gurov,
How did the Mishimoto expansion tank go, I have one at home, I have not put it on yet as was unsure of fitment - I have two of their thermostats that don't fit in the OEM thermostat housing.
Cheers.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 05-12-2017, 05:44 PM   #346
gurov
Originally Posted by cosmos328Ci View Post
Hey gurov,
Cheers.
the expansion tank fit fine. very little space in my setup, but good piece. the stock cooling system is quite good.
Old 05-12-2017, 11:21 PM   #347
cosmos328Ci
Thanks gurov.
I don't have a problem with the OEM system, polished aluminium looked nice.
Old 05-13-2017, 04:25 PM   #348
gurov
Thanks gurov.
I got stranded once in Manhattan because of the cracked expansion tank. This would have prevented that.
Old 05-13-2017, 04:51 PM   #349
cosmos328Ci
Mmmm. then would the radiator split at the plastic joins then.
Old 05-13-2017, 05:07 PM   #350
gurov
so in my setup, there was a full aluminum radiator.
M54 has way better cooling than my 2jz in the supra. I'm way jealous.
Old 05-14-2017, 02:51 AM   #351
cosmos328Ci
Do you think there was any cooling benefit from the full aluminium radiator?
I have one at home, not installed yet.
I hope you get a buyer for your aluminium M54 manifold.
Old 05-14-2017, 12:52 PM   #352
gurov
doubt there was much cooling benefit from the aluminum radiator for what i was doing, it was more of a peace of mind of having a full aluminum radiator. all the hoses fit.
the bigger radiator places the expansion tank WAY too close to the alternator pulley, so the aluminum expansion tank was obvious choice there.
