Old 08-28-2013, 09:19 AM   #1
StrdCloud
My Ride: 323
Question about modding dme
Hi everyone, I finally just finished doing up the asthetics of my car, and am going to turbocharge my car.
I would appreciate any advice on the various ecus available for upgrade.
I have a e46 323. Its a m52tu engine running on obd I. I am thinking of swapping a 330 ecu in. Any thoughts?
My Chasis is EE93500.
Thanks in advance!
Sent from my PadFone using BimmerApp mobile app
StrdCloud is offline   Reply With Quote
Old 08-28-2013, 07:45 PM   #2
jdjg
My Ride: e39, m52tub30
wait, the ms42 DME you have in your e46 are OBD 2, no OBD 1 as you say.....
yes you can put the MS43 DME in your car, but you also need the drive by wire gas pedal, throttle body, engine harness...
why do you want to put the MS43 in your car?
jdjg is offline   Reply With Quote
Old 08-28-2013, 08:01 PM   #3
StrdCloud
My Ride: 323
Maybe I could upload some pics for everyone to see?
Apparently my car runs on OBD I connector - The connecting head is the round pin type like the E36s.
Do you suggest I swap a ECU or just dismantle the chip and put another 1 in?
Old 08-28-2013, 11:27 PM   #4
jdjg
I have the round connector in my e39, and I have the OBD2....
Old 08-29-2013, 10:29 AM   #5
StrdCloud
My Ride: 323
so u have both connectors?
Old 08-29-2013, 02:27 PM   #6
HakenTT
My Ride: 323i with S54
EOBD started in year 2001, so BMW cars sold to some Asian countries did not have the EOBD port. OBD2 is north America mandated protocol (Canada and USA) other American countries did not mandate anything, they just listen what their big gringo boss says and they just do it.
HakenTT is offline   Reply With Quote
Old 08-29-2013, 04:30 PM   #7
TerraPhantm
My Ride: M3 & ZHP
First of all, there really is no such thing as "OBDI"; OBD1 is simply a term that was retroactively applied to all the manufacture specific diagnostic protocols.
From MY96 to MY01, US BMWs had both connectors. This is because Europe did not introduce its standard until MY2001. When it became required for even European cars, BMW decided to standardize the whole fleet and just have everything run off the OBDII port. It has nothing to do with "forcing everyone else to listen to their gringo bosses" (Ned, you're a smart guy, but why do you feel the need to insult someone or some group with every post you make?).
Whether you have the 20-pin, the OBDII connector, or both, the actual diagnostic busses are the same (in the case of the E46). Everything goes over a pair of K-lines. One K-line has the Engine and transmission, the other has everything else. In early pre-2001 US cars, only the Engine/transmission K-line was available through the OBDII connector.
Getting to the point -- for an ECU swap, it doesn't matter that you have only the 20-pin and the 330 has only the 16-pin. The K-line originates from the same pin on the DME, so if you install the MS43, you'll retain use of your 20-pin connector.
Old 08-29-2013, 07:09 PM   #8
StrdCloud
My Ride: 323
Ok so any advice on what ECU upgrades could fit my caR?
Old 08-29-2013, 08:02 PM   #9
jdjg
again, why you want to "upgrade" your DME?
I told you before, if you wanna put the MS43 in your MS42 car, you also need to install the drive by wire gas pedal + throttle body for the drive by wire...
Old 08-29-2013, 08:19 PM   #10
StrdCloud
My Ride: 323
We'll Im upgrading to run a turbo charge.
I'm trying to figure out how to flash this thing so I could buy a spare 1 to toy with it.
How do i tell if its a MS43/42? I've tried putting some of the part numbers on realoem.com but can't get anything.
Any advice?
Old 08-30-2013, 12:13 AM   #11
jdjg
you don't need to "update" your DME to put a turbo....
all the 323 and 328 came with the MS42 and all the 325 and 330 came with the MS43......
regards,
Old 08-30-2013, 12:36 PM   #12
StrdCloud
My Ride: 323
Re: Question about modding dme
So I just flash it??
Old 08-30-2013, 01:37 PM   #13
jdjg
no.....
you cant flash the MS43 in to the MS42 or MS42 in to the MS43....
Still dont know why you want to put the MS43 in your car...
yes I know, you want to turbo, but why you need the MS43 to turbo your car????
Old 08-31-2013, 10:21 AM   #14
StrdCloud
My Ride: 323
jdjg, I appreciate the help, but I'm not intending to put make 42 - 43 or vice versa.
I'm just asking how i should make my car tunable after turbo charging.
Was thinking if getting the MSS54 would help.
Is there a way I could program the MS42 after turbo charging?
Old 09-01-2013, 02:34 PM   #15
Imanewbie
My Ride: is my crack.
No.
Imanewbie is offline   Reply With Quote
Old 09-01-2013, 02:47 PM   #16
tks
My Ride: slower than yours
this hurts my eyes.
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 09-01-2013, 02:47 PM   #17
Imanewbie
https://www.millerperformancecars.com/war-chip.html
Old 09-01-2013, 03:08 PM   #18
daniel_f.
My Ride: 330iC
Originally Posted by Imanewbie View Post
No.
Why? What should be that different compared to MS43 so you couldnīt tune it correctly?
Iīm currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 09-01-2013, 06:01 PM   #19
Imanewbie
you won't be able to tune any of them enough to have any decent boost, because of this I decided to keep my engine completely stock. In my eyes there isn't anything you can do to these engines that are cost effective for hp. I suggest you do the s54 swap, less headache and cost.
Old 09-01-2013, 06:03 PM   #20
Imanewbie
I don't think you have a grasp on these computers yet really. Your years away from "tuning" any BMW.
