E46 Convertible
Old 08-05-2013, 07:26 PM   #1
hallj2006
My Ride: 2001 330ci dinan
2001 330ci convertable top not moving no motor sounds
Hello- looked over the threads - not all cause there are a lot...
But could not find this problem.
indicator light flashing - no motor work at all
boot extender is in place
top is tightened down in "top up" position by manual
and the answer is? Help appreciated....
Love the forum - and want to keep mine going to 200k (105k now)
hallj2006 is offline   Reply With Quote
Old 08-05-2013, 08:42 PM   #2
avneet
My Ride: 2001 330ci Vert
When you press the open top botton, nothing at all happens but flashing light? So top doesn't even move a tiny bit up?
avneet is offline   Reply With Quote
Old 08-05-2013, 09:21 PM   #3
hallj2006
Top not moving
Correct light flashes - no movement
Old 08-05-2013, 09:37 PM   #4
avneet
Definitely take a look at this thread http://forum.e46fanatics.com/showthread.php?t=854059
Hopefully it's as simple as the broken wire harness. I was going to wonder if it was the latch, but you aren't hearing anything. Sounds like nothing moves at all, which makes me think of the wire harness. Taylor will have better info.
Old 08-05-2013, 10:02 PM   #5
hallj2006
Thanks. Would you take this to the dealer?
Old 08-06-2013, 12:00 AM   #6
taylor192
My Ride: 2003.5 M3
Re: 2001 330ci convertable top not moving no motor sounds
Only if you're not capable of fixing a broken wire. If no broken wires have a shop (any BMW shop, not just the dealer) read the CVM codes. The flashing light indicates a stored code, and that code will help a ton to figure out what's wrong. Shop should charge 1/2hr labour to read the codes, well worth the expense.
Old 08-06-2013, 08:43 AM   #7
dknightd
My Ride: 2002 330 cic
My guess would be the car does not think the storage area is properly open, or the car thinks the trunk is open.
dknightd is online now   Reply With Quote
Old 08-06-2013, 11:17 AM   #8
taylor192
My Ride: 2003.5 M3
Good catch! yet...
1. The light is typically yellow, not flashing red, if the the storage area is not fully down.
2. The dash usually displays the trunk is open if the trunk wiring is the issue.
Both are definitely worth checking though just to be sure.
Old 08-06-2013, 11:53 AM   #9
dknightd
didn't even know that light did yellow - learn something new every day - useful info - thanks
Old 08-06-2013, 02:47 PM   #10
Vandyinc
My Ride: 2000 323 Cic
OP.. Do your windows lower a few inches when you press the Top Down button?
Done:H&R Sport Springs Koni STR Shocks & Struts, Lower Control arms, FCABs, OFHG, CCV, Cooling Sytem refresh, Coolantsnitch. Yet to do:Transmission fluid & filter, VCG
Vandyinc is offline   Reply With Quote
Old 08-09-2013, 04:02 AM   #11
mkdonald
My Ride: 330 Cic
This may be too stupid simple, but mine experienced this and I thought I checked all the fuses. Took it to the dealer and it ended up being a fuse somewhere in the middle of the fuse box.
mkdonald is offline   Reply With Quote
Old 08-09-2013, 10:20 AM   #12
fmzip
My Ride: '08 328xi / '01 530i
Did you check for broken wires
http://forum.e46fanatics.com/showthread.php?t=790169
fmzip is offline   Reply With Quote
Old 08-25-2013, 11:46 PM   #13
Wildwon325
My Ride: 2003 e46 vert
No motion or sound
Mine did this today, worked fine and today nothing but the yellow light on button.
Wildwon325 is offline   Reply With Quote
Old 08-26-2013, 12:13 AM   #14
taylor192
My Ride: 2003.5 M3
Yellow light means the storage compartment is not fully down. If it is then the sensor might be sticking. Try opening and closing the storage compartment to get the sensor to work. If that doesn't work then the sensor might need cleaning, might be bad, or I've read people having found broken wires in the trunk.
Old 08-26-2013, 12:48 AM   #15
Wildwon325
Don't want to sound dumb but do I need to lower the top manually and then unlock the storage compartment?
Old 08-27-2013, 12:15 AM   #16
taylor192
My Ride: 2003.5 M3
Just fiddle with the storage compartment. Open close it a few times and hope the sensor resets, otherwise you'll have to investigate why the sensor failed.
Old 08-27-2013, 11:53 AM   #17
billyp
My Ride: alpina b3s vert 3.4
I have did this also in the past and it worked for me, also told a fellow vert owner about this and worked for him, so as above open and close the storage compartment and hopefully it will work again
billyp is offline   Reply With Quote
Old 11-17-2013, 02:26 PM   #18
hallj2006
Looking for mechanic
I am in Concord CA. And I am looking for a mechanic in the east bay. I have taken my 2001 330ci to the dealership up to now 103k. Just can't see the value anymore.
Needs tune up and the top issue on original thread dealt with. Any suggestions please let me know.
Thanks,
