Old 08-13-2013, 09:44 AM   #1
fmzip
My Ride: '08 328xi / '01 530i
Found some perfect LED's for the interior!
Found some perfect Amber LEDS that match the stock hue. Installed some in the 530's door pockets, planning to tackle the e46 next..
fmzip is offline   Reply With Quote
Old 08-13-2013, 10:37 AM   #2
Tbone8ty
My Ride: 2003 330i
Link?
Tbone8ty is offline   Reply With Quote
Old 08-13-2013, 10:42 AM   #3
Hockeyguy02
My Ride: E46 m3
In for link
CarbonBlackCinnamon
30% Tint/Black Grilles And Gills/CF Wrapped Trim/MeganRacingExhaust/DepoSmokedCorners
Hockeyguy02 is offline   Reply With Quote
Old 08-13-2013, 10:56 AM   #4
mjose
My Ride: 2000 328Ci
link?
mjose is offline   Reply With Quote
Old 08-13-2013, 10:57 AM   #5
diM3tri
My Ride: 330ci + stg2 Scoobie
In for link
Current Cars:
'99 Big Turbo B5 A4 (the red one) ^^^
'13 GLI
'91 Ford F150 v8 5spd
Previous Cars:
'05 stg 2 scoobie wagon
'82 VW rabbit vert
'01 330ci
'84 633csi
diM3tri is offline   Reply With Quote
Old 08-13-2013, 03:33 PM   #6
NyC35AV
My Ride: 99' 323i ZSP/S52 E34
Sub'd
NyC35AV is offline   Reply With Quote
Old 08-13-2013, 06:37 PM   #7
fmzip
It took a long time to find the perfect match. I sourced them from a friend of mine in Sweden. He got them from a source in Germany. I had to buy 1000pcs so I have plenty for those who are interested.
I mounted them in this bezel
As far as wiring/ soldering, this is how you hook the LED's up:
For power, I tapped off the grey/red wire off the door switches. I assume that the wire color will likely be the same in all cars. I also tapped off my center console door lock switch for footwell lighting. The wire color is the same to any light in the interior that glows amber, grey/red. I followed this DIY, my posts are on page 2
http://forums.bimmerforums.com/forum...ndles-into-E39
If you want them, I have them in sets of 4 here:
http://www.ebay.com/itm/121152569267
It can be mounted in the bezel two ways. One makes the LED head protude slightly as pictured above, and if you install it from behind the bezel and silicone it in, it's more stealth.
You can also sand them down to diffuse it even further.
It's a 5mm LED
5/16" mounting hole, the bezel is 9/64" high. Can be mounted in plastic/metal up to 7/32" thick
I also used these LED's in my courtesy lights. Popped out a festoon bulb and made a small bread board with 12 LED's without bezels. I was also thinking of putting these in the map lights
Old 08-13-2013, 08:39 PM   #8
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
That's a pretty good idea. I hate digging in those pockets on the dark.
Cavi Mike is offline   Reply With Quote
Old 08-13-2013, 08:42 PM   #9
fmzip
I agree! It's soft lighting, not too bright, it's really spot on.
I look forward to the drives at night, seem to look for a reason to take a ride after dusk.
I also put a few under the dash to illuminate the foot-well areas.
Old 08-13-2013, 08:54 PM   #10
Tbone8ty
My Ride: 2003 330i
very nice touch! wanna put some in my footwells for night time driving.
Old 08-13-2013, 09:01 PM   #11
fmzip
You're local bud, stop on over and pick some up! I'm in Bloomfield
Old 08-13-2013, 09:32 PM   #12
Tbone8ty
My Ride: 2003 330i
Nice! I work off day hill road in windsor. maybe we can meet up sometime. im a recent e46 owner so im learning so much!
check out my recent purchase
do you still have yur supercharged e46 vert? its beautiful! ;-)
Old 08-13-2013, 09:36 PM   #13
motorhead55
My Ride: 01 325it 5spd sport
What value is the resistor needed? Do you supply them with the LED's?
motorhead55 is offline   Reply With Quote
Old 08-13-2013, 09:41 PM   #14
fmzip
Nice Ride! Welcome to the club.
I work off Day hill too on Addison Road. Yes, still have the 330, thanks for the compliment. Be glad to meet whenever you'd like(needs to be sunny)
Last edited by fmzip; 08-13-2013 at 09:46 PM. Reason: Yes, still have the 330, thanks for the compliment
Old 08-13-2013, 09:42 PM   #15
fmzip
Yes, I supply the LED's with resistors and bezels at stated in the listing.
Old 08-14-2013, 07:58 PM   #16
fmzip
Thanks for all the orders! ALL PM's replied to
Old 08-27-2013, 11:24 PM   #17
Tbone8ty
My Ride: 2003 330i
how many would i need for the footwells in my e46?
wanna make them so there on when i switch the lights on? possible?
Old 08-28-2013, 08:04 AM   #18
fmzip
You could use as many as you'd like. I used two per side. Any switch that glow amber already is a source for power.
You can tap off any of the window switches by the shifter which is what I did for my footwells. Most likely the LED wire for your car is grey/black for +12V. Brown wire is ground.
If you can't figure out where to tap off, I am 5 miles from you.....
