E46 Xi Forum
Old 08-10-2013, 12:12 AM   #1
tanayast
My Ride: 2001 325xi
Another Front Axle DIY (2001 325xi)
First of all, I want to THANK YOU for the E46F members for their posts on the front axle replacements. It helped me tons doing mine.
I know there are a lot of good DIY already in this forum for Front Axle replacement, but I though I'd share my front axle replacement experience with you all. One more DIY with pics can't hurt, right? Plus it may helped someone else by providing more reference....
I ended up buying the GKN Loebro axles from Pelican. They're a bit more expensive than the Cardone reman ones, but still cheaper than getting them from BMW dealer.
What started this is the usual: Outer boots are ripped, grease all over the place, and clicking noise when turning. On my pics below, you'll see my brakes are removed and the car is entirely on jack stands because I ended up replacing all 4brake rotors and pads while I'm at it.
Some of the pics below are taken outside the actual car for clarity.
(1) Make sure the car is securely rested on Jack Stands. If possible, soak all the threads with PB Blaster the night before, it will make the job much easier
Remove the plastic undercarriage shields.
(2) As mentioned above, I removed all my brakes (although I don't know if it's necessary to do so if you're not doing brake job). Make sure the calipers are zip tied to the springs and not hanged on the brake line.
(3) I started removing the tie rod end on the passenger side, but later found out you DON'T NEED to remove the tie rod.
(4) Remove the sway bar link from the strut. Then separate the strut from the steering knuckle by removing the strut bolt and hit the steering knuckle with a hammer downward.
(5) To remove the Axle Nut: Hit the dimples on the nut using punch and hammer so it can turn. Afterward, I just hit it a couple times with an electric impact (while my other hand is holding the axle from behind the knuckle to minimize the axle spinning). A couple hits with impacts and the Axle Nut came out.
(6) To separate the outer CV from the hub: I rented an Axle Pusher tool from a local part store. Just bolt the flange on the hub using 3 lug bolts and tighted the center rod until it pushed the axle out.
(7) Now the fun part. To remove the inner CV, crawl under the car (again, please make sure the car is securely supported by jack stands) and using a punch or chisel (I have one from Harbor Freight with the rubber 'handle' that works great), hit the inner CV out from the diff. You can tell from the pics below where I hit it and how to access it from under the car:
This is where you hit:
What I did was hit it like 10x, do a quater turn, hit it another 10x, keep doing it and eventually the axle will pop out from the diff. Make sure the clip is out with the axle on the inner splines. Same procedure for both sides.
(8) Remove the output axle seals and replace with new ones. I got them from the BMW dealer, I think they're around $17 each. I used a round stock that fits inside the red plastic holder and tap them into place (see pic where I tapped them). Remove the red plastic holder afterward. Apply a little grease on the ID of the seals.
(9) While I'm at it, I drained both front and rear diff fluids (MAKE SURE you can open the fill plug prior to opening the drain plug - sorry to state the obvious ). For the rear, I re filled it up right away using transfer pump and closed the fill plug. For the front, wait to refill until both axles are in.
(10) A lot of people said reuse the old axle retaining C clip. I removed the old clips from the old axles and compared them with the new GKN clips. They are exactly the same size and shape, so I just used the new clips. But if you run into issue, you may want to try using the old ones. Make sure the clip opening is up top (12 o'clock)
(11) Driver's side (LHS) - Apply a little grease or anti-seize on the splines. Push the inner splines unto the diff and make sure they are aligned. Then using the dimples on the inner side of the CV, tap the axle into the diff (I used the HF chisel mentioned above). This is where you hit it:
(12) Passenger Side (RHS) - Apply a little grease or anti-seize on the splines. The key is to make sure it goes perfectly straight and aligned. What I did is cut a piece of 1x4 and placed it above the frame to support the axle, that way it's straight and not tilted down.
You can fine tune the height of the support by 'shimming' the 1x4 using piece of cardboard. Let the axle rest above the 1x4 then push in until the splies are aligned. After than, tap it using the same method as the driver's side discussed above. You may need to move the axle left / right to find the sweet spot, but once it's aligned you'll know as it will push in easier.
