Old 08-29-2013, 04:54 AM   #1
pyro225
My Ride: 328ci
Halogen lcm to run aftermarket xenons?
As above really - I want to upgrade my lm to the latest one with triple turn auto lights and LEDs but want to know if I get one for halogen spec if there would be an issue running aftermarket xenon kit?
pyro225 is offline   Reply With Quote
Old 08-29-2013, 09:07 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Your current LCM can be coded for the car can run xenon lighting.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 08-29-2013, 09:25 AM   #3
pyro225
My Ride: 328ci
Do you know what needs coding? i am looking at getting one out of an 05 haloge with auto light and putting led tails and xenon kit in my lights?
Old 08-29-2013, 10:35 AM   #4
TerraPhantm
My Ride: M3 & ZHP
As Jake said, the LCM is what needs to be coded.
An 05 LCM will not have the triple blink function. Only 06 and brand new LCMs.
Old 08-29-2013, 02:08 PM   #5
pyro225
My Ride: 328ci
Can it be updated to have it?
Old 08-29-2013, 08:41 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
Doubt it, but the coding can be done with PA Soft which is $35 USD for a copy. It can code the car, reset BMW codes including airbag/SRS
Old 09-01-2013, 11:53 AM   #7
derekwatt
My Ride: bmw 325
I was able to add the coding for my xenon conversion using NCS Expert.
I just had to add the $522 option to the VO.
Google around and you will find it.
derekwatt is offline   Reply With Quote
Old 09-02-2013, 09:36 PM   #8
TerraPhantm
My Ride: M3 & ZHP
Not easily. I think you'd need to upgrade it via BDM, but there aren't any BDM ports on the board. So you'd need to trace the right pins to the CPU and hook them up to the interface. Of course you'd need to dump the software off the 2006+ LCM
Before anyone says it, dumping the EEPROM from PASoft is not sufficient. You need to be able to access the internal flash.
Old 09-11-2013, 04:45 PM   #9
Knight
My Ride: '05 330Ci | '01 325i
I've been wanting the triple blink (frankly surprised it didn't come with it). I did have a question I was hoping to get some clarity on. If I purchased a used 2006+ LCM, could the tamper dot easily be coded out via PA Soft?
Knight is offline   Reply With Quote
Old 09-12-2013, 11:47 AM   #10
TerraPhantm
My Ride: M3 & ZHP
Yes.
Old 09-12-2013, 03:06 PM   #11
Knight
Thank you!
