ESS TS3 Supercharger for 328. 398.5 whp - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-27-2015, 03:24 AM   #61
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Originally Posted by Davconelectric View Post
It's getting there, Basically going ts3 with a full freshen up. I'll do an engine build thread once it's in and running, but it will have CP Pistons and SP Rods. I Will be keeping limit at 7200rpm.
Here is a selection of photos for your entertainment
Attachment 598632
Attachment 598633Attachment 598634Attachment 598635Attachment 598636
Nice pics.
Like your new OFH. What brand is it? or is it a S54/S52?
Can you weigh your rods and pistons, Please.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 04-27-2015, 04:28 AM   #62
Davconelectric
My Ride: 2 dog powered sled
Ofh is s54. Sorry rods and Pistons are with block at machine shop for blue printing and balancing
Davconelectric is offline   Reply With Quote
Old 04-27-2015, 06:36 AM   #63
cosmos328Ci
Kool.
Will you document the fitment of your hose route and alternator fitment?
Will you run a thermostat?
Definitely looks the part.
Looking forward to the end results.
Old 04-27-2015, 07:58 AM   #64
paraklas
My Ride: ESS TS2 320ci
Originally Posted by cosmos328Ci View Post
It has more tension for the cam chain. Keeps the cam chain at a more constant tension to keep the cams in relation to the crank in better alignment, especially good for high RPM.
My M54 cam chain tensioner had very little resistance compared to the S54 cam chain tensioner.
Do you have the part number of the S54 tensioner?
paraklas is online now   Reply With Quote
Old 04-27-2015, 01:35 PM   #65
Rob43
My Ride: 03 331Ci 5spd R1200R
S54 tensioner is #11317838675
EDIT: Your in luck, they use to sell for about $250 all day long, but now I'm seeing them at about $200.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 04-28-2015, 12:54 AM   #66
cosmos328Ci
Rob43
Thanks Rob43.
Old 05-03-2015, 11:28 AM   #67
paraklas
Rob43
http://www.ebay.com/itm/BMW-E46-M3-3.../271743496773?
$151.
I asked them what they mean by "German supplier" and I got this reply:
"It's made by Ruville in Hamburg and they are original equipment.."
Seems like a good option (and cheaper)
Old 05-03-2015, 07:15 PM   #68
Davconelectric
Original equipment for what?
Old 05-05-2015, 07:20 AM   #69
paraklas
Probably for tensioners and stuff. They're part of Schaeffler group where Ina / Luk / f.a.g also belong. All 3 brands are found in BMWs leaving the factory. That said, I managed to source a genuine S54 tensioner (80k miles, used) for peanuts which I will be installing soon
Old 05-05-2015, 08:41 AM   #70
cosmos328Ci
Nice work.
Compare both for compression Resistance.
Let us know how it feels once installed.
All the best.
Old 05-05-2015, 02:55 PM   #71
Davew
My Ride: 2004 330ci Msport
Nice work.
All the best.
Spring tension uninstalled isn't relative, they are hydraulic
Davew is offline   Reply With Quote
Old 05-10-2015, 04:57 AM   #72
cosmos328Ci
Increased 7000 RPM limit to 7200 RPM limit
Increased 7000 RPM limit to 7200 RPM limit last Tue.
Got an extra 1.0 - 1.5 psi. LOL
Hope fully I will have a Dyno next week, just waiting on other things before I can finalise.
Old 05-10-2015, 06:05 AM   #73
Davew
Get the headers on and get a bigger exhaust already. That should give you a bigger increase in power and torque than any more boost you gain.
Old 05-10-2015, 09:17 AM   #74
cosmos328Ci
LOL, I was not looking for extra boost... LOL - If I wanted more boost I would put on my 6.8 inch ATI Dampner.
The 7200 RPM allows me to change gear at 7000 RPM without hitting the rev limiter.
The last few months I have been away a lot and had very little time for major work on my car, in the last couple of months I have probably spent about eight hours on my car.
So... my next major work will be, fit the eBay Headers and ad another 2.5 inch pipe with a 100CPSI cat like the one I am currently running. This will go straight upto my rear rear muffler which already has 2x 2.5 inch inlets for the 2x 2.5 inch exhaust pipes to fit to. Then a tune and re-dyno.
On the same Dyno Dynamic dyno as my last dynos...
- What do ya recon... an extra 20 whp? (I am hoping this will be my minimum)
Old 05-10-2015, 09:41 AM   #75
jdjg
My Ride: e39, m52tub30
why not 3" exhaust?
jdjg is offline   Reply With Quote
Old 05-10-2015, 11:29 AM   #76
cosmos328Ci
Originally Posted by jdjg View Post
why not 3" exhaust?
Hey jdjg,
How is ya beast going?
Well... If I was going to change my exhaust system to another single pipe then it would only be a 3.5 inch single system - based on my internet trolling.
3.5 inch single would reduce my clearance even more and I like my ride height as it is...
So... 2x 2.5 inch pipes would give me the best of both worlds (clearance and extra performance).
Old 05-10-2015, 04:37 PM   #77
Davconelectric
Why not install exhaust and ati before going back on dyno?
Old 05-10-2015, 05:11 PM   #78
cosmos328Ci
The ATI may put the boost around 28 psi, not ready to muck around with the engine yet.
I would at least have put a bigger SC pulley on to keep the boost down but the under drive pullies really would not be under drive any more.
I will have to look into having the ATI machined down if possible.
Old 05-13-2015, 12:37 AM   #79
paraklas
Nice work.
All the best.
Will do both, it came today so I will do a comparison/install this Saturday in new thread so that I don't pollute yours . Need to clean it and re-oil it as it is used, but for $50, no big deal!
Old 05-13-2015, 01:44 AM   #80
cosmos328Ci
You will not be polluting my thread with good info.
$50, good buy.
All the best.
