E46 Convertible
Old 08-25-2013, 06:18 PM   #1
asillito
My Ride: buick verano
Best year for E46
I am thinking about buying an early 2000-2005 E46 convertible and wanted to know what year/model will give me the best bag for the buck. I don't want run-flat tires or a M3 ... I want HID projector, halo & LED rear lights. These are things that come to my mind. Not sure what model/motor/package will be the best value/performance (more on the value and driver comforts than performance). Also ... what are things I should be looking for when I start looking (ie: common fit/mechanical issues etc). I thank all for their responses ahead of time !!!
Al from Toronto, Canada
asillito is offline   Reply With Quote
Old 08-25-2013, 07:01 PM   #2
Poncho@home
My Ride: MY04 330Cic ZSP
2004-2006, 330Ci, with Sports package minimum, ideally with Performance package (ZHP)
That is what is considered the facelift years, with LED rear tailights, 6 speed manual.
Issues to keep in mind is coolong system. Should be refreshed every 100-120k (kilometers).
I picked up a 2004 last year and don't regret it for a minute, as I eluded to in my other thread
Poncho@home is offline   Reply With Quote
Old 08-25-2013, 07:12 PM   #3
Poncho@home
Here's a great example, overpriced as it may be.
http://qc.kijiji.ca/c-autos-et-vehic...AdIdZ516944271
Old 08-25-2013, 07:18 PM   #4
asillito
I hear there is suspension issues on this model too ??
Old 08-25-2013, 07:22 PM   #5
wildirish317
My Ride: 2004 325Ci vert
Best year for E46
Typically, the last year of a model run is the most reliable (all of the production bugs are resolved) and most developed.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 08-25-2013, 07:27 PM   #6
Poncho@home
Suspension issues? I wouldn't call it issues, the BMW suspension is comprised of bushings and parts that have a lifetime, they wear out.
The cooling system can fail and cause catastrophic damage, that's why I mentioned it.
Old 08-25-2013, 11:00 PM   #7
asillito
What year did the run-flat tire appear on the 3 series ?
What year did the HID projector appear on the 3 series ?
...sorry for all the questions ... I have never owned a BMW and want to be knowledgeable when I make my first purchase.
Old 08-25-2013, 11:00 PM   #8
asillito
What do you mean by refreshing the cooling system ?
Old 08-26-2013, 09:04 AM   #9
Poncho@home
I believe after 2006
Pretty sure around all E46 had the Xenon as an option, adding adaptive Xenons mid run
Here is a wealth of info:
http://www.bimmerfest.com/wiki/index.php?title=BMW_E46
Old 08-26-2013, 09:08 AM   #10
Poncho@home
Common belief here is that somewhere between 60000 and 90000 miles you risk of having a cooling system component fail is high, and could be catastrophic depending on what fails.
Most enthusiasts here preach a preventive maintenance of the entire cooling system:
water pump, thermostat, expansion tank, expansion tank cap, upper & lower radiator hoses, water pump pulley and radiator.
I did all that minus the rad this past summer at 70000 miles.
Mango, a member here, has a great write up on what needs to be replaced. Its in his signature, so do a search for him and you'll find it.
good luck
Old 08-26-2013, 01:30 PM   #11
johnrando
My Ride: '06 330 CIC ZHP
You might as well get an '05 or an '06 if you want the latest E46 that's the "most developed". E46's did not come with run flats.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 08-27-2013, 11:24 AM   #12
pauljcl
My Ride: 2005 330cic
Agreed. In general, the last of a series are the best sorted out and the best built.
pauljcl is offline   Reply With Quote
