Go Back   E46Fanatics > E46 BMW > Sponsor Press Releases & New Product Announcements > Site Sponsor Specials and Sales
Find out about the latest specials and sales from our site sponsors here!
Old 08-21-2013, 07:52 PM   #1
MJM Distributing
Past Site Sponsor
My Ride: TOO MANY TO LIST
Send a message via AIM to MJM Distributing Send a message via Yahoo to MJM Distributing
Eibach Wheel Spacers Sale at MJM Autohaus!
ALL EIBACH SPACER KITS ARE MADE IN GERMANY AND INCLUDE ALL HARDWARE!
Recently marked down in price due to overstock (for limited time), MJM has Eibach Pro-Spacers in stock and ready to ship for the select applications below. To give your car the final visual and performance touch you, the engineers at Eibach have created a complete line of Eibach "Pro-Spacer" Wheel Spacers. These spacers are designed to give your vehicle a wider, more stable stance, quickly and easily. Eibach Wheels Spacers, made in Germany, are also a perfect match for the famous Eibach Pro-Kit or Sportline Lowering Spring Sets. With the right Eibach Pro-Spacers installed, your car takes on a more aggressive look, with the wheels and tires filling the wheel arches exactly the way they should. In addition, wheel spacers can also help assist in fitting a custom wheel or brake kit you're looking to add to your car.
Fine-tuning your track width doesn't just enhance your car's looks, it also gives you improved handling performance and optimized roll characteristics. Eibach's "Pro-Spacer" Wheels Spacers are available in a wide range of sizes - from 5mm all the way to 45mm (depending on the application), letting you position your tires exactly where they will look and perform their best. In many cases, installing the right Pro-Spacers can improve the look and function of your existing wheels and tires so much, you might not need to buy new custom wheels and tires at all. All spacers come complete with bolts - NO NEED TO BUY SEPARATE BOLTS! Each kit will include the set of two (2) spacers for right and left side for the front or rear of your vehicle.
ALL SPACER KITS INCLUDE BOLTS - NO NEED TO BUY SEPARATELY!
Features:
  • 5x120 Bolt Pattern
  • Hub Center of 72.5
  • Strength-Tested for All Applications
  • Reduced Weight Compared to Steel Wheel Spacers
  • Widen Your Stance for Better Handling and Appearance
  • Precision Engineered and Hub-Centric for Perfect Fit and Wheel Balance
  • Extreme Corrosion Protection Through DIN 50021 Approved Coating Process
Sale Pricing:
  • 5mm Spacers: $79.95 with free shipping! (QTY: 2 in stock)
  • 12mm Spacers: $124.95 with free shipping! (QTY: 5 in stock)
  • 15mm Spacers: $134.95 with free shipping! (QTY: 4 in stock)
  • 20mm Spacers: $119.95 with free shipping! (QTY: 3 in stock)
  • 25mm Spacers: $119.95 with free shipping! (QTY: 3 in stock)
  • 30mm Spacers: $139.95 with free shipping! (QTY: 4 in stock)
Ordering Info:
To place an order, simply send us a PM with your PayPal info for same day shipping. All kits ship from Texas.
Last edited by MJM Distributing; 08-21-2013 at 07:57 PM. Reason: Auto-save 1377133053
MJM Distributing is offline   Reply With Quote
