*OFFICIAL* BMW Diagnostic Scanner PA Soft 1.4 Thread - Page 133 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 871 votes, 4.97 average.
Old 03-01-2017, 12:01 PM   #2641
LocoCan
My Ride: 2000 323i sedan
Originally Posted by illicitstylz View Post
Hey Loco,
Thanks for the heads up. I already ordered the plug adapter (20pin to 16 pin). Can you clarify how you jumped the pins on the adapter?
Sent from my ONE A2005 using E46Fanatics mobile app
In the pictures on the linked post
http://forum.e46fanatics.com/showpos...postcount=2298
I hope that is helpful.
LocoCan is offline   Reply With Quote
Old 03-08-2017, 11:47 AM   #2642
Rooky1
My Ride: 2004 e46 316i 1.8
Hey guys
My PA soft has the bridge on 7 &8 already. Did I read somewhere on this thread that 1 & 2 need to be bridged as well?
Rooky1 is offline   Reply With Quote
Old 03-23-2017, 12:11 AM   #2643
Peterthenotsogreat
My Ride: E39 m5
Frustrated
So I've read through 50-60 pages of this topic and I still can't get this thing to work!!! Ike and ews errors nothing reading at all!
E39 m5 2000
Used 20 pin adapter
Used xp computer
Pin 7-8 jumped
But I don't have the typical version of the scanner! Mine isn't the solid board but rather wired soldered to the pins that run to a board.
I'm so confused and desperate to get this working!!!
Peterthenotsogreat is offline   Reply With Quote
Old 03-25-2017, 11:33 AM   #2644
cscracker
My Ride: 2004 330Xi
I have exactly the same problem as Peterthenotsogreat, my adapter lights up as it's supposed to on both the OBD and USB sides, recognizes on the computer fine, but connection always fails. Inside, my adapter has wires on a plug to the PCB. 7&8 are on the same wire (therefore bridged) and 1&2 are not connected to anything. I tried bridging them together but it made no difference.
Does anyone know if the scanner requires USB 2.0? I'm using an old T23 which only has 1.1, and I'm thinking that may be the issue.
cscracker is offline   Reply With Quote
Old 05-06-2017, 03:29 PM   #2645
ss2115
My Ride: E39 530i Sportswagon
PA Soft versions
Hi.
I've not an E46. But I'm new to PASoft and you guys in this thread are way ahead of anyone else I can find.
I have a late 2002/2003 spec E39 Sportswagon.
I've used NCS Expert with the dummies addition but its still a bit difficult to use.
I recently purchased an eBay copy of PA Soft with the 1.4 OBDII connector. It connects up quite okay with pins 7 & 8 shorted together.
However, in my research i was lead to believe that this software could synchronize the cars clock with the laptop time but I cannot find where this happens.
Also - i found that a couple of the modules show different mileage to the dashboard. Nothing drastic - all either side by only 100 - 300 different. How important is this? Should they all be identical? And if I wish to make them all identical, should I choose the dashboard display or is there one particular module that is the "master" that the others should be the same?
Finally - I wish to have visual confirmation of locking and unlocking with the key FOBs. But even though i tick the boxes for both visual and audible and write to the module, it doesn't work. I tried this in NCS as well. What is wrong here? Can anyone suggest any other settings I should have to make these work please?
The version I received with the adapter is 1.4.0.07. It seems to be the most common version to find on the internet.
But was there any versions after that? I seem to remember 1.4.0.09 was the final version but I cannot find it anywhere.
Thanks in advance.
ss2115 is offline   Reply With Quote
Old 05-16-2017, 09:29 PM   #2646
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
Anyone have these show up in PA Soft and know what they're about?
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 05-16-2017, 09:35 PM   #2647
bimmernut3
My Ride: '05 330cic, '01 540i
These are past not present code that have been corrected some how. Clear the error & see if they return
One looks like the 2nd air pump & one looks like drivers mirror heater may be dead.
Sent from my SM-G920R4 using E46Fanatics mobile app
'05 330ci
[IMG][/IMG]
bimmernut3 is offline   Reply With Quote
Old 05-16-2017, 09:46 PM   #2648
lllRazorlll
Modded ///Member
My Ride: '00 328i
These are after errors are cleared
Old 05-17-2017, 06:22 AM   #2649
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
Except the first one. Drivers mirror. That's the little motor that adjusts the mirror. I get that error but it still works. I think the their is corrosion on the terminals that increases resistance and gives the error. Does your mirror adjustment work?
