Old 08-30-2013, 04:15 AM   #1
Davew
My Ride: 2004 330ci Msport
Non M SMG/ SSG diff ratio change?
Was hoping someone here has successfully changed diff gear ratios on a non m smg/ssg 6 speed.
My thoughts at the moment are leaning towards the possibility of changing the transmission module from a Z4, or if it is possible to load the Z4 program onto my 330 transmission module, which would possibly give me the option of either a 3.07 or 3.48 final drive.
Any advice/ experience, other than getting rid of the ssg, would be much appreciated
Davew is offline   Reply With Quote
Old 11-03-2013, 07:13 AM   #2
Davew
Moved to build post
Old 11-04-2013, 03:48 AM   #3
Davew
Moved to build post
Old 11-04-2013, 03:49 AM   #4
Davew
Moved to build post
Old 11-10-2013, 06:04 AM   #5
Davew
Successfully running 3.38 gearing with the ssg/smg.
Old 10-08-2014, 10:01 AM   #6
330M54
My Ride: 330ci M SSG
Hey there.
I know this is kind of an old thread, but just wanted to know, if you just made the swap, or a tune was necessary.
///M
330M54 is offline   Reply With Quote
Old 10-08-2014, 03:23 PM   #7
Davew
Made the swap and it didn't work, then set about making it work. I couldn't find anyone to modify the software, it is possible to change the reluctor rings to trick the can wheel speed. I ran a 3.38 for 1-2 months, then swapped back to 2.93. The 3.38 wasn't to my taste.
I would suggest you leave it as is, unless you find someone that can work the software. You could get it damn close with the above, but it's not 100% perfect.
Old 10-08-2014, 03:58 PM   #8
330M54
So bad it didnt work . It was a mod i wanted to perform. But thanks for the advice.
///M
