Old 08-22-2013, 09:10 PM   #1
Greenmonster138
My Ride: 99 323i?
Question E46 non M stock fuel lines max hp support
I am curious if the stock fuel lines with an in-tank aeromotive 340 pump will support a single turbo LS making in the neighborhood of 550 whp? What is the Max the stock lines can support?
Greenmonster138 is offline   Reply With Quote
Old 08-23-2013, 09:52 AM   #2
BDUB328I
My Ride: bmw 328i S54 sedan (
i think there is more to it than what the lines can support. i know to power the m3 fuel pumps there is an extra relay called the EKP fuel relay. this allows the car to give more power to the fuel pumps that the m3 pumps require to make 5 bar. non-m cars dont have the EKP relay
BDUB328I is offline   Reply With Quote
Old 08-23-2013, 03:36 PM   #3
sunnyjay
My Ride: 01 330i
The EKP fuel pump relay only exist in the US E46 M3's. They are missing in the the euro E46 M3's. That relay is just a speed controller for the fuel pump. I believe bimmerguy055 is running a walbro 255hp in his turbo setup and is making 500hp on his boosted e46.
sunnyjay is offline   Reply With Quote
Old 09-16-2013, 01:16 PM   #4
ATLZHP6M
My Ride: TS2+ ZHP, ESS E39 M5
if you install an aeromotive pump using their wiring recommendations, you will be installing a 40A relay and 10G wire to provide sufficient current for the pump.
As for the original question, I had 550HP on my M5 using stock fuel lines. This works fine but I'd prefer to upgrade all lines, fuel rail and fuel filter/regulator.
Same applies to my E46 non M
ESS TS2+ Street/Track Toy
ATLZHP6M is offline   Reply With Quote
