E46 Xi Forum
Old 08-19-2013, 08:29 AM   #1
paullfisher
My Ride: 2005 325i
Send a message via MSN to paullfisher
Shocks/struts for 325xi
I just bought a 2003 325xi and it needs shocks/struts.
Looking around, Bilstein seems to make fronts and Sachs makes rears. I don't like mixing brands so any suggestions? I would like something close to a factory ride quality as my wife has back problems and doesn't want it stiffer.
Thanks!
Paul L Fisher
2003 325xi (wife's car)
  • Eibach
  • Koni Sport
paullfisher is offline   Reply With Quote
Old 08-19-2013, 09:55 AM   #2
SamDoe1
My Ride: 4cyl of fury
http://forum.e46fanatics.com/showthread.php?t=986932
Old 08-19-2013, 12:34 PM   #3
paullfisher
My Ride: 2005 325i
Originally Posted by SamDoe1 View Post
Thank you. Just ordered the Koni Yellow Sport front and rear for $499 including shipping.
Paul L Fisher
  • Eibach
  • Koni Sport
Old 08-19-2013, 03:35 PM   #4
dgknight
My Ride: 02 325xi 5sp 120k
Make sure to check the front control arm and rear trailing arm bushings, along with the front inner and outer ball joints and tie rods.
All those wear and are due for replacement when the struts are if not done already.
dgknight is offline   Reply With Quote
Old 08-19-2013, 07:22 PM   #5
Foxtrot_Uniform
My Ride: 325Xi
You might as well order some Eibach springs to go with those shocks/struts...
Foxtrot_Uniform is offline   Reply With Quote
Old 08-19-2013, 09:45 PM   #6
jmo69
My Ride: 03 325xi 98 328is
It looks like we have the same car and the same surroundings, Wisconsin winters. I'm going to need to do this eventually, please post how the install goes and where you purchase the dampers.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 08-20-2013, 09:33 AM   #7
paullfisher
My Ride: 2005 325i
I will be doing it this weekend.
I bought them at www.shox.com. If you ask them for a quote, they will give you the $499 with shipping price. Online it was somewhere in the $711 - 20% or $580 or so.
I ordered all the hardware from Newegg and Bav Auto.
We shall see how it goes. Probably going to get the spring compressor from Autozone.
Paul L Fisher
  • Eibach
  • Koni Sport
Old 08-20-2013, 09:33 AM   #8
paullfisher
My Ride: 2005 325i
I don't want to lower the car. The springs seem in good shape. We shall see when I pull them this weekend.
Paul L Fisher
  • Eibach
  • Koni Sport
Old 08-21-2013, 03:25 PM   #9
Foxtrot_Uniform
My Ride: 325Xi
I will almost bet you that one of the rear springs is broken.... Springs are cheap.
Old 08-26-2013, 12:44 PM   #10
EDWAGON
My Ride: 2004 325xiT
Hey Paul how did you make out? I am about to order oem front struts question for this tread did you also replace the front strut mounts?, spring pads upper and lower, and damper guard and bump stop? I have 82k miles and wondering if I can reuse all those parts and just replace struts.
Thanks.
EDWAGON is offline   Reply With Quote
Old 08-26-2013, 01:27 PM   #11
paullfisher
My Ride: 2005 325i
Thanks.
I got the struts and shocks Friday. The rest of the parts didn't show up in time for me to do it last weekend.
I did order the rest of the parts because I figured I don't want to take them apart more than once.
I am probably going to take Big Rick's advice and order the Eibach springs because it is kinda droopy compared to the front.
So far, www.advanceautoparts.com is the cheapest for the springs because they have a 15% off coupon through the end of the month and offer free shipping. $237.99 delivered.
Paul L Fisher
  • Eibach
  • Koni Sport
Old 08-29-2013, 03:57 PM   #12
rawbspear
My Ride: 04' E46 XIT 5 speed
the eibachs will lower 1/2". better do all 4
rawbspear is offline   Reply With Quote
Old 09-07-2013, 04:20 PM   #13
paullfisher
My Ride: 2005 325i
Finally have all the parts. I did the rears today as they were the worst.
I had noticed a puddle by the right rear wheel and was concerned that it was a caliper.
Anyhow, took the wheel off and the shock was soaked. It had failed spectacularly!
Then pulled out the springs and they were broken, as Big Rick suggested.
Car drives much better! Even with the Eibach lowering springs, the rear end is higher up.
Paul L Fisher
  • Eibach
  • Koni Sport
Old 09-07-2013, 08:09 PM   #14
White_Knuckles
My Ride: 2003 325xi
They will settle some. Don't forget a 4-wheel alignment to make sure camber is is dialed after the small drop.
Old 09-09-2013, 07:28 AM   #15
paullfisher
My Ride: 2005 325i
Here are the pictures of the blown shock and broken springs.
https://picasaweb.google.com/1143459...eat=directlink
Paul L Fisher
  • Eibach
  • Koni Sport
Old 09-09-2013, 11:20 AM   #16
rawbspear
looks sick. cant wait to hear how you like it. Has to be better than before buy will you like the lowering?
Old 09-09-2013, 03:04 PM   #17
paullfisher
My Ride: 2005 325i
Actually, with the non-broken spring and the thinner upper spring pad it actually raised it.
So far my wife likes it so much better. I'll do the fronts this weekend because I had forgotten to order the front bump stops.
Paul L Fisher
  • Eibach
  • Koni Sport
Old 09-09-2013, 09:47 PM   #18
Kubica
My Ride: 2003 325xi
What the hell happened to that shock?!
Old 09-10-2013, 01:34 PM   #19
paullfisher
My Ride: 2005 325i
Nice huh? The car has 166,000 miles on it and has been in Wisconsin all of its life.
Paul L Fisher
  • Eibach
  • Koni Sport
Old 09-10-2013, 03:30 PM   #20
SamDoe1
