Australia
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 4.00 average. Display Modes
Old 08-10-2013, 08:37 PM   #21
indoafro
My Ride: 325ci
Daves Minimal Build/Progress thread
cool story...i really want to have lsd on my coupe..how was the rear subframe instalation ? could you tell us more detail story about that ?
indoafro is offline   Reply With Quote
Old 08-10-2013, 08:50 PM   #22
selien
My Ride: 330CI
Originally Posted by Davconelectric View Post
Cool story bro. I would never break any road rules, or endanger mine of any others life's like that.
ha! your cooking alone endangers life
I AM OF DUBIOUS NATURE
selien is offline   Reply With Quote
Old 08-10-2013, 10:03 PM   #23
Davew
My Ride: 2004 330ci Msport
Don't know if it is possible with the m3 diff you have, but if you could change your ratio down to 3.38 running your 19 wheels, you should get much better 0-100. At the moment I would guess you have to change twice to get there, diff ratio change would mean only one gear change, quicker time.
http://www.bokchoys.com/differential...calculator.htm
Davew is offline   Reply With Quote
Old 08-10-2013, 11:37 PM   #24
Davconelectric
My Ride: 2 dog powered sled
Thanks Dave, not a bad calculator. I have been thinking about changing diff ratios. Just gotta find one
Davconelectric is offline   Reply With Quote
Old 08-10-2013, 11:40 PM   #25
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Where would he find a 3.38 for the M3 diff?
E46 Coupe is offline   Reply With Quote
Old 08-11-2013, 12:28 AM   #26
Davew
Like I said, no idea if it was possible? Custom cut gears depending on carrier size??? No idea. I am stuck with my ratio because of my tranny, never looked into this myself.
Old 08-11-2013, 12:31 AM   #27
Davew
I work for an engineering company, the gear cutters we use for all our gear cutting are excellent and very helpfull. I can pass on there contacts if you like, but I have no idea of the size of the carrier in the m3 diff and if this is possible???
Old 08-11-2013, 02:12 AM   #28
Davew
http://www.turnermotorsport.com/p-20...m-options.aspx
Turner have options that you could look into, maybe they have a gearset on the shelf???
They have the option of 3.23 or 3.45 on there custom M3 diffs.
Old 08-11-2013, 02:19 AM   #29
Davew
3.23 would look good, to 100 with one change, good cruising rpm at 100. Calculator is pretty accurate for clutched drive.
Old 08-11-2013, 02:32 AM   #30
Davew
Please don't think I am being a smart *ss here, my job during the week is basically to solve engineering problems/ dilemmas. Just trying to be helpfull. My knowledge of m3's is limited, I have never had the chance to play with one, and most of my experience is with the 330 and 325.
Old 08-11-2013, 03:02 AM   #31
E46 Coupe
E46 Coupe's Avatar
Nah, not questioning the possibility (of course) just the cost of such a change to a weekend car for Dave.. Dave.
lol
Old 08-11-2013, 03:50 AM   #32
Davconelectric
Here's the issue, been thinking about it whilst driving home. How many standing start launches do I really do? I mean most of my driving is between 40 and 110kmph. Is it even worth changing ratios and spending a few grand on new gears that realistically would only be for 0-100kmph drags?
Old 08-11-2013, 04:06 AM   #33
Davew
Launch in second perhaps???? See how that goes.....
Old 08-11-2013, 04:08 AM   #34
E46 Coupe
E46 Coupe's Avatar
Doesn't add enough to the smile "factor" but if you want "that" you wouldn't hold back...
Old 08-11-2013, 04:10 AM   #35
Davew
If you had a rooted M3 crown and pinion, could always machine some blanks and then have them gear cut and heat treated. This option may see you come under a grand easily.
Old 08-11-2013, 04:10 AM   #36
E46 Coupe
E46 Coupe's Avatar
Daily drive? No.. Purpose built car? Wrong base..
Davcon.. I'll trade my tubular frame 1/4mile chassic for the 330
Old 08-11-2013, 04:11 AM   #37
E46 Coupe
E46 Coupe's Avatar
Woops quoted wrong Dave hahaha
Old 08-11-2013, 04:17 AM   #38
Davew
Does anyone out there have a set of m and non m crown and pinions that they would allow to be measured up?
Old 08-11-2013, 04:50 AM   #39
Davconelectric
I believe Brendan_select is selling a LSD for a standard diff if your interested. My car was a 6 speed manual so everything including tail shaft bolted straight in. If you have an auto or 5 speed you'd need to get a custom length tail shaft made up. It was really quite an easy straight forward job.
Old 08-11-2013, 07:19 AM   #40
Davew
http://item.mobileweb.ebay.com/viewi...d=111047287375
Do it Dave, it's only $500 bucks. You know you will end up doing it eventually!!! Do it now!
You will save this on tyres alone!!!
