Sponsored by BimmerWorld
Old 08-22-2013, 06:33 PM   #21
2003 325i
My Ride: '03 Orient Blue 325i
Bmw doesn't recommend greasing the slide pins but I do, especially if you're in a climate where rust and corrosion are factors. I would use a SMALL amount on any make or model regardless of the manufacturer's suggestion.
Silicone brake caliper and dielectric grease. Clean and reapply every year or 20000km
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 08-22-2013, 06:37 PM   #22
My Ride: Lexus
Originally Posted by xps View Post
Well I should have specified, greasing isn't recommended on BMWs(so far what I have read of forums).
And that was not an advice Mango that was a sincere doubt I have , because that's what I understood even from the product description on amazon
"Suggested applications include disc brake caliper hardware, pistons, brushings, rubber sleeves and seals"
For pads (that's what OP mentioned he bought new) I thought CRC like compound would help better.
Again not an adivce just my doubts and views
You read that on "forums" because you read it from me. I started enforcing this a long time ago and peoples reactions (like many other topics here) were WAT?! NO! FALSE! Now it's quiet. I'm sure some others knew, but I make it known very publicly.
Regardless of what a product label says, you should always follow the specific recommendations by your manufacturer for your particular application. Product labels say this as well.
Old 08-22-2013, 06:39 PM   #23
My Ride: Lexus
Guide pins shouldn't rust if the bushing caps are installed. BMW does not only "doesn't recommend it," they specifically instruct NOT to do it.
Old 08-22-2013, 07:04 PM   #24
2003 325i
Originally Posted by Mango View Post
BMW stating not to grease the pins is cannot be likened to their lifetime fluid program. Not greasing the pins does not affect the image of the brand.
Neither has to do with branding. My point was that they're wrong more than once. Forgot about that other exposed end didn't you
Old 08-22-2013, 07:10 PM   #25
My Ride: Lexus
It has everything to do with it. It's a business and marketing case pure and simple. Prior to a certain point, BMW had proper service intervals for these "lifetime" fluids. This isn't limited to BMW. Mercedes, Audi, VW have been doing this for years. It's been discussed to death for nearly a decade. Google is your friend.
Old 08-22-2013, 07:14 PM   #26
xps
My Ride: 05 325ci w/ zhp eng
remanufactured calipers from ECStuning came with filled (almost overflowing) grease in the guide pin hole.. I actually opened the cap and cleaned a bit before installing.
xps is offline   Reply With Quote
Old 08-22-2013, 07:42 PM   #27
2003 325i
That's fine and good but ive never seen an ad boasting about lifetime fluid and I think you'd be hard-pressed to find a salesman that mentions it as a selling point.... likely because theyd look like a tool for saying such a preposterous thing.
Regardless... grease the pins... benefit outweighs the cost by far... just like bmw's lifetime fluids.
Old 08-22-2013, 09:41 PM   #28
Sapote
My Ride: E46 2000 323i wagon
No. Grease is NOT to be used on the caliper guide pins. Please stop giving advice.
So what should be used to lube the guide pins? Pure Lavender Honey?
Sapote
Sapote is offline   Reply With Quote
Old 08-22-2013, 09:53 PM   #29
My Ride: Lexus
You obviously don't understand the way the world works. This isn't about commercial ads or sales pitches. Just... nevermind.
Sapote
Nothing. No lubrication needed. Ever.
Old 08-22-2013, 09:55 PM   #30
My Ride: Lexus
That's likely an anti-corrosion gel similar to "cosmoline" what BMW uses at the factory. Also comes on rotors, etc. Either way, third-parties reman parts and ship them off. No biggy. wash it out.
Old 08-22-2013, 10:10 PM   #31
Kris323i
My Ride: 323i
BMW brakes need grease?
I bought oem pads and rotors put them on dry with no issues or squeaks.
Kris323i is offline   Reply With Quote
Old 08-22-2013, 11:23 PM   #32
2003 325i
Agree to disagree. As a mechanic I will continue to use it and advise others to do so. You can keep suckling from the BMW teat.
Old 08-23-2013, 03:03 AM   #33
Smurphymurphy89
My Ride: 2005 325xi
Pads
Yeah but should I still grease up the back of the pads that's the only thing I was going to grease anyway ?
Smurphymurphy89 is offline   Reply With Quote
Old 08-23-2013, 12:59 PM   #34
HOTBMW
My Ride: 2000 323i
NO! Grease could come off and get on you pads/rotors and reduce your stopping distance. Use something specific to stop squeals. I just changed my pads and used CRC's anti-squeal on the back of the pads. Looks like a small bottle of pink goop. I put a light coat of it on the shims with a small brush and let it dry. It dries to a rubber like consistancy. 600+ miles, no squeaks.
HOTBMW is offline   Reply With Quote
Old 08-23-2013, 01:07 PM   #35
xps
+1
Use the CRC stuff they are messy but they work
Old 08-23-2013, 02:15 PM   #36
Smurphymurphy89
My Ride: 2005 325xi
What's that where do you. Get that? I wonder what BMW uses when they so a brake job do you know
Old 08-23-2013, 03:40 PM   #37
My Ride: Lexus
Do NOT use the CRC stuff. I already posted advising against this.
Use this:
http://forum.e46fanatics.com/showpos...2&postcount=10
Old 08-23-2013, 04:43 PM   #38
xps
Old 08-23-2013, 04:46 PM   #39
xps
Old 08-23-2013, 06:40 PM   #40
HOTBMW
My Ride: 2000 323i
I got the CRC anti-squeak at Autozone and so far this stuff has worked. If at some point the brakes start to squeal I'll take the CRC stuff off with a wire brush and use something else. I would probably use what Mango suggests. FYI, I'll be the first to admit I'm not an expert on brakes, BMW's or cars in general but I do a fair amount of research before I start a project. BTW, I have to say that I have gained a lot of knowledgable by reading this forum and if I had seen what Mango suggested, I probably would have gone with that.