I actually had a hard time started it, so I did this (*but I don't recommend it unless you're desperate... like I was....)
Get a long 2x4, and rest it on the part of the inner boot that rested on the piece of the inner joint. Place a towel or rag in between the 2x4 and the boot to avoid damage AND if possible, round off the edges of the 2x4 a bit. Again, only do this if you absolutely can't push the axle in any other way AFTER you made sure they go in straight:
(13) Refill the front diff oil (don't forget!! )
(14) To insert the outer splies into the hub, I use a some anti-seize on the splines and get them aligned. After that I used a slide hammer to push in the hub. Just bolt the flange on the hub using the lug bolts and hit the hub with a slide hammer until enough thread is visible to start the nut (at least 3 turns).
(15) After that, install the nut and zap it using an impact until the front face of the thread is pretty much even with the nut and it won't move any more.
Do NOT stake the nut yet.
(16) Reinstall the strut, sway bar link, and tie rod (if you removed tem, but again, you don't need to).
(17) In my case, I reinstalled the brakes. Have someone hold the brakes and torque the axle nut to ~220 ft-lbs. After that stake the nut using a punch / chisel to prevent it from backing out.
(18) Reinstall tires, reinstall under carriage shields, lower the car, and torque the lugs.
(19) Test drive the car and listen / feel for anything out of place. If all goes right you shouldn't have any problem.
Sorry if it's a bit long and redundant, but I just feel like I should give back to this community that helped me so much already
Let me know if I missed anything and feel free to PM me with any questions.
Good Luck
tanayast is offline   Reply With Quote
Old 08-10-2013, 12:44 AM   #2
Shadow330xi
My Ride: 2001 Red 330xi
Awesome write up, definitely will be looking at this when I do mine! Thanks for taking the time!
Shadow330xi is offline   Reply With Quote
Old 08-10-2013, 04:01 AM   #3
dgknight
My Ride: 02 325xi 5sp 120k
+1 thanks!
dgknight is offline   Reply With Quote
Old 08-10-2013, 07:42 AM   #4
Kubica
My Ride: 2003 325xi
This is good.
I believe you must either release the bottom of the strut or control arm/tie-rod to get an axle out.
Old 08-19-2013, 09:58 PM   #5
xi_ter
My Ride: 2003 325xi
Good to see how to use this equipment for the axle replacement.
Old 08-19-2013, 10:49 PM   #6
bilwltr5
My Ride: 2004 325 xi
Will be book marking this thread for future use. Its always nice to know the reference you need is readily available.
bilwltr5 is offline   Reply With Quote
Old 08-20-2013, 12:40 PM   #7
xi-xi
My Ride: 2002 330xi
When I did this I had the lower control arm out so it wasn't necessary to remove the strut from the steering knuckle--it was easy to push it out of the way to get the axle out, even with the tie-rod still connected. I've read how a lot of people have to pound the axle to get it loose, but mine popped out easily. Went in easy, too. I used a new Cardone axle...so far, so good.
xi-xi is offline   Reply With Quote
Old 08-20-2013, 01:28 PM   #8
GSherbs
My Ride: 2002 330 xi
Very nice!
Appreciate the write up!
GSherbs is offline   Reply With Quote
Old 08-20-2013, 02:54 PM   #9
TiAgXi
My Ride: e46xi, e46m
Nice write up.
A helpful method for removing the axles from the diff is to get a large diameter circle clamp to fasten around the axle in order to have a different point to place your lever. I put a pickle fork on the circle clamp to act as a lever, then I give the pickle fork a single large whack with a small sledge which pops the axle right out. I just recently learned this trick, so I thought I'd share.
TiAgXi is offline   Reply With Quote
Old 08-20-2013, 04:57 PM   #10
Kubica
My Ride: 2003 325xi
Driver's side tends to go in/out much easier.
Originally Posted by TiAgXi View Post
Nice write up.
What's a circle clamp?
