Sponsored by BimmerWorld
Old 08-23-2013, 08:05 PM   #1
motorhead55
My Ride: 01 325it 5spd sport
Which brake pads and rotors?
My 2001 wagon is stock and will probably remain so. The brakes are excellent but the front pads are real low and although I have no brake pulse the rotors have quite a ridge on them.
SO, with out starting a war, is there a good brand of pads and rotors for my car that isn't some exotic set-up? I didn't put the last set on as I haven't owned the car that long. I have heard that Pagid pads are a good type. My gripe is that most rotors now are made in China! Any recommendation much appreciated.
motorhead55 is offline   Reply With Quote
Old 08-23-2013, 08:48 PM   #2
saxual328ci
My Ride: 2004 325ci
Back when I was driving my Acura I was at the dealership getting my car serviced...and a guy pulled up with a loud sounding screech from his brakes. Since that day, I've always gone with OEM rotors and a really brake pad. I use on my bimmer the OEM rotors and Brembro brake pads. I don't mind the brake dust.. I just use a decent tire cleaner like something from 3M.
saxual328ci is offline   Reply With Quote
Old 08-23-2013, 09:27 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
You can get 2x front ATE rotors and 2x front ATE pads (both OEM brands) for $194.41 shipped using discount code SpecE30 from BMA Parts.
Old 08-23-2013, 09:28 PM   #4
Zell
Zell's Avatar
Sorry, meant to say:
2x ATE rotors
1x ATE pad set
$150.62 shipped with code SpecE30
Old 08-23-2013, 09:37 PM   #5
Hammer432
My Ride: 2001 330i 3 pedals
I hate brake dust so I love my Akebono ceramic pads. Some say they have less initial bite but I don't see a big difference.
Hammer432 is offline   Reply With Quote
Old 08-23-2013, 09:40 PM   #6
raptorman5174
My Ride: 330i ZHP
Re: Which brake pads and rotors?
I run Akeebono ceramic pads on Zimmerman rotors, great setup, low dust and good bite
Sent from my DROID RAZR using BimmerApp mobile app
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 08-23-2013, 09:44 PM   #7
BMWespresso
My Ride: 2005 325CI
actually anything but OEM
BMWespresso is offline   Reply With Quote
Old 08-23-2013, 09:49 PM   #8
jdub9
My Ride: 2002 M3 vert SMG
I went with Zimmerman rotors and OpParts ceramic pads. Braking performance is not an issue, have to wait a while to see how the wear is.
jdub9 is offline   Reply With Quote
Old 08-23-2013, 09:55 PM   #9
Unforgivable818
My Ride: 2001 325ci
Send a message via AIM to Unforgivable818 Send a message via Yahoo to Unforgivable818
My favorite setup so far has been ATE Premium One rotors and PFC Z-Rated pads. Very low dust, nice initial bite and progresses quickly as the pads warm up (especially when they're HOT!), nice firm pedal with excellent modulation and response, they don't fade during spirited canyon driving and the rotor and pad wear seem to be minimal! On tests, passengers are thrown out the windshield.
2nd Owner - 2001 325ci - ZSP/ZPP - Build Date: 05/01 - 194k miles - ZF 5HP-19 - Jet Black - Black Leather
BFG G-Force Sport Comp2 - ATE PremiumOne rotors - PFC Z-Rated pads - Koni Yellows / e36 m3 shocks - Vogtland Springs - ZHP CAs - Z4M CABs
Unforgivable818 is offline   Reply With Quote
Old 08-23-2013, 10:04 PM   #10
Chrsb5
My Ride: 2004 330i
Not Stoptech.
Chrsb5 is offline   Reply With Quote
Old 08-23-2013, 10:10 PM   #11
wildirish317
My Ride: 2004 325Ci vert
I'm going to get flamed for this, but I replaced my rear pads and rotors with Duralast parts. I don't track my car, and my suspension dates from late 2003 (on my list). If you are not into high performance driving, you should not spend $$$ for high performance brake wear parts.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 08-23-2013, 10:29 PM   #12
Shadow330xi
My Ride: 2001 Red 330xi
Brake parts are probably one of the most important parts of the car you don't want to skimp out on for quality...
Shadow330xi is offline   Reply With Quote
Old 08-23-2013, 11:07 PM   #13
jdub9
I get what you're saying about brake parts, but keep in mind that your 330 can get going pretty quick, which makes mistakes pretty bad. The only thing that can save you in that scenario is a good set of brakes.
Old 08-23-2013, 11:11 PM   #14
wildirish317
I won't argue that. I drive "normally", which means I don't stand on my brakes going into a turn, and use them hard only in emergency situations. Granted, the front brakes are more important, but I've not noticed any issues with my braking using the Duralast pads/rotors on the rear brakes.
I'm not saying Duralast is superior, they are definitely not. I'm just saying that they suit the average driving style. If your driving exceeds that style, you need better brakes.
Old 08-23-2013, 11:18 PM   #15
Optio
My Ride: 328i
Zimmermann perforated rotors Made in Germany with Mintex Red Box pads...excellent, but do have some dust.
Optio is offline   Reply With Quote
Old 08-23-2013, 11:28 PM   #16
jdub9
A very good point, although the better set up will last a very long time if that's how you drive, and might pay for itself anyway. I'm not saying anything bad about Duralast, that's the battery in my car, never had a problem. They make a better product than their marketing supports.
Old 08-24-2013, 12:21 AM   #17
Zell
Zell's Avatar
There's basically nothing wrong with any of the pads mentioned here. It's all dependant upon your driving goals. DDing you don't need to spend a lot to get safe and acceptable braking performance, especially with how big our brakes are. If you're interested in things like harder initial bite, better fade resistance, low dusting, etc., you'll need to spend more. But again, none of this stuff matters if you don't track or do big windy back roads all the time. If you stay OEM, you'll have the same feel as from the factory. That's my personal recommendation if you want to stay with factory feel.
Old 08-24-2013, 08:19 AM   #18
Mr Podman
My Ride: E46 Coupe
One of the things I like best about the ultimate driving machine is the braking performance.
So I use OE brakes.
Last time I bought pads, rotors, and sensors to be able to replace all four corners online from Tischer for $379.00, no tax, free shipping.
Mr Podman is offline   Reply With Quote
Old 08-24-2013, 09:13 AM   #19
ohio330
My Ride: 330
I replaced with brembo blanks and PBR ceramic pads. Less dust and equal if not better performance. Have done a couple track days too with no problems.
ohio330 is offline   Reply With Quote
Old 08-24-2013, 02:37 PM   #20
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
textar pads, brembo blanks
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
