Sponsored by BimmerWorld
Old 08-22-2013, 03:35 PM   #1
Smurphymurphy89
My Ride: 2005 325xi
BMW brakes need grease?
Could anyone tell me if I need to freeze up my BMW brake pads I want to install. I recently got the BMW brakes because the aftermarket brakes I put on kept squealing on those I had to put grease. I'm wondering if I have to do the same for the original BMW pads I have a 05 325xi thanks
Smurphymurphy89 is offline   Reply With Quote
Old 08-22-2013, 03:36 PM   #2
Smurphymurphy89
My Ride: 2005 325xi
Greese''
Old 08-22-2013, 03:39 PM   #3
Grande D
My Ride: E36 M3
Yes you need to use anti-squeal grease on any pads you put on your car, if that's your question. It's kinda hard to tell.
It will change your life!
Old 08-22-2013, 04:02 PM   #4
My Ride: Lexus
TIS instructs the use of high-temp anti-squeal compound used on the pad shim and pad bracket areas where pad slides in the caliper.
Old 08-22-2013, 04:06 PM   #5
paraklas
My Ride: ESS TS2 320ci
81 22 9 407 103
Brake-pad paste
it does work.
Old 08-22-2013, 04:28 PM   #6
Smurphymurphy89
My Ride: 2005 325xi
Yep that's what I meant.. Where could I find that grease what's the name of it ? I see you gave me the part number? Where could I enter that in
Old 08-22-2013, 04:31 PM   #7
My Ride: Lexus
Doesn't need to be BMW.
Look for high temp ceramic brake grease by Permatex. Comes in purple packets. Find it at your local auto parts store.
Old 08-22-2013, 04:32 PM   #8
Smurphymurphy89
My Ride: 2005 325xi
Does BMW make one?
Old 08-22-2013, 04:33 PM   #9
My Ride: Lexus
Does BMW make one?
probably. but it's also probably rebadged by permatex.
Old 08-22-2013, 04:34 PM   #10
My Ride: Lexus
Here you go:
Permatex high temp brake grease - amazon
This stuff is GOOD. trust me.
Old 08-22-2013, 04:43 PM   #11
Smurphymurphy89
My Ride: 2005 325xi
Old 08-22-2013, 04:49 PM   #12
Smurphymurphy89
My Ride: 2005 325xi
Thanks bud will do
Old 08-22-2013, 04:56 PM   #13
xps
My Ride: 05 325ci w/ zhp eng
I used this when I did mine,
Autozone CRC RED
Apply plenty of 'em. be careful about what you wear during the brake job, this dosen't go once they stick to your clothes, ask me how I know
xps is offline   Reply With Quote
Old 08-22-2013, 04:58 PM   #14
My Ride: Lexus
Autozone CRC RED
That stuff is horrible. It isn't grease. It's a thick sticky mess that turns to rubber. Ineffective and unnecessary.
Old 08-22-2013, 04:59 PM   #15
xps
BTW I doubt its called grease! the grease would be used for guide pins in the caliper, squeaking needs some kind of antisqueak high temp resistant stuff
Old 08-22-2013, 05:00 PM   #16
My Ride: Lexus
No. Grease is NOT to be used on the caliper guide pins. Please stop giving advice.
Old 08-22-2013, 05:01 PM   #17
xps
I know its too messy, but I thought this thing turning into rubber like compund is what absorbs sqeaks? no?
Old 08-22-2013, 05:01 PM   #18
My Ride: Lexus
I tried it before. It made it worse!
Old 08-22-2013, 05:17 PM   #19
FenderGuy05
My Ride: 2002 BMW 325i
I've used the CRC stuff on both rear and fronts, no squeeking. Only on the back of the pads, where the pads slide into the caliper, I used brake grease.
FenderGuy05 is offline   Reply With Quote
Old 08-22-2013, 05:25 PM   #20
xps
Well I should have specified, greasing isn't recommended on BMWs(so far what I have read of forums).
And that was not an advice Mango that was a sincere doubt I have , because that's what I understood even from the product description on amazon
"Suggested applications include disc brake caliper hardware, pistons, brushings, rubber sleeves and seals"
For pads (that's what OP mentioned he bought new) I thought CRC like compound would help better.
Again not an adivce just my doubts and views