Old 08-21-2013, 11:47 AM   #11
Hogan773
My Ride: 2002 325xi
Awesome write up! Good job. Seals the deal for me that next time my axle goes, I'll still pay the couple hundred to my indy to do it for me though. I'm still new to the DIY thing and your writeup tells me that this ain't the job for me!
Hogan773 is offline   Reply With Quote
Old 08-21-2013, 04:23 PM   #12
Foxtrot_Uniform
My Ride: 325Xi
Excellent write-up! Thanks for posting this.
Foxtrot_Uniform is offline   Reply With Quote
Old 08-21-2013, 09:07 PM   #13
fastjasonbmw
My Ride: 330Xi
I'd like to comment on step (8), lube the sealing surface. I also like to add a bit of grease to the inner part of the seal, where the spring resides, this helps keep the spring in place during re-installation of the axle. This also applies to any seal that has a spring around the inner seal surface. I also like to place a pry bar in the brake rotor vent veins and and place the handle of said pry bar against the fender liner (wheel well plastic) to make the removal/installation of the axle easier (more space to work). just pay attention to the brake line, so it is not overly stretched. With the right tools and knowledge/experience, you can bust out a front outer CV boot replacement under 30 mins. But, you're better off replacing the inner and outer CV boots at the same time. Don't forget to apply silicone/RTV to the inner CV boot rubber piece sealing surfaces. My opinion: I like to remove the lower control arm outer ball joint nut, to separate the control arm from the knuckle, a ball joint separator tool is recommended.
Good DIY!
fastjasonbmw is offline   Reply With Quote
Old 08-21-2013, 09:42 PM   #14
TiAgXi
one of those steel circular bands that tightens. like what they use to secure hoses'n'things.
Old 08-24-2013, 10:09 PM   #15
tanayast
My Ride: 2001 325xi
Thank you all for the kind words and adding to this DIY!
Let's keep helping each other out
Old 11-20-2013, 05:02 PM   #16
Mannydog
My Ride: '02 330Xi 5spd
tanayast:
This was a big help last weekend changing my drivers side axle, thanks!
The seal I used didn't have the clip, but for the passenger side (next weekend), I have an OEM BMW seal on the way that should have the clip.
What is the diameter of the stock you use to tap in the seal (which, BTW, looks a lot easier than what I went through to get the first seal in)?
'02 330xi 5 spd
Mannydog is offline   Reply With Quote
Old 11-22-2013, 11:19 AM   #17
mvance30
My Ride: 2002 325xi
I'm sure this is probably mentioned somewhere but I cant find it. Replacing diff fluid is needed and/or recommended? if so what weight would I need? Redline would work?
mvance30 is offline   Reply With Quote
Old 12-16-2013, 10:19 AM   #18
Mannydog
Good DIY!
What he said!
After installing a GKN axle (and OEM seal) on the passenger side, I had a serious leak.
I thought it must be the support bracket/pedestal, so I got a new on and installed (luckily I read fastjason's tip and added grease). After installation I did a little forensic work on the old support bracket and found the spring from the seal cuddled up next to the bearing inside the support bracket.
Thanks Jason, I never would have thought about the spring coming off if I hadn't seen your post!
'02 330xi 5 spd
Old 03-21-2014, 02:16 PM   #19
thassler25
My Ride: 2002 BMW 325xi
axle gap problem
I just completed this job the other day and your DIY was a big help! I do have a problem though. I just noticed a gap between the axle and where the differential seal goes. Its about a quarter inch, maybe a little less. I already have everything back together and had an alignment done. Do you think it will work its way back in? I'm not sure if I should leave it alone or pull it apart and beat it in further. What is your thought? There might be a little oil dripping out too. I'm gonna go drive it around a little more and double check that.
thassler25 is offline   Reply With Quote
Old 03-21-2014, 03:04 PM   #20
Mannydog
Exclamation
NO!
Don't drive it! You will leak dif fluid and risk damaging the dif!
It's not all the way in and it can take several tries to get it seated (the snap ring has to go past the internal splines into the corresponding groove).
Possibly the most frustrating part of the whole axle change procedure.
I seriously doubt it will work its way in on its own.
'02 330xi 5 spd
