E46 Xi Forum
Old 08-10-2013, 09:56 AM   #1
mcurcio1989
My Ride: 2002 325xi
cracking noise coming from front end after front dif removal
02 325xi automatic
Long story short last sunday I pulled my front differential which invollved replacing both cv's, dropping the front sub frame, supporting the engine with an engine bar etc. Everything was all good for the first few days but now I am getting a cracking noise apparently from the front end. It kind of feels like its coming from my right foot area but who knows. Under a hard acceleration from low speeds it will make a noise with associated vibration that sounds like your cracking your knuckle. Then under decelleration it will do the same thing but with maybe 3 or 4 cracks. It feels like something is loose and moving maybe 1/32 -1/16 of an inch. This started maybe 3 days ago and seems to be getting worse.
I put the front on stands and checked the things I had removed last week for tightness, front motor mounts, steering shaft, cv's, brake calipers, differential, front drive shaft, front subframe mounts, ball joints and brackets on the front control arm, and the struts. All was good - I couldn't find anything that had any play and the engine feels firm with no movement if you shake it. I checked my front motor mounts when I had them off and they felt fine. I have really no good idea what is causing this and it is driving me crazy. The one thing I am wonder is maybe the rear engine / transmission mounts. Maybe if they were on there way out this work could have accelerated it.
I am not sure if this is related but for the past year I have noticed what to me feels like an excessive amount of vibration when stopped at a light in drive. It has me nervous but from all of the reading I have done there seems to be no conclusive idea on how to attack that so I haven't done anything with it yet.
mcurcio1989 is offline   Reply With Quote
Old 08-11-2013, 06:14 PM   #2
mcurcio1989
My Ride: 2002 325xi
anybody? its getting worse and its driving me crazy I just cannot find where it is coming from
Old 08-12-2013, 06:48 AM   #3
Kubica
My Ride: 2003 325xi
I would have a good look at your subframe bolts. Re-torque to spec. Possibly replace.
Old 08-12-2013, 08:04 AM   #4
bmwbob89
My Ride: M-5 325 X3 528 740
Go to this page for the proper sequence for tightening the sub frame.
http://bmw.workshop-manuals.com/3_Se...ex.php?id=1417
bmwbob89 is offline   Reply With Quote
Old 08-20-2013, 09:40 PM   #5
mcurcio1989
My Ride: 2002 325xi
^Thanks, Like an idiot I had tightened up the rear two first and it clearly prevented the front two from seating all the way. Hindsight is 20/20
Old 09-11-2013, 09:50 AM   #6
mcurcio1989
My Ride: 2002 325xi
Okay so the problem came back and worse then before I tried retorquing the bolts again and that didn't help. One of them had gotten a little bent when I removed it so I replaced them both and then re-torqued again. Still not helping at all. So I'm back to square one. I'm gonna go under there and give everything another good look and check tightness but in the mean time any ideas are appreciated.
Old 05-03-2015, 10:33 AM   #7
djdonis
My Ride: e39 540i M, 330i 6sp
wondering if you resolved the problem. Please let us know if solution was found.
Diagnosis - BMW...
djdonis is offline   Reply With Quote
Old 05-18-2015, 07:30 AM   #8
cmacleod
My Ride: 2003 325xi
Did you remove the front sway bar during your struggles? if so, did you re-install it with the suspension loaded? they need to by installed with the car under its own weight and not on stands or else you will get a popping/cracking noise from turns/accelerating/bumps... etc etc. Put the car on ramps, loosen the bushing and hardware holding the bar in place and then re-torque them properly while the car sits on the ramps.
cmacleod is offline   Reply With Quote
