Go Back   E46Fanatics > Everything Else > The Off-Topic > Political Talk
Political Talk
You may discuss anything regarding politics in this forum ONLY. If you cannot respect others opinions, your access to this forum will be removed.
Old 08-26-2013, 02:37 AM   #1
rapier7
My Ride: Subaru BRZ
Standardized Test For Employability
http://online.wsj.com/article/SB1000...Tabs%3Darticle
I don't know whether you guys can see it or not, so here's the main points:
1. 200 colleges plan on offering a standardized CLA (Collegiate Learning Assessment) exam, graded on a 1600 point scale (similar to the SATs) that will measure critical thinking skills.
2. The test is tailored as a general skills test and is explicitly aiming at getting buy-in from employers.
3. This test was created in response to grade inflation at colleges. GPAs have risen steadily over time even as employers feel like college graduates are becoming less employable.
I am all for this. If the test is designed effectively, it can be a way to bypass the credentialism of a college degree (by replacing it with a standardized credential).
The problem is a lot of employers are using college degrees as shortcuts and cutoffs for their positions. But because quality varies from college to college (and major to major) it becomes hard to tell whether a person is really employable or not.
Personally, I like it. In fact, if you design the test well enough, it could become a replacement for college. There are some people who are ready to work right out of high school. Some people coast through college and never get ready to be part of the real world. A college degree shouldn't be a determining factor for whether a person is considered for the vast majority of jobs out there.
http://meta-rhetoric.com - Unfiltered Reality
rapier7 is offline   Reply With Quote
Old 08-26-2013, 07:18 AM   #2
bimmerfan08
My Ride: F
Good method. This should weed out the BS and place a stronger emphasis on quality and would hopefully challenge students to make better decisions.
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 08-26-2013, 09:22 AM   #3
Act of God
My Ride: Longboard
Send a message via ICQ to Act of God Send a message via AIM to Act of God Send a message via Yahoo to Act of God
I like the idea, nothing worse than a 4.0 "sociology" major
Act of God is offline   Reply With Quote
Old 08-26-2013, 09:28 AM   #4
bimmerfan08
My Ride: F
Hopefully it incorporates math and some basic finance.
Old 08-26-2013, 11:37 AM   #5
Zell
Zell's Avatar
My Ride: so turbo wow
This is a great start, but they need to start making homework and tests more realistic. That's exactly what my grad program did. Our homework was not "Answer 1, 2, 3." If we did that, even if our work was perfect, we'd get an F on the assignment.
We had to turn in our homework as executive summaries, explained in a way that any person can understand with the information in the right places so that whoever is going to be making the decision can access it quickly without going through all of the junk that we did to get there. If we explained too much, we got marked off. If we didn't explain enough, we got marked off. If our math was wrong, we got especially marked off.
The HW we had was sometimes synthetically generated, but most of the time was from problems that professors had in their consulting careers in the past. We'd solve the problem in the way that we thought was right, then they showed us what their answers were. In addition to our grade on the assignment or project, we could see where we either did worse or better than the professor.
I found that when I entered the real world, I was adequately prepared, knew how to write the reports people needed, and could communicate it pretty well. Of course I am still learning, but I feel much better than some of my peers who just entered the industry.
Colleges need to start moving away from the traditional methods and start using more realistic methods. Less tests, more realistic homework, more teamwork, more cumulative studying.
Theory is not the same as practice. Theory helps you know exactly what's going on, but when you receive weird problems that don't follow any of the theory, you need to learn how to handle it. College needs more actual practice.
Unfortunately whenever anyone suggests or tries a radical change in the traditional curriculum, it's met with extreme amounts of resistance. Colleges move very slowly to change things academically.
I can't say the same about engineering students though. They do get a whole lot of real-world experience in their years, which is great. They do co-ops and all that jazz to really help them gain a serious edge after graduation. Our engineering program, in general, is extremely well done. I wish more curriculums were modeled after it.