BMW-North is offline   Reply With Quote
Old 05-17-2017, 07:59 AM   #2650
lllRazorlll
Modded ///Member
My Ride: '00 328i
The motor works but does not function the way its supposed to when putting the car in reverse. Sometimes when going from reverse to park the mirror tilts down and stays stuck that way
Old 05-17-2017, 11:44 AM   #2651
BMW-North
Only the passenger mirror tilts for reverse (and only when the switch for that mirror is active) Your error is for the driver mirror? As I said, I see that error periodically but my mirror functions ok.
Old 05-17-2017, 12:40 PM   #2652
zander271
My Ride: 6spd ZHP/5sp XI
Razor I had the same problem. It went away when I replaced my 8.5 year old battery. If you battery is new the ribbon that connects to the driver side mirror motor is bad and needs to be replaced most likely.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 05-17-2017, 01:41 PM   #2653
lllRazorlll
Modded ///Member
My Ride: '00 328i
This is for the passenger-side mirror.
Battery was replaced a couple months ago. I suspected the mirror motor or cable to be faulty as I find the tilt down feature very useful
Old 05-19-2017, 12:57 AM   #2654
Dogthebountyhunter
My Ride: 02 325xi
Stupid questions for you guys. I downloaded the pa soft demo a few days ago and it reads codes and shadow codes just fine on my 02 325xi. Today I tried to read my uncles 2000 323ci with ms42 and it told me how many codes it had, but I couldn't see them unless I bought the full version. What gives?? Also are all you guys using the demo version? I find it hard to believe that the full version is only available for 600 bucks
Dogthebountyhunter is offline   Reply With Quote
Old 05-19-2017, 11:46 AM   #2655
ChampionC
My Ride: 318Ci Convertible
I got the full thing on a mini CD with the adapter i bought on eBay.
Sent from my LG-D855 using Tapatalk
ChampionC is offline   Reply With Quote
Old 05-19-2017, 01:02 PM   #2656
prowl583
My Ride: 2002 325CI
Hello all
I just got mine and I cant get the software and I am having a hell of a time with this thing and all I wait to do is get the convertible top to be a one touch function. does any one have the drivers for window 7 they can give me or is in Indianapolis and can help
thank you all
prowl583 is offline   Reply With Quote
Old 05-19-2017, 01:41 PM   #2657
LocoCan
BMW PA Soft 1.4.0.9
In this thread are the chip drivers
http://forum.e46fanatics.com/showthr...966&highlight=
Follow the instructions in the 1st post to install the drivers.
The software can be found
https://www.xcar360.com/bmw-scanner-...de-reader.html
look below the picture there is an UPDATE and SUPPORT tab. Click the tab and a link should show up.
You could search google
http://lmgtfy.com/?q=BMW-Scanner-1.4.0.zip
Good Luck
Old 05-20-2017, 03:45 AM   #2658
ChampionC
Good Luck
The most important thing that people must realise and understand is that you cannot use any ordinary obdii cable nor can you use the obdii inpa cable either.
The PASoft cable is recognised as a different type of device in Windows and will not be seen as a COM Port. If it does get listed as a Com port, you have the wrong drivers installed.
Old 05-22-2017, 02:19 AM   #2659
PhantomX
My Ride: E46 M3
Is it possible to bleed the system (slave cylinder on SMG) using this OBD reader?
-1999 BMW M3 Convertible 6SP(Sold)
-2002 BMW M3 Coupe SMG(Current DD)
-2002 BMW M3 Convertible 6SP(Totaled by Red Light runner....that Bastard)
-2004 BMW 325CI Coupe (Sold)
-2003 CBR 600RR (Sold)
-1995 Acura Integra Turbo (Sold)
-1989 BMW E30 (Totaled by sis)
Instagram | Snapchat @ TwinzTurbo
PhantomX is offline   Reply With Quote
Old 06-10-2017, 03:36 PM   #2660
cxvarol
My Ride: Searching...
Hi all,
I have just got the hardware and software from an ebay seller located in CA. I installed the software to an old XP machine. After I plug the USB cable, "found new hardware" wizard popped and did the driver update according to instructions. However, I never see BMW Scanner 1.4 under Device Manager and also when I try to run the software "BMW Scanner Adapter is not plugged in" message comes with yellow light. Dongle is connected to the OBD and to the computer. Dongle provides solid green light. I'm puzzled. Can it be an issue with the dongle? What else can be done?
cxvarol is offline   Reply With Quote
1.4, airbag, bmw scanner, diagnostic tool, error message, pa soft, scanner, srs
Rate This Thread
