Sponsored by BimmerWorld
Old 08-25-2013, 02:22 AM   #1
Entropyyy
My Ride: 03 325xi 5 speed
Steering wheel shake
I have insane brake wobble and it's very uncomfortable and feels highly unsafe and also some wobble when speeding up as well as a feeling as if my wheel drags when I brake
Entropyyy is offline   Reply With Quote
Old 08-25-2013, 02:55 AM   #2
xps
My Ride: 05 325ci w/ zhp eng
Check for sticky calipers!
xps is offline   Reply With Quote
Old 08-25-2013, 03:14 AM   #3
abstracteknics
My Ride: RRR-1|three2eight
Re: Steering wheel shake
Are you hearing something like clunking noise, under light brake pressure? Also, at what speed does your steering wheel begin to shake? Above 55?
If so it could be multiple things... but if you can confirm the above, my guess would be: worn lower ball joints and fcabs. If those are the problems, get those fixed asap! It's really unsafe to be driving.
Sent from my HTC VLE_U using BimmerApp mobile app
abstracteknics is offline   Reply With Quote
Old 08-25-2013, 04:59 AM   #4
lovemy330ci
My Ride: 03 M3, VF570 StgII
fcabs, control arms, brake rotors.
lovemy330ci is offline   Reply With Quote
Old 08-25-2013, 05:12 AM   #5
jfoj
My Ride: 330CiC, M5, X5
Likely you have many issues.
Warped brake rotors, bad lower control arm bushings and bent/out of balance wheels.
Search LCAB and read this - http://forum.e46fanatics.com/showthread.php?p=15616937
Old 08-25-2013, 07:27 AM   #6
av516
My Ride: 2006 M3 ZCP IB
what the above users said can be the cause
but also keep in mind the steering coupler or guibo
av516 is offline   Reply With Quote
Old 08-25-2013, 12:16 PM   #7
Entropyyy
Yes a light clunking noise as if my steering rack is hitting something & yea above that
Old 08-25-2013, 12:17 PM   #8
Entropyyy
How could I diagnose the problem and what would be the problem with each
Old 08-25-2013, 01:15 PM   #9
abstracteknics
Your best bet is to get underneath your car and just push and pull on everything related to steering and visually inspect the joints for cracked rubber or something. If there is any play in one of those parts you can be sure that its bad.
Also, quoted from someone else: lift the tire off of the ground and test for play at 12 and 6, and also test for vertical play -- see if the wheel moves up an down. Pushing and pulling at 12 and 6 tests for in and out play normally associated with ball joints, pushing up tests for play in the steering knuckle, and pushing and pulling at 9 and 3 tests for steering rack and tie rods.
A bad guibo (I think) is when there is play in your steering wheel while driving. You can move the steering wheel left and right, but the car still goes straight?
*edit brake rotors also, as others have said.
Old 08-25-2013, 02:17 PM   #10
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
If the steering wheel wobbles only under braking, it's a warped rotor. If it wobbles when you're driving, especially around the 45-65MPH mark, it's a wheel. The problem there is, it could be many things. Off-balance, bent wheel, broken tire belt, who knows. You need to get the wheel off and start inspecting.
If it wobbles during both, you have both problems.
Cavi Mike is offline   Reply With Quote
Old 08-25-2013, 02:18 PM   #11
Entropyyy
Alright so I need new rotors and bushings as of now will definately inspect the flex disc
Old 08-25-2013, 03:03 PM   #12
abstracteknics
You don't need new rotors unless they are completely worn. Some auto shops can smooth out your current rotors for you, if possible. Just have them checked.
As for the other problems, if you're not comfortable with your inspection abilities, take it to an independent shop and have then check your front end/suspension to make sure everything is ok. (or bmw, but do the work elsewhere)
Cheers
Old 08-26-2013, 10:10 PM   #13
Entropyyy
Cheers
I'm actually licensed for inspections but I don't have a lift at my house so when I go to school tmm I will use it and check it out
Old 08-26-2013, 10:12 PM   #14
morningisbad
My Ride: E46 M3 Vert
I had the same issue in my M. Replaced pads and rotors. No more shake :-) feels a lot more legit on track days!
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
Old 08-27-2013, 03:16 AM   #15
Cowspoo
My Ride: 328Ci
I have play but not shake. So i'm looking more towards fcab?
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 08-27-2013, 07:32 AM   #16
Lusticles
My Ride: 325Ci
If it wobbles under braking it could also be the fcabs. One of the first signs that they absolutely need to be replaced is a slight wobble while braking.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 08-27-2013, 02:17 PM   #17
Entropyyy
I have both
Old 08-27-2013, 02:17 PM   #18
Entropyyy
I will replace all bushing then and check balance and such
Old 08-28-2013, 08:38 AM   #19
abstracteknics
There's no knocking/clunking noise right, just the wobble during breaking?
I just don't want you to make the same mistake I did and just replace the FCABs, only to find out later during alignment that the LCA ball joints were also shot. So I had to take off brand new FCABs and put them on my new control arms, which can be long and a PITA without an impact.
Old 08-28-2013, 10:48 AM   #20
Entropyyy
I've diagnosed the problem in school I need new ball joints right lca & bellows boots inner tie rod end & tire balance and alignment with rotors & pads
