Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 08-23-2013, 04:01 PM   #1
GasKing
My Ride: 1990 Yugo GVC
MTM Survivor ammo can.
MTM Case-Guard has developed a ammunition storage can designed specially for burying in the ground.
The Survivor Ammo can was designed to secure important essentials that may be needed in the future. The Survivor Ammo Can will hide important documents, gear and even emergency food underground. The capsule is completely waterproof/weatherproof with the double O-ring seal and uniquely designed protective cap. The protective cap serves dual purposes as it drains water away from the seals with its overlay design, it withstands the additional weight of earth and acts as a vacuum seal that keeps dirt out of the secure screws in the can and endures the possible impact from a shovel with extracting the unit. The bucket-style design of the Survivor Ammo Can will house up to 600 rounds of .45 ACP or 500 rounds plus a handgun. Sometimes the safest place to store things is right underfoot.
It will retail for $29.95. Your only problem will be trying to find (or afford) enough ammo to fill up!
I know people do the 6-8" pvc method for cheaper, but midway has these on sale for $22.99. Might just give this a try.
GasKing is offline   Reply With Quote
Old 08-23-2013, 05:25 PM   #2
Adam@Euro-Spec
My Ride: is slowww
Send a message via AIM to Adam@Euro-Spec
burying all that gas station cash in the backyard?
Adam@Euro-Spec is offline   Reply With Quote
Old 08-24-2013, 09:43 PM   #3
tailo
My Ride: 02 330I
I feel no need to burry anything....
tailo is offline   Reply With Quote
Old 08-24-2013, 10:29 PM   #4
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
That's like burying a fire extinguisher
JonJon is offline   Reply With Quote
Old 08-25-2013, 07:44 AM   #5
GasKing
It has its purpose.
Old 08-25-2013, 08:04 AM   #6
Sentaruu
My Ride: Xterra
it's like burying a fire extinguisher that the gubbment doesn't want u to have: it is NY
Sentaruu is offline   Reply With Quote
Old 08-25-2013, 08:19 AM   #7
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
I am not burying anything.
One dude with a sonar/radar tool or good metal detector and everyone is screwed.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 08-25-2013, 08:24 AM   #8
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Originally Posted by GasKing View Post
It has its purpose.
If it gets so bad that "people" are coming to take my ammo/guns...
That's when it's time to start using them
I guess if you are trying to hide something
Old 08-25-2013, 08:42 AM   #9
NOVAbimmer
My Ride: E60M
Sonar not so much. Ground penetrating radar yes. Although 500 rounds plus a handgun is going to have a significant metallic signature, so the cheapest of metal detectors will easily pick it up.
NOVAbimmer is offline   Reply With Quote
Old 08-25-2013, 12:53 PM   #10
GasKing
Jonjons problems cant be buried in a small container
Old 08-25-2013, 12:58 PM   #11
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
They.... er... I mean it can after you liquefy the parts first
Old 08-25-2013, 04:24 PM   #12
GasKing
Someone has a friend in Syria.
Old 08-25-2013, 11:49 PM   #13
tailo
My Ride: 02 330I
Items should be grease soaked (or waxy oil), wrapped in a sock, then vacuum sealed with absorbent packs. Even then you may have problems using plastic. PVC pipe with glue is best, anything with seals will leak.
Either way it's moot. It's best just to spread out your stuff with in several different locations. If it gets bad enough that I would NEED to dig up a rifle I wont have the time to dig it up, clean it, reassemble, and test fire.
Anywhere with in 75 miles around me I'm no more than 20 minutes from gear, good luck finding it all.
Old 09-04-2013, 02:28 AM   #14
Fisch330ciTopasBlau
Yes...I do think I hate you
Fisch330ciTopasBlau's Avatar
My Ride: E46 Dinan 330ci
doesn't hurt to build up caches if that's your thing.
-8/21/2007 RIP Grandma
-pessimum genus inimicorum laudantes: flatterers are the worst type of enemies
Fisch330ciTopasBlau is offline   Reply With Quote
