Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 2.00 average. Display Modes
Old 04-30-2014, 07:16 PM   #1
Boolala
My Ride: 2001 325xi
Pelican order--questions
So below is what I had Pelican work up for me today. 3 questions.
First--CCV...should I just change it and if so, is it a complete PITA to replace? (don't want to change it just to change it)
Second--Seems Pelican's DISA is $100 more than OEMBimmerparts.com DISA...how can this be (both listed as OEM).
Last questions is..I thought I read somewhere on here that when changing the valve cover gasket you should NEVER use anything but the OEM nut seals which are $2.00 a piece--true?
*Also VANOS oil line to this list (just has oil around the fitting like most do).
ANYTHING ELSE YOU CAN THINK OF SINCE I WILL HAVE THE ENTIRE THING TORN APART--maybe the oil filter housing gasket (even though I just had the oil changed 2000 miles ago). I will change the complete cooling system late this summer as well.
The following items are being assembled and processed:
11-61-7-544-806-M9 Adjusting Unit for Intake Manifold, DISA Valve
1 $382.75
$382.75
11-12-9-070-990-M30 Valve Cover Gasket Set also use 11-12-1-437-395-M208 valve cover nut seals
1 $23.75
$23.75
11-12-1-437-395-M30 Valve Cover Nut Seal, as needed
15 $0.75
$11.25
13-32-7-512-019-M67 Fuel Filter, 325i/Ci/iC/Xi MODELS WITH M54 ENGINES ONLY ;2001-05, 330i/Ci/iC/Xi 2001-05
1 $60.25
$60.25
13-54-1-705-209-M9 Intake Boot, Throttle Housing to Mass Air Meter, E46 323i/Ci/Ci Conv, 325i/Ci/Xi/Xi Wagon, 328i/Ci; Z3 2.5i/2.8i from 9/98
1 $22.00
$22.00
13-54-1-435-627-M9 Intake Boot "Tube Elbow" Throttle Housing to Air Boot (Also use 13-54-1-435-626 ring and 07-12-9-952-131 clamp)
1 $18.00
$18.00
13-54-7-504-728-M17 Throttle Housing Gasket
1 $5.75
$5.75
11-61-7-501-566-M9 Ventilation Valve, Pressure Regulating Valve - Oil Separator
1 $70.25
$70.25
11-61-1-432-559-M9 Ventilation Pipe, Valve Cover to Pressure Regulating Valve
1 $30.25
$30.25
11-61-7-504-535-M9 Connecting Hose from Pressure Regulating Valve
1 $42.50
$42.50
11-61-7-504-536-M9 Ventilation Pipe, Return Pipe from Connecting Hose
1 $33.25
$33.25
11-15-7-532-649-M9 Ventilation Hose, Pressure Regulating Valve to Oil Dip Stick Tube
1 $24.75
$24.75
32-41-1-128-333-M103 Reservoir Cap Seal for Power Steering Fluid Container
1 $3.00
$3.00
Boolala is offline   Reply With Quote
Old 04-30-2014, 08:21 PM   #2
mr ilia
My Ride: 98 323is, 04 325ic
For the part number 11-61-7-544-806 @ Pelican they list to carry several brands with prices of $223 for Vaico and Dorman to $382 for the Geniune BMW.
mr ilia is offline   Reply With Quote
Old 04-30-2014, 09:02 PM   #3
sneakyRedPanda
My Ride: 2004 325i
Send a message via Skype™ to sneakyRedPanda
Valve cover gasket, go OEM. Only OEM.
The oil filter housing gasket can mean one of two things, the O-ring that sits between the filter tube and the cap for the filter, or the actual gasket that sits against the engine block where it connects with the very bottom part of the oil filter. If that hasn't been replaced, you'll want to replace it as well. The O-ring will come with every OEM filter you buy, so you should always change that every time you change your oil.
If the DISA is ~100 difference and you're sure they're both OEM, go the cheaper one. I've seen bigger discounts on OEM parts than $100 for various parts.
Make sure you check your front control arm bushings.
Nexus 7 In-Dash DIY /// 2004 325i /// Titansilber /// Style 72 /// Angel Eyes, HID Projectors
sneakyRedPanda is offline   Reply With Quote
Old 05-03-2014, 04:29 AM   #4
dznuts007
My Ride: 2001 325i Sedan
Yes, change your CCV and related hoses. I have a 2001 and changed my CCV system last year. It basically crumbled apart. Oh yeah, and it is a PITA, but it's not too bad. Just don't give up easily. Also watch alot of videos. Otto's BavAuto CCV video is pretty good to prepare yourself on "blindly" assembling the part under the manifold
dznuts007 is offline   Reply With Quote
Old 05-03-2014, 04:40 AM   #5
wapner
My Ride: 05 Xi
Stock the fridge with beer for the CCV. That one hose almost made me start smokin again.
wapner is offline   Reply With Quote
Old 05-03-2014, 04:53 AM   #6
dznuts007
I just finished removing my intake manifold and replacing the gasket today. The CCV would be MUCH easier if you take off the intake manifold, but would be much more work since you have to take off a bunch of lines. If you want to go as far as taking off your intake manifold, then by all means do it. I found a bunch of cracked hoses on Part #5 (one was cracked and the other one completely broke and fell off) These were probably contributing to my increased LTFT over the past few months. Would have never found it without taking off the intake manifold
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
