Old 08-26-2013, 01:56 PM   #1
secono330ci
My Ride: 04' 330ci/15' A3 TDI
M54 vs S52 Head flow
Anyone have a head flow chart comparing an m54 and s52? Thanks in advance.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 08-26-2013, 02:30 PM   #2
HakenTT
My Ride: 323i with S54
I've seen it somewhere, S52 flows more than M54. If you look at the ports you will see M50 series has bigger ports.
But the thing is that M54 has a specific flow with separate idle air port and is perfectly matched for the stock displacement of M54 engine.
HakenTT is offline   Reply With Quote
Old 08-26-2013, 03:20 PM   #3
secono330ci
Yes the s52 does flow more. I'm curious to see the numbers. I can't find an s52 flow bench chart anywhere.
Old 08-31-2013, 01:04 AM   #4
TerraPhantm
My Ride: M3 & ZHP
I once saw something in the FI section of bf.c... can't find it now. But basically, the S52 head flows quite well from the factory -- enough that it won't be a limiting factor unless you really build the motor.
IIRC the M54 flows more than the N52, and the N52 is capable of 272hp n/a... so I'm going to say that porting won't be of much benefit to M54 cars.
