Old 02-16-2017, 07:03 PM   #1
hagzflow
My Ride: 2003 BMW 330i
Shifter was doing something weird
So coming home from work, I noticed that the shifter was leaning slightly towards the right but was not in gear. And when driving through the gears, the shifter naturally wanted to go into 5th instead of 3rd. I messed around with it for a little moving it through the gears while idling, and eventually it sat back in it's normal position. Any idea what this could be?
hagzflow is offline   Reply With Quote
Old 02-16-2017, 07:12 PM   #2
illicitstylz
My Ride: 2000 328ci
I believe it's the detent pin? Search it up, it's been discussed a few times. Remedies include new trans fluid or taking apart the clutch to replace the part
Sent from my ONE A2005 using E46Fanatics mobile app
illicitstylz is offline   Reply With Quote
Old 02-16-2017, 08:35 PM   #3
hagzflow
Thanks! After reading some of the other cases, does indeed seem like the detent pin. I don't have the time to drop the tranny right now, so might change the tranny fluid for the time being until I have some free time/need to do the clutch.
Old 02-17-2017, 07:46 AM   #4
randy72877
My Ride: 01 330 sport 5m sil/
Mine does it too only when it's cold outside for 5-10 minutes. Search 5th gear lean. I plan on fixing mine when I replace the original clutch
Sent from my SAMSUNG-SM-G870A using Tapatalk
randy72877 is offline   Reply With Quote
Old 02-17-2017, 08:02 AM   #5
hagzflow
Yeah it seems like after about 5 minutes of driving it cleared up
Old 02-17-2017, 08:46 AM   #6
markusmarkus
My Ride: 2001 330Ci
I don't think it's a detent spring as they are present only in the reverse shifter path and 5th gear shifter path. They have nothing to do with the clutch but are on either side of the tranny. Check your engine and tranny mounts first.
Old 02-17-2017, 02:04 PM   #7
randy72877
The detent pin for 5th gear binds in the bore. Once the transmission gets warm slightly it releases and the shifter stays in the center. Bmw has a tsb/sib from back when the cars were new about the problem.
Old 02-17-2017, 02:06 PM   #8
randy72877
They are on the top of the trans so you have to remove it for access. They come out from the outside of the transmission so you don't need to open the case.
