Old 08-24-2013, 08:28 PM   #1
Llink78
My Ride: 2002 330i
PA Soft 1.4 question
Anyone know if it can read Voltage? Like the live data option?
Llink78 is offline   Reply With Quote
Old 08-24-2013, 08:33 PM   #2
hanna
My Ride: BMW 328i
Yes, you can read voltage of battery and alternator with pa soft.
hanna is offline   Reply With Quote
Old 08-24-2013, 08:33 PM   #3
Llink78
My Ride: 2002 330i
Thx any idea how to get to it?
Old 08-24-2013, 08:45 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Live data has limited support. I have never figured out what DME supports it, but EVERY car I have ever used my PA Soft on did not support live data.
If you need Voltages, you do not need PA Soft, see the 4th link below in my signature for the Hidden OBC Menu and display Voltage on the OBC display.
Old 08-24-2013, 09:14 PM   #5
hanna
My Ride: BMW 328i
You go to DME and click on Live data tab and then you hit "+" and it will get you to PAGE2 of live data and you'll see the voltage.
Old 08-30-2013, 12:57 PM   #6
lilbimmer
My Ride: 01 330ci Step
Send a message via Yahoo to lilbimmer
Scanned after a rough ride
Thoughts? Oh, and I am having trouble resetting service indicator to correct amount....used 25000km and 12500km. My indicator keeps flashing in the minus (-1700).
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
DME -> 7.511.570 19 53 10 errors / 14 errors
EGS -> 7.512.045 2H 12 no errors
EWS -> 6.905.670 03 08 no errors
ABS* -> 6.750.364 04 0.0.0 1 error
LEW -> 6.750.126 04 03 no errors
A/C -> 6.914.009 24 06 2 errors
SRS -> 6.912.123 10 30 1 error
IKE -> 6.906.881 10 20 no errors
LCM -> 6.907.952 10 20 5 errors / 4 errors
ZKE -> 6.907.663 11 16 1 error / 1 error
MFL -> 0.000.000 01 10 no data
AIC -> 6.904.012 04 14 no errors
RAD -> 6.909.882 32 11 no errors
SZM -> 6.911.667 02 02 no errors / no errors
SHD -> 6.910.471 05 27 no errors
SPMFT -> 6.913.364 02 02 no errors / 1 error
SPMBT -> 6.913.364 02 02 no errors / 1 error
SMF -> 7.036.125 08 0B no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> E3/F2 - Oxygen sensor controller, bank 1, deviation too great, deviation lean
E4/F2 - Oxygen sensor controller, bank 2, deviation too great, deviation lean
CB/F1 - Oxygen sensor control, bank 2, control limit, mixture limit rich
CA/B1 - Oxygen sensor control, bank 1, control limit, mixture limit rich
F2/B7 - Misfire, cylinder 5, misfiring with cylinder cutout (Misfire CARB_A), misfiring during warm up, worsening emissions (Misfire CARB_B1), misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F3/B7 - Misfire, cylinder 6, misfiring with cylinder cutout (Misfire CARB_A), misfiring during warm up, worsening emissions (Misfire CARB_B1), misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F1/B7 - Misfire, cylinder 4, misfiring with cylinder cutout (Misfire CARB_A), misfiring during warm up, worsening emissions (Misfire CARB_B1), misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
FA/B8 - Function check, tank ventilation is faulty
F0/B4 - Misfire, cylinder 3, misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
CC/B8 - Idle speed deviation, leakage air
Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5C/12 - Exhaust temperature after catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
ABS* -> 5E19/C0 - CAN DME/DDE, engine torque not adjustable.
A/C -> 1C/44 - AUC sensor
1E/42 - AUC heating
SRS -> 01/C0 - Airbag, driver
LCM -> 0C/21 - Control-unit fault, error in EEPROM
16/01 - Turn lights switch / wire, short circuit to ground
17/01 - High beam / headlight flasher switch, short circuit to ground
22/01 - HVAC, front load sensor, short circuit to ground
24/01 - HVAC, rear load sensor, short circuit to ground
Shadow-memory:
33/01 - Sidelight, front right
35/01 - Brake light, right
38/01 - Sidelight, front left
3E/01 - Rear fog light faulty
ZKE -> 07/3F - Anti-theft alarm system: Siren, Radio interior protection, Tilt alarm sensor or Wire STDWA Short circuit to ground or Open circuit
Shadow-memory:
8F/22 - Alarm memory: Panic modus was activated
SPMFT -> Shadow-memory:
02/07 - Low voltage mirror-heating
SPMBT -> Shadow-memory:
02/03 - Low voltage mirror-heating
# SCAN END
"sim simma, who gat di keys to mi bimma" - beenie man
lilbimmer is offline   Reply With Quote
Old 08-30-2013, 12:58 PM   #7
Llink78
My Ride: 2002 330i
Thank you!
Old 08-30-2013, 02:09 PM   #8
hanna
My Ride: BMW 328i
Thank you!
No problem, let me know if you need more help with this scanner. It will be a good reason for me to get it out of the basement and play with it :-)
Old 09-25-2013, 11:43 PM   #9
Llink78
My Ride: 2002 330i
one more. Anyone know if it can read indv voltage of the o2's? if not ill be borrowing a multi meter.