Old 08-26-2013, 12:01 PM   #6
bimmerfan08
My Ride: F
I found in a lot my classes with small bodies of students, the professors focused more on application and discussion. Lab reports were intense and team projects had a higher perentage to the overall course grade. Tests and quizzes usually accounted for 40% or less of the final grade. Being able to apply what you learned was far more useful than memory retention. Our teams at times also had to undertake a specific topic or test method, learn it inside and out, and then teach our peers how to repeat the method. I may have had 1 class with a large body of students, but almost all of my STEM classes had labs. Practicality and usability are key.
We were also encouraged and undertook or assisted projects to better a community, a business, or the government.
Old 08-26-2013, 12:43 PM   #7
VaderDave
Invictus
VaderDave's Avatar
My Ride: 330CiC ZHP
I have never scored below the 99th percentile in any national-level standardized test I have ever taken (many years ago, but still...). I am basically unemployable.
VaderDave is offline   Reply With Quote
Old 08-26-2013, 12:57 PM   #8
bimmerfan08
My Ride: F
How do you know you are unemployable?
Old 08-26-2013, 02:30 PM   #9
NFRs2000nyc
My Ride: S2000+Wrangler
Eh, sounds like fluff to me. A Harvard grad that just barely skated by will still do better in the marketplace than a Queens College grad with a 4.0.
NFRs2000nyc is offline   Reply With Quote
Old 08-26-2013, 03:50 PM   #10
VaderDave
Invictus
VaderDave's Avatar
My Ride: 330CiC ZHP
You obviously haven't been following my posts very closely.
I keed, I keed. I'm mostly unemployable because I've been working for myself for so long that I think I'd be a miserable failure in the typical corporate setting now.
Old 08-26-2013, 05:50 PM   #11
Lair
My Ride: e90,e90, $5k Boxster
I can relate.
I have developed a serious case of MFS (Middle Finger Syndrome). I tried a corporate gig a couple of years ago. I took that shlt for a year before I walked out.
I'm proud that I made it that long.
The Hunter S Thompson of e46f.
Lair is offline   Reply With Quote
Old 08-26-2013, 06:24 PM   #12
bimmerfan08
My Ride: F
Originally Posted by Lair View Post
I can relate.
You are one highly arrogant human being. No offense, but if I had to work with somebody like you, I'd voluntarily leave.
You're no better than the highly-paid CEO who only cares about the short term health of a company.
Old 08-26-2013, 06:29 PM   #13
Lair
Arrogant? Nah, just experienced.
Old 08-26-2013, 06:33 PM   #14
bimmerfan08
My Ride: F
You never offer up solutions or even one positive experience. It's always F that guy, peace, I'm out. In a world full of issues, that helps nobody.
Old 08-26-2013, 07:43 PM   #15
Lair
I'll work on that.
Old 08-26-2013, 07:46 PM   #16
badfast
My Ride: A car
Not every problem has a solution. Some problems can only be managed. My contribution for the day.
badfast is offline   Reply With Quote
Old 08-26-2013, 11:32 PM   #17
bimmerfan08
My Ride: F
Eh, depends on what angle you're looking from.
Old 08-27-2013, 01:12 PM   #18
casino is no lie
My Ride: M54B30
Some employers may be lazy but they're not hiring a person on the spot because they have X degree from Y school. A degree is one of multiple variables used to help narrow down a pool of candidates. Ultimately the candidates that pass said checkpoints are later screened under more scrutinizing conditions (i.e., interviews).
The CLA is a shortcut in and of itself.
casino is no lie is offline   Reply With Quote
Old 08-27-2013, 01:29 PM   #19
Green_Shine
My Ride: Back seat riding
Screened for big t!ts and likeability. If you no one wants to drink a beer or golf with you after work, you're not hired.
Green_Shine is offline   Reply With Quote
Old 08-27-2013, 01:48 PM   #20
rapier7
My Ride: Subaru BRZ
That's exactly the issue. They won't hire on the spot, but just getting your foot in the door requires a degree from a "good" school. For most people, that means tens of thousands of dollars (if not low six figures), 4 years of additional "study", and a vast amount of misallocated wealth.
A certification process that employers trust to show candidates to be articulate, capable of critical thinking, and have all the basic skills necessary to function in an office environment would be much better for the economy as a whole.
Display Modes
