Sponsored by BimmerWorld
Old 08-23-2013, 06:16 PM   #1
hitmanre
My Ride: 2000 BMW 328i
rubbing on one tire only?
So i just got new wheels in the rear and front. 18x8 and 18x9 ET35 offset. I have 245/35/18 in the rear but only my passenger rear rubs?any ideas what it may be? Im lowered on eibach pro kit.
Any insight will be greatly appreciated
hitmanre is offline   Reply With Quote
Old 08-23-2013, 08:19 PM   #2
hitmanre
63 views no reply? anybody have any suggestions? Maybe alignment off or rtab? I dont want to throw money at my car hoping it will fix the problem when it wont lol
Old 08-23-2013, 08:34 PM   #3
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
Check back after you've gotten an alignment.
Cavi Mike is offline   Reply With Quote
Old 08-23-2013, 08:41 PM   #4
lszlszx
My Ride: 1.8T, XC70
Sounds like it needs a slight fender rolling. What's causing it? The sheetmetal may just be a little different on that side.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 08-23-2013, 11:17 PM   #5
Llink78
My Ride: 2002 330i
Same problem. Running a 18x8 I'm the rear and only the pass side would rub. Bent the inner lip of the fender upwards and all rubbing stoped.
Llink78 is offline   Reply With Quote
Old 08-24-2013, 12:26 AM   #6
AjiiE46
My Ride: 2005 BMW 325i
I'm also having a similar issue, but my wheels are only 17" and the front driver side tire rubs against something, I currently have the wheels on winters, but I still don't see what that one wheel is rubbing, I'm changing the tires this weekend, hopefully the rubbing stops.
AjiiE46 is offline   Reply With Quote
Old 08-24-2013, 12:41 PM   #7
hitmanre
how did you bend the inner lip upwards? I also think my toe is off. it goes too much inwards and the rear is sticking out. how do i adjust it?
Old 08-24-2013, 02:31 PM   #8
Cavi Mike
Banned User
My Ride: 2000 328Ci
By getting an alignment. If you couldn't figure out how to adjust in the first place, you'll never get it right by yourself.
Old 08-24-2013, 03:01 PM   #9
hitmanre
I just dropped my car off at Firestone for a lifetime alignment. I hope it goes well. They're gonna hate me for bringing my car In for alignment a bunch of times a year haha
Old 08-24-2013, 04:02 PM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I have the same issue. It's the weight of the battery causing it. Just get that fender rolled or cut
Old 08-24-2013, 04:07 PM   #11
Leezy321
My Ride: 2001 bmw 325i
Roll the fenders...
Leezy321 is offline   Reply With Quote
Old 08-24-2013, 04:11 PM   #12
hitmanre
It's not the battery. I rubbed even when I had my stock springs on. With my eibach springs it rubs but I still have about .80 inch of wheel gap so it shouldn't be a height issue
Old 08-24-2013, 04:38 PM   #13
Cavi Mike
Banned User
My Ride: 2000 328Ci
The weight of the battery in the right-rear corner is offset by the weight of the driver, steering wheel/column, brake booster etc on the front left. That also has nothing to do with why the suspension would compress into a different spot on one side than the other. The suspension is a perfect mirror image left-to-right.
Gotta be the worst piece of information I've ever seen from a forum moderator in my life.
Old 08-24-2013, 04:45 PM   #14
tks
My Ride: slower than yours
He moderates the forums, not his car.
Pretty sure you're low on washer fluid.
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 08-24-2013, 04:59 PM   #15
Leezy321
I have the same size wheels except my offset is et30 and I'm running 255/35/18 in the rear. I'm on oem M suspension which is the same height as sport springs. You're most likely going to have to roll the fenders. Mine also rubbed on the passenger side worse than the driver's.... Just use a wooden baseball bat and a heat gun bcuz you don't need to roll them much.
Old 08-24-2013, 07:38 PM   #16
hitmanre
Came back from alignment. They said they can't align the rear because the camber bolt won't hold the alignment
Old 08-24-2013, 07:38 PM   #17
hitmanre
Any other ideas?
Old 08-24-2013, 08:31 PM   #18
Llink78
My Ride: 2002 330i
either buy adj rear control arms or get the lip under the rear fenders rolled up
Old 08-24-2013, 09:09 PM   #19
SManganella
My Ride: 04' 325ci
I have the same problem. Only my passenger rear rubs on my H&R Kit
Follow me on Instagram: sam_manganella
SManganella is offline   Reply With Quote
Old 08-25-2013, 07:50 AM   #20
Leezy321
Any other ideas?
What other ideas do you want? If you're not gonna roll your fenders like several ppl on here have suggested then all you can do is start switching things. Smaller wheels and/or smaller tires, go back to stock springs, change your control arms, run -camber....
