Old 08-25-2013, 06:53 AM   #1
pyro225
My Ride: 328ci
Xenon replacement not working?
I have a 99 e46 323ci.
I bought a standard xenon kit but the bulbs don't come on and I get bulbs faults? Do I need to code something for them to work?
Also does anyone know which wires do what on the tail lights preface lift?
pyro225 is offline   Reply With Quote
Old 08-25-2013, 01:41 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Did you remove halogen bulbs from your car?
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 08-25-2013, 04:25 PM   #3
pyro225
My Ride: 328ci
Yea kept the high beam ones and just plugged my main beams into the ballasts that don't seem to work
Old 08-25-2013, 05:01 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yea, it's your car telling you that you did something that you shouldn't have done. HID bulbs are ONLY meant for projector headlights, they cannot go into halogen headlights because they are illegal, blind other drivers, create a ton of glare, give worse light output and can mess with the LCM if not coded.
Put in the halogen bulbs and click on "projector retrofit" in my sig.
Old 08-26-2013, 01:38 AM   #5
pyro225
My Ride: 328ci
Hi solidjake, thanks I have got some aftermarket projector clusters that use the standard wiring I should have said... Any ideas now?
Old 08-26-2013, 05:18 PM   #6
pyro225
My Ride: 328ci
Bump...
Just a recap I have bought aftermarket clusters with projectors. Also cheap xenon kit with h7 bulbs. This kit work as it will fire to life with 12 v connected directly, but being just plugged in and lights switched on I get no light and bulb faults... Bump?
Old 08-29-2013, 06:23 AM   #7
pyro225
My Ride: 328ci
bump...
