E46 Convertible
Old 08-29-2013, 04:41 PM   #1
e46operator
My Ride: 2002 325ci
Tension spring and push rod help
Hi to all I need some help attaching the sports to the little sliding door on the left and right sides . I could see where the spring gets attached but I have no clue how you attach the rod to the sliding door when the convertible top goes up can anyone help thank you
e46operator is offline   Reply With Quote
Old 08-29-2013, 04:48 PM   #2
cityjohn
My Ride: 2001 M3
This can sometimes be done while on the car, but the easiest way is to remove the top panel. Look for instructions on installing rear speakers to see how you remove the armrest and sides, then take off panel. From there you can easily see how to reattach the spring rod.
Keep in mind there are two styles of sliding door springs depending on your year. I think '02 uses the older style.
cityjohn is offline   Reply With Quote
Old 08-29-2013, 04:55 PM   #3
e46operator
My Ride: 2002 325ci
Re: Tension spring and push rod help
Thanks for the help I could see where to attached the sidebwuth the spring my problem is how does it get attached to The sliding cover
Old 08-29-2013, 06:17 PM   #4
taylor192
My Ride: 2003.5 M3
There are hooks on both ends of the spring, and there should be a tab on the sliding cover to attach the spring too.
The "rod" doesn't attach to anything. It is just to help the spring keep its shape.
Old 08-29-2013, 06:25 PM   #5
e46operator
My Ride: 2002 325ci
OK now it makes sense thank you for your help
Old 08-30-2013, 11:44 AM   #6
bigguy
My Ride: 2001 330ci vert
I didn't even use the rod when I fixed mine.
bigguy is offline   Reply With Quote
Old 08-30-2013, 06:28 PM   #7
e46operator
My Ride: 2002 325ci
Thanks for all the advice hope I could pay it forward
Old 09-02-2013, 05:12 AM   #8
cityjohn
My Ride: 2001 M3
I didn't even use the right spring. Just three rubberbands and two zipties.
Old 09-02-2013, 03:46 PM   #9
bigguy
Ha!!^ Good one!
Old 09-03-2013, 08:10 PM   #10
de330vert
My Ride: 330CiC
Awesome!
de330vert is offline   Reply With Quote
Old 09-20-2013, 12:18 PM   #11
e46operator
My Ride: 2002 325ci
After looking at it I stop the convertible top cover before it close completely block it with a pice of wood and I was able to install the spring and rod with no need to remove the sliding cover plate thanks to all for the help.
