///M3 Forum
Old 08-22-2013, 12:36 AM   #21
khr0n1x
My Ride: 2004 CARBON BLACK M3
Finally took 01 m3 in for dme recall, codes p0012
Originally Posted by Grinchxvx View Post
This sounds exactly like my car, I bought the parts yesterday so if they're here by Friday I'm either finding a friend to help me or taking it to my local Indy for 50 bucks
Well try cleaning the solenoid connector and delete the CEL, it might fix it for you! All I know is I had misfires on every cylinder also!
| 2004 E46 M3 Carbon Black | Black Interior |
| OEM Short Shift Kit | Depo LED Turn Signals |
| Angel Eye LED's | CSL M3 Style Carbon Splitters |
| VMR V710 Gunmetal Grey 19" |
| Agency Power V1 Exhaust |
khr0n1x is offline   Reply With Quote
Old 08-22-2013, 10:19 PM   #22
Grinchxvx
My Ride: 2001 M3, 1998 M3
Originally Posted by taylor192 View Post
Please don't comment if you don't know what you're talking about, you only confuse the OP. You might want to do some more research before tackling the Besian repairs since you're not very familiar with the vanos parts.
The solenoid is mounted under the vanos pump on the outside of the engine. No need to disassemble the motor.
Yeah it confused me at first but I get that the Solenoid is basically mounted on the vanos unit and is easy to get to.
Grinchxvx is offline   Reply With Quote
Old 08-24-2013, 10:39 PM   #23
Grinchxvx
I did the beisan solenoid pack today and cleared the codes and the service engine is still on, camshaft position sensor next?
Old 09-20-2013, 06:17 PM   #24
Kylew90
My Ride: E46 M3 SMG
Question When replacing the solenoid, cam sensor, etc for P0012
Could the p0012 still show it's face again after replacing the solenoid do to not adequately torquing down the bolts down ( the 5 on top the vamps ) to 7 Ib? I'm not a mechanic but I get by with avoiding having to make car to my local stealership as much as possible so anybody's help would be appreciated. I'm actually having a little more trouble or problems with my car than need to be so I figured I should tackle the P0012 issue first. I've replaced the solenoid, the Cam sensor, bout year ago had to rebuild engine do to the vanos bolt shearing off and falling into my timing chain and yea, you get the picture. I didn't buy a new one though I went to Dr.Vanos and also to Beinsen for the solenoid so never fully brand new parts I used to replace these which I hope that this could not be the issue as well. Again if anybody could help me man I would seriously appreciate it. Thanks.
Kylew90 is offline   Reply With Quote
Old 09-21-2013, 05:48 PM   #25
Grinchxvx
I've also done the cam sensor/ solenoid pack and still have p0012. My next step is to pie the valve cover and check everything out. Since you bought a used vanos unit maybe it's possible something broke again and didn't fall into the timing chain?
Old 09-21-2013, 05:48 PM   #26
Grinchxvx
Open* the valve cover
