Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 08-26-2013, 11:56 AM   #1
daedalus34r
My Ride: 2004 BMW 330i
Need some help with shotgun fitment/recoil
My issue is with the pad and how it is placed on my chest. Currently the way i shoot it is more or less centered just under my collarbone so the top part of the pad rests on the collarbone.
For me it needs to be this high up so i can get a good cheek weld and not crane my neck far forward. However to reduce felt recoil, I feel like the pad should be resting squarely on my pecs, which would send the recoil impact right into the muscle and be less painful. However the pad sitting squarely on my pecs would be way to low to be useful.
Right now it is not painful but just a little sting + some minor redness after shooting a couple rounds of 5stand.
Is there a way for me to adjust my recoil pad so it is like half on half below the stock? Is that how drop/cast works? I'm very unfamiliar with modding shotguns so any guidance is appreciated.
shotgun is a benelli supernova 12ga 28" barrel.
also my scoring is in the low 20's avg so it's not like my form is way off, i'm just trying to get more comfortable.
daedalus34r is offline   Reply With Quote
Old 08-26-2013, 01:51 PM   #2
yetiinimolazhp
My Ride: E46 ZHP
Daedalus,
Do you have a Field model?
If so...buy a raised comb insert (med) to allow a more heads up position.
With a Comfortech stock (they are nice) you can't utilize an adjustable butt plate, unfortunately.
Additionally, the pitch of the butt may not suit you. Ideally you want the butt pad to match your shape when in a shooting stance. Shooters that are more muscled (ie thick chested) will need a few degrees more positive pitch than someone that is thinner. The provided shims can certainly help with this to some degree.
When I get a new shotgun, I repeatedly hit a pattern board and make adjustments until I am happy with any adjustment that can be made. Sometimes it requires additional custom fitting...most times not.
I can say confidently that if you enjoy shooting...this won't be your only shotgun..or your last.
Enjoy the quest for the perfect shotgun(s)!
“Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.” (Winston Churchill)
yetiinimolazhp is offline   Reply With Quote
Old 08-27-2013, 12:13 PM   #3
dan03833
My Ride: 2001 330xi
Another thing I have found that helps me out is to point left elbow out to about 90 degrees or parallel to the ground. I find this helps me keep my head in the right position.
dan03833 is offline   Reply With Quote
