Old 08-13-2013, 12:33 PM   #41
My Ride: Lexus
Originally Posted by 325iGirl03 View Post
Blah blah blah
i thought maybe your car overheated
Old 08-13-2013, 01:10 PM   #42
WDE46
My Ride: '13 128i, '04 330Ci
Go get a stock airbox at a junk yard and replace that cone. It's definitely hurting you.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 08-15-2013, 12:08 PM   #43
Scott_B
My Ride: 330Ci
I am still doing research at this point, but this morning i tried to start car and it did same thing 5 seconds and dies, i sprayed cone (filter) with starting fluid and it started and worked fine around 1000 rpm, however was vibrating. So i sprayed all over intake and could not find any other spots that will make it rev once sprayed.
Scott_B is offline   Reply With Quote
Old 09-25-2013, 08:10 PM   #44
Scott_B
My Ride: 330Ci
Ok got the problem few weeks back, forgot to mention it was the MAF sensor, not sure what happened it was working fine in the past. However connector is all messed up and i suspect it could be the problem. Do you know where i can buy new connector for MAF sensor i cannot find on RockAuto.
Will also try to diagnose it with multimeter and clean and see if that helps.
Old 09-26-2013, 07:14 AM   #45
dznuts007
My Ride: 2001 325i Sedan
You have any codes or is the SES (Service Engine Soon) light on?
dznuts007 is offline   Reply With Quote
Old 09-26-2013, 10:46 AM   #46
sprintman
My Ride: Ex 325CI owner
Originally Posted by Scott_B View Post
Any idea what causes sludge in first place? While i lived in Europe quite few people said that Castrol oil is doing that...
How about using 5 minutes engine flush before changing oil, it has any other disadvantages other than clogging oil pump netting/filter
I forgot to tell oil smells like exhaust gases getting to it, probably that destroys chemical formula of oil faster than at 2/3 of its life cycle.
Using the wrong spec oil and it shears. That's why. BMW and the oil companies developed LL01 oil spec to stop this.
sprintman is offline   Reply With Quote
Old 09-26-2013, 03:36 PM   #47
dznuts007
I'm a +1 on the Seafoam. I did not use it to remedy a problem though. I was using it in the crankcase and gas tank to hopefully keep things clean. I'll admit back in the days I was NOT taking care of my car very well. Skipped doing oil changes waaaay past the intervals. I even took my car to Jiffy Lube once! (Please don't ever repeat this or quote me or use this against me).
Well anyways, a mechanic I used to use often was replacing my VCG and was amazed at how clean the engine was for the amount of miles it had. He even said it waa cleaner than his own and asked me what I was adding, what gas I was using, etc. I told him I didnt do anything special. Just use Seafoam every once in awhile.
