Old 08-08-2013, 08:57 AM   #1
bmwci323
My Ride: 00 323ci
E46 p0155, o2 changed. Code still apparent
Hey guys,
My car threw a p0155 o2 heater circuit malfunction(bank 2, sensor 1) code a few months ago.
Yes, Iam finally dealing with it now.
So, which seemed obvious.. I changed the bank 2 precast sensor. Cleared the code , started thee motor and the code was back, I was a little shocked , so I even did it again. Same outcome..
Seeing as though the o2 sensors wire runs behind the motor, could it be loose on the other end? Or make ripped where I can't see it?
Any help appreciated!
bmwci323 is offline   Reply With Quote
Old 08-08-2013, 09:12 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Sometimes these codes can be a bit misleading.
First you need to check fuses, not sure if there are individual fuses for Heated O2 sensors or a single fuse.
Then you need to test to see if you actually have power at the O2 sensor connector.
You can also verify that the O2 sensor heater has continuity. Most sensors are 4 wire sensors, 2 wires are the sensor and 2 wires are for the heater. You can search around and see what colors are typically uses for the heater circuit.
What brand sensor did you purchase? I always use Bosch sensors and have very good luck with them.
Old 08-08-2013, 09:31 AM   #3
bmwci323
My Ride: 00 323ci
I agree with you ib misleading, usually.
I'll see what I have for fuses.
I have the proper voltage / ohmeter testing equipment, so would I want to unplug the harness and touch the prongs to each socket? (for the harness that leads to the DME , not the o2 sensor)
The new sensor was also Bosch !
Old 08-08-2013, 11:34 AM   #4
GuiltySpark
My Ride: 02 325xi
I had to clear the code after replacing it, no lights or problems 1.5k later. Post cat btw. Lol, never mind read your entire post, I'm with the other guys, make sure the circuit itself isn't toast, because no matter how many sensors you put in, nada.
GuiltySpark is offline   Reply With Quote
Old 08-08-2013, 02:01 PM   #5
bmwci323
My Ride: 00 323ci
The heater wireing circuit?
Old 08-18-2013, 04:13 PM   #6
bmwci323
My Ride: 00 323ci
I definitely know it is the o2 sensor harness for sure.
I even switched around the harnesses and the code remained the same for that harness..
I have chased the wiring all the way to the ecu.
There are various small burn marks, but none penetrated the insulation..
Iam unsure where to go from here? Is there a relay or fuse for a single 02 sensor? I couldn't find anything online that suggested it.
Old 08-18-2013, 04:35 PM   #7
jfoj
Possible valve cover pinch damage? This seems to be a common problem at times.
The heater circuit is only 2 wires per sensor, ground and positive feed.
Problem is the O2 sensor heaters do not run all the time.
Luckily since you have 2 banks, you can compare readings and behavior with the good bank and maybe figure out what is going on?
Old 08-18-2013, 04:58 PM   #8
bmwci323
My Ride: 00 323ci
Not sure about the pinch your talking about?
I can chase the wire freely all the way to the black box on the driver side.
I was tried checking the prongs on the harness with a voltmeter/ohmeter. But I don't know what to look for, nothing was coming up.
Do I have to wait until the motor is at running temp for any readings?
Old 08-19-2013, 05:47 AM   #9
jfoj
Heat O2 sensors work mainly at cold start up. There has been some discussion that they may turn on at extended idle under certain conditions, but do not bank on that.
So you likely will see the O2 heater on for only the first 1-3 minutes at cold start.
You could measure the good side to see if what pins have 12 Volt output and then compare to the bad side.
I have read where sometimes people replacing the valve cover gasket have pinched the O2 sensor wires under the valve cover when reinstalling the valve cover. This can damage the insulation. I have also heard problems where mice or rodents have chewed the wiring as well on cars.
Sounds like you have a break in the heated O2 wiring for the bank than it throwing the code?
Old 08-23-2013, 08:33 PM   #10
bmwci323
My Ride: 00 323ci
*** PrObLEm SOLVED!!***
I ended up cutting the heat insulation wrapped around all the wires, and I found all of the wires burnt together , and one of them cut .
I fixed the wire, code gone. And for good!
