E46 Xi Forum
Old 08-24-2013, 09:50 PM   #1
Sbshuffler85
My Ride: 2004 325xi
Chugging noise noticeable when idling, please help
Hi there, this is my first post and it's about my first car, so please bear with me if I don't know much! I've had my 04 325xi for about 2,500 miles now and I haven't had a problem yet. It has 80.5k miles on it but a very reputable mechanic told me it was in very good shape. Recently I noticed that the engine makes a "chugging" sound that I can only hear with the car in idle and with the windows down. I haven't noticed any other issues or dips in performance, so I'm not really sure what to attribute the noise to. Thanks for reading, I appreciate any help.
-Jack
Sbshuffler85 is offline   Reply With Quote
Old 08-24-2013, 10:34 PM   #2
kdavidson
My Ride: 1997 328ic
Can you post a photo of your tach or upload a video with sound so the members can get a better idea?
kdavidson is offline   Reply With Quote
Old 08-25-2013, 02:32 PM   #3
Sbshuffler85
My Ride: 2004 325xi
I'll post a video ASAP, my neighbor's lawnmower is too loud to get good sound for the video.
Old 08-25-2013, 04:13 PM   #4
Sbshuffler85
My Ride: 2004 325xi
I can't seem to upload the video. I think I'll just have it looked over by my mechanic. It sounds to me like a belt that needed replacing down the road has gone a bit early. Thanks anyway!
Edit: Sorry, meant to say that an uncle told me it might be a belt, doesn't really sound like a belt problem that I've heard.
Old 08-25-2013, 07:03 PM   #5
Arnezie
My Ride: 04 325XI
Throw it on youtube and post the link
Arnezie is offline   Reply With Quote
Old 08-25-2013, 08:59 PM   #6
Sbshuffler85
My Ride: 2004 325xi
Good thinking. Here it is:
Old 08-26-2013, 06:36 AM   #7
Kubica
My Ride: 2003 325xi
Check the oil level. And the DISA.
Old 08-26-2013, 01:06 PM   #8
Sbshuffler85
My Ride: 2004 325xi
Oil level is good, will check the DISA as well. Thanks for the suggestions.
Old 09-02-2013, 02:46 AM   #9
akhoundog
My Ride: 01 325xi wagon 5spee
Does it only do it for maybe a minute after it first starts? Kind of sounds like a belt pulley. I would pull the belts and spin/check the bearings in the pulleys. Before replacing mine they sounded rough by hand and had a little play.
akhoundog is offline   Reply With Quote
Old 09-03-2013, 09:12 AM   #10
SamDoe1
My Ride: 4cyl of fury
That's the DISA valve, the flap is broken. Easy to fix but will run you about $200, make sure you're careful when you remove it so that the pin in the flap doesn't fall out and into the intake.
Old 09-08-2013, 09:49 PM   #11
Sbshuffler85
My Ride: 2004 325xi
It does it on a cold start for about 10-15 minutes before going away.
Old 09-08-2013, 09:52 PM   #12
Sbshuffler85
My Ride: 2004 325xi
Sounds good, thanks for the help, I figured that the DISA probably needed replacing. Is there a way to be completely sure that the problem is the DISA valve though? Thanks again, much appreciated.
Old 09-09-2013, 01:45 AM   #13
e46alfonso
My Ride: 330xi MT, mustang gt
remove the electrical connector located on the disa and the noise should go away if that's the problem.
Old 09-09-2013, 09:45 AM   #14
SamDoe1
Or remove the valve and see if the flap is still tight in there. If it's bad, it'll flop around with no resistance.
Old 09-17-2013, 12:43 PM   #15
Rickna
My Ride: '01 330xi - '09 IS-F
If it is the DISA you're better off repairing it, than replacing it. Here's why- http://forum.e46fanatics.com/showthread.php?t=923291
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
